8787 060U500
8787 060U500
    BELDEN
    2 #22, 8 #24 FS PVC
8787 060U500 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 8787 Multi-Conductor - Special Audio, Communication and Instrumentation Cable For more Information please call 1-800-Belden1 General Description: 24 and 22 AWG stranded (7x32 and 7x30)) TC conductors, PVC insulation (22 AWG) / polyethylene insulation (24 AWG), cabled in quads, 24 AWG stranded TC drain wire, PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Conductors AWG Stranding Conductor Material 8 24 7x32 TC - Tinned Copper 2 22 7x30 TC - Tinned Copper Total Number of Conductors: 10 Insulation Insulation Material: Insulation Material Wall Thickness (in.) AWG PE - Polyethylene .012 24 PVC - Polyvinyl Chloride .015 22 Insulation Resistance: 100 Megaohms/1000 ft. @ 500 V DC Inner Shield Inner Shield Material: Inner Shield Trade Name Type Inner Shield Material Beldfoil® (Z-Fold®) Coverage (%) Tape Aluminum Foil-Polyester Tape 100 Inner Shield Material (Multi-AWG): AWG Inner Shield Trade Name Type Inner Shield Material Coverage (%) Description 24 Beldfoil® Tape Aluminum Foil-Polyester Tape 100 Over Quad 24 Beldfoil® Tape Aluminum Foil-Polyester Tape 100 Over Quad 22 Unshielded Singles Inner Shield Drain Wire AWG: AWG 24 Inner Shield Drain Wire Stranding: 7x32 Inner Shield Drain Wire Conductor Material: TC - Tinned Copper Inner Shield Waterblocking Tape: Gray, White, Blue, Green; Brown, Red, Yellow, Orange; White, Blue Outer Jacket Outer Jacket Material: Outer Jacket Material Nom. Wall Thickness (in.) PVC - Polyvinyl Chloride .030 Overall Cable Overall Cabling Color Code Chart: Number Color AWG Group/Cond. Color 1 Red Quad 24 Red Quad 2 White 22 White 3 Green Quad 24 Green Quad 4 Blue Blue 22 Overall Nominal Diameter: 0.290 in. Mechanical Characteristics (Overall) Operating Temperature Range: -20°C To +80°C Non-UL Temperature Rating: 80°C Bulk Cable Weight: 45 lbs/1000 ft. Max. Recommended Pulling Tension: 62.200 lbs. Page 1 of 2 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 8787 Multi-Conductor - Special Audio, Communication and Instrumentation Cable Min. Bend Radius/Minor Axis: 3 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 04/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Flame Test UL Flame Test: VW-1, UL1685 UL Loading Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Conductor DC Resistance: Description DCR @ 20°C (Ohm/1000 ft) 24 AWG 23.9 22 AWG 15 Nom. Inner Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 5 Max. Operating Voltage - Non-UL: Voltage 350 V RMS Max. Recommended Current: Current 1.5 Amps per conductor @ 25°C (24 AWG); 2.0 Amps per conductor @ 25°C (22 AWG) Notes (Overall) Notes: Inner Beldfoil® shield over 24 AWG quads. Each quad wrapped in transparent polyester tape. Red Beldfoil® shield over one quad, Green Beldfoil® shield over the other. (2) quads and (2) unshielded conductors cabled. Put Ups and Colors: Item # Putup Ship Weight Color 8787 060U500 500 FT 24.000 LB CHROME 8787 060500 500 FT 24.000 LB CHROME Notes Item Desc 2 #22, 8 #24 FS PVC C 2 #22, 8 #24 FS PVC Notes: C = CRATE REEL PUT-UP. Revision Number: 1 Revision Date: 08-27-2012 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 2 of 2 01-05-2017
8787 060U500 价格&库存
很抱歉,暂时无法提供与“8787 060U500”相匹配的价格&库存,您可以联系我们找货
