9228 0102000
9228 0102000
    BELDEN
    COAX RG-62A/U 22AWG 93 OHM
9228 0102000 数据手册
Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 9228 Coax - 93 Ohm For more Information please call 1-800-Belden1 General Description: 93 ohm, RG-62A/U type, 22 AWG solid .025" bare copper-covered steel conductor, semi-solid polyethylene insulation, bare copper braid shield (95% coverage), high-density polyethylene jacket. Physical Characteristics (Overall) Conductor AWG: # Coax AWG Stranding Conductor Material 1 22 Solid Dia. (mm) BCCS - Bare Copper Covered Steel 0.635 Total Number of Conductors: 1 Insulation Insulation Material: Insulation Material Wall Thickness (mm) Dia. (mm) Semi-Solid PE - Semi-Solid Polyethylene 0.660 3.708 Tracer Tracer AWG: Solid Outer Shield Outer Shield Material: Type Outer Shield Material Coverage (%) Braid BC - Bare Copper 95 Outer Shield Flooding Grease: Polyethylene Outer Jacket Outer Jacket Material: Outer Jacket Material Nom. Wall Thickness (mm) HDPE - High Density Polyethylene 0.838 Overall Cable Overall Nominal Diameter: 6.147 mm Mechanical Characteristics (Overall) Operating Temperature Range: -55°C To +80°C Non-UL Temperature Rating: 80°C Bulk Cable Weight: 44.646 Kg/Km Max. Recommended Pulling Tension: 373.649 N Min. Bend Radius/Minor Axis: 63.500 mm Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes Page 1 of 3 10-30-2013 Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 9228 Coax - 93 Ohm EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes RG Type: 62/U Suitability Suitability - Outdoor: Yes Suitability - Burial: Yes Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 93 Nom. Inductance: Inductance (µH/m) 0.380596 Nom. Capacitance Conductor to Shield: Capacitance (pF/m) 44.2935 Nominal Velocity of Propagation: VP (%) 84 Nominal Delay: Delay (ns/m) 3.9372 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/km) 135.177 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/km) 9.5149 Nom. Attenuation: Freq. (MHz) Attenuation (dB/100m) 1 0.9843 10 2.9529 50 6.2339 100 8.8587 200 12.4678 400 17.3893 700 23.9513 900 26.9042 1000 28.5447 Max. Operating Voltage - Non-UL: Voltage 300 V RMS Put Ups and Colors: Item # Putup Ship Weight Color Page 2 of 3 Notes Item Desc 10-30-2013 Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 9228 Coax - 93 Ohm 9228 0101000 305 MT 14.969 KG BLACK C RG-62A/U TYPE COAX 9228 0102000 610 MT 30.844 KG BLACK C RG-62A/U TYPE COAX 9228 010500 152 MT 7.484 KG BLACK C RG-62A/U TYPE COAX 9228 0105000 1,524 MT 77.111 KG BLACK C RG-62A/U TYPE COAX Notes: C = CRATE REEL PUT-UP. Revision Number: 3 Revision Date: 10-16-2012 © 2013 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 73/23/EEC), as amended by directive 93/68/EEC. Page 3 of 3 10-30-2013
9228 0102000 价格&库存
很抱歉,暂时无法提供与“9228 0102000”相匹配的价格&库存,您可以联系我们找货
