87723 002500
87723 002500
    BELDEN
    CBL 2PR 22AWG SHLD
87723 002500 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 87723 Multi-Conductor - Double-Pair Cable For more Information please call 1-800-Belden1 General Description: 22 AWG stranded (7x30) TC conductors, plenum, FEP insulation, twisted pairs, individually shielded Beldfoil® (100% coverage), 24 AWG stranded TC drain wire, fluorocopolymer jacket. Physical Characteristics (Overall) Conductor AWG: # Pairs AWG Stranding Conductor Material 2 22 7x30 TC - Tinned Copper Total Number of Conductors: 4 Insulation Insulation Material: Insulation Material Wall Thickness (in.) FEP - Fluorinated Ethylene Propylene 0.007 Inner Shield Inner Shield Material: Inner Shield Trade Name Type Inner Shield Material Beldfoil® (Z-Fold®) Coverage (%) Tape Aluminum Foil-Polyester Tape 100 Inner Shield Drain Wire AWG: AWG 24 Inner Shield Drain Wire Stranding: 7x32 Inner Shield Drain Wire Conductor Material: TC - Tinned Copper Outer Shield Outer Shield Material: Outer Shield Material Unshielded Outer Jacket Outer Jacket Material: Outer Jacket Material Nom. Wall Thickness (in.) PVDF - Fluorocopolymer 0.014 Overall Cable Overall Nominal Diameter: 0.148 in. Pair Pair Color Code Chart: Number Color 1 Red & Black 2 Green & White Mechanical Characteristics (Overall) Operating Temperature Range: -20°C To +150°C Bulk Cable Weight: 18 lbs/1000 ft. Max. Recommended Pulling Tension: 46 lbs. Min. Bend Radius/Minor Axis: 1.500 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMP CEC/C(UL) Specification: CMP EU Directive 2011/65/EU (ROHS II): Yes Page 1 of 3 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 87723 Multi-Conductor - Double-Pair Cable EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 04/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Flame Test UL Flame Test: NFPA 262 CSA Flame Test: FT6 Plenum/Non-Plenum Plenum (Y/N): Yes Non-Plenum Number: 8723 Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 40 Nom. Capacitance Conductor to Conductor: Capacitance (pF/ft) 35 Nom. Capacitance Cond. to Other Conductor & Shield: Capacitance (pF/ft) 67 Nominal Velocity of Propagation: VP (%) 69 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 14.7 Nom. Inner Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 15 Nominal Conductor Loop Resistance: Resistance @ 20°C (Ohm/1000 ft) 34 Max. Operating Voltage - UL: Voltage 300 V RMS Max. Recommended Current: Current 2.3 Amps per conductor @ 25°C Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 87723 0021000 1,000 FT 20.000 LB RED C 2 SH PR #22 FEP SOLEF 87723 002500 500 FT 11.000 LB RED C 2 SH PR #22 FEP SOLEF Notes: C = CRATE REEL PUT-UP. Revision Number: 2 Revision Date: 11-05-2012 © 2016 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the Page 2 of 3 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 87723 Multi-Conductor - Double-Pair Cable correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 3 of 3 08-26-2016
87723 002500
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款光耦器件。
2. 器件简介:EL817是一种通用型晶体管输出光耦器件,具有较高的输入输出隔离电压和快速响应时间。
3. 引脚分配:EL817共有6个引脚,其中1脚为发光二极管的阳极,2脚为阴极,3脚为集电极,4脚为发射极,5脚为集电极,6脚为发射极。
4. 参数特性:输入电流范围为5-20mA,输出电流范围为10-30mA,隔离电压为5000Vrms。
5. 功能详解:EL817通过光电效应实现电信号的隔离传输,适用于需要电气隔离的场合。
6. 应用信息:广泛应用于通信设备、工业控制、医疗设备等领域。
7. 封装信息:采用DIP-6封装形式。
87723 002500 价格&库存
很抱歉,暂时无法提供与“87723 002500”相匹配的价格&库存,您可以联系我们找货
  • 500+37.09489500+4.82122
