8777 0603280
8777 0603280
    BELDEN
    CBL 3PR 22AWG SHLD
8777 0603280 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 8777 Multi-Conductor - Shielded Twisted Pair Cable For more Information please call 1-800-Belden1 General Description: 22 AWG stranded (7x30) tinned copper conductors, polypropylene insulation, twisted pairs individually Beldfoil® Shielded (100% coverage), 22 AWG stranded tinned copper drain wire, PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Pairs AWG Stranding Conductor Material Dia. (in.) 3 22 7x30 TC - Tinned Copper .030 Total Number of Conductors: 6 Insulation Insulation Material: Insulation Material Wall Thickness (in.) PP - Polypropylene 0.011 Inner Shield Inner Shield Material: Layer # Inner Shield Trade Name Type Inner Shield Material Coverage (%) 1 Beldfoil® Tape Aluminum-Polyester 100.000 Inner Shield Drain Wire AWG: AWG 22 Inner Shield Drain Wire Stranding: 7x30 Inner Shield Drain Wire Conductor Material: TC - Tinned Copper Outer Shield Outer Shield Material: Outer Shield Material Unshielded Outer Jacket Outer Jacket Material: Outer Jacket Material Nom. Wall Thickness (in.) PVC - Polyvinyl Chloride 0.034 Overall Cable Overall Nominal Diameter: 0.273 in. Pair Pair Color Code Chart: Number Color 1 Black & Red 2 Black & White 3 Black & Green Pair Lay Length & Direction: Lay Length (in.) Twists (twist/ft) Direction 1.750 6.900 Left Hand Mechanical Characteristics (Overall) Storage Temperature Range: -40°C To +80°C Operating Temperature Range: -20°C To +80°C UL Temperature Rating: 80°C (UL AWM Style 2919) Bulk Cable Weight: 39 lbs/1000 ft. Max. Recommended Pulling Tension: 79 lbs. Min. Bend Radius/Minor Axis: 2.750 in. Page 1 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 8777 Multi-Conductor - Shielded Twisted Pair Cable Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CM NEC Articles: 800 CEC/C(UL) Specification: CM AWM Specification: UL Style 2919 (30 V 80°C) EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Flame Test UL Flame Test: UL1685 UL Loading CSA Flame Test: FT1 Suitability Suitability - Indoor: Yes Plenum/Non-Plenum Plenum (Y/N): No Plenum Number: 88777, 87777, 82777 Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 50 Nom. Inductance: Inductance (µH/ft) 0.18 Nom. Capacitance Conductor to Conductor: Capacitance (pF/ft) 30 Nom. Capacitance Cond. to Other Conductor & Shield: Capacitance (pF/ft) 55 Nominal Velocity of Propagation: VP (%) 66 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 15.0 Ind. Pair Nominal Shield DC Resistance @ 20 Deg. C: 10.600 Ohm/1000 ft Max. Operating Voltage - UL: Voltage Description 300 V RMS Listed type CM 30 V RMS AWM 2919 Max. Recommended Current: Description Current 10C temperature rise 2 Amps per conductor @ 25°C ambient Put Ups and Colors: Item # Putup Ship Weight Color 8777 060U1000 1,000 FT 41.000 LB CHROME Notes 3 SH PR #22 PP PVC 8777 060U500 500 FT 21.000 LB CHROME 3 SHLD PR #22 PP PVC Page 2 of 3 Item Desc 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 8777 Multi-Conductor - Shielded Twisted Pair Cable 8777 060100 100 FT 4.700 LB CHROME 8777 0601000 1,000 FT 43.000 LB CHROME C 3 SHLD PR #22 PP PVC 3 SHLD PR #22 PP PVC 8777 06010000 10,000 FT 460.000 LB CHROME CY 3 SHLD PR #22 PP PVC 8777 0601640 1,640 FT 68.880 LB CHROME C TRANSFER REVIEW (20 TO 30) 8777 060250 250 FT 11.250 LB CHROME C 3 SHLD PR #22 PP PVC 8777 0603280 3,280 FT 137.760 LB CHROME C TRANSFER REVIEW (20 TO 30) 8777 060500 500 FT 21.500 LB CHROME C 3 SHLD PR #22 PP PVC 8777 0605000 5,000 FT 215.000 LB CHROME C 3 SHLD PR #22 PP PVC Notes: C = CRATE REEL PUT-UP. Y = FINAL PUT-UP LENGTH MAY VARY -10% TO +20% FROM LENGTH SHOWN.MAY CONTAIN 2 PIECES. MINIMUM LENGTH OF ANY ONE PIECE IS 1500'. Revision Number: 2 Revision Date: 08-02-2013 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 3 of 3 01-05-2017
8777 0603280 价格&库存
很抱歉,暂时无法提供与“8777 0603280”相匹配的价格&库存,您可以联系我们找货
