9267 0101000
9267 0101000
    BELDEN
    #20 FPE BRD PE BRD CSM
9267 0101000 数据手册
Part Number: 9267 Video Triax, RG59, #20 Solid, CSPE Jacket Product Description 20 AWG solid .032" bare copper conductor, gas-injected foam high density polyethylene insulation, paper tape separator, bare copper braid shields (95% and 80% coverage), CSPE - Chlorosulphonated Polyethylene jacket. Technical Specifications Product Overview Environmental Space: Indoor/Outdoor Physical Characteristics (Overall) Conductor AWG Stranding 20 Solid Material Nominal Diameter No. of Coax BC - Bare Copper 0.032 in 1 Conductor Count: 1 AWG Size: 20 Insulation Material Nominal Diameter Gas-injected FHDPE - Foam High Density Polyethylene 0.145 in Inner Shield Material Type Material Coverage [%] Braid BC - Bare Copper 95 % Inner Jacket Material Material Nominal Diameter PE - Polyethylene 0.216 in Outer Shield Material Type Material Coverage [%] Braid BC - Bare Copper 80 % Outer Jacket Material Material Nominal Diameter Separator Material CSPE - Chlorosulphonated Polyethylene 0.36 in Paper tape Electrical Characteristics Conductor DCR Nominal Conductor DCR 10.1 Ohm/1000ft Nominal Conductor DCR Conductor Resistance Nominal Inner Shield DCR Nominal Outer Shield DCR 10.1 Ohm/1000ft Capacitance Nom. Capacitance Conductor to Shield 16.3 pF/ft Inductance Nominal Inductance 2.5 Ohm/1000ft 2.6 Ohm/1000ft 0.097 µH/ft Impedance Nominal Characteristic Impedance 75 Ohm Return Loss (RL) Frequency [MHz] Min. Structural Return Loss (SRL) 5-850 MHz 21 dB 850-3000 MHz 15 dB High Frequency (Nominal/Typical) Frequency [MHz] Nom. Insertion Loss 1 MHz 0.3 dB/100ft 3.6 MHz 0.6 dB/100ft 10 MHz 0.9 dB/100ft 71.5 MHz 2.1 dB/100ft 135 MHz 2.9 dB/100ft 270 MHz 4.2 dB/100ft 360 MHz 4.8 dB/100ft 540 MHz 6 dB/100ft 720 MHz 6.7 dB/100ft 750 MHz 6.9 dB/100ft 1000 MHz 8.3 dB/100ft 1500 MHz 10.5 dB/100ft 2250 MHz 13.4 dB/100ft 3000 MHz 15.9 dB/100ft Delay Nominal Delay Nominal Velocity of Propagation (VP) [%] 1.24 ns/ft 82 % Voltage Non-UL Voltage Rating 300 V RMS Temperature Range Non-UL Temp Rating: 80°C Operating Temp Range: -20°C To +80°C Mechanical Characteristics Bulk Cable Weight: 72 lbs/1000ft Max Recommended Pulling Tension: 124 lbs Min Bend Radius/Minor Axis: 3.5 in Standards CPR Euroclass: Eca RG Type: RG-59/U Type Applicable Environmental and Other Programs EU Directive 2000/53/EC (ELV): Yes EU Directive 2011/65/EU (ROHS II): Yes EU Directive 2012/19/EU (WEEE): Yes EU Directive 2015/863/EU: Yes EU Directive Compliance: EU Directive 2003/11/EC (BFR) EU CE Mark: No EU RoHS Compliance Date (yyyy-mm-dd): 2004-01-01 CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Suitability Suitability - Aerial: Yes - When supported by messenger wire Suitability - Burial: Yes Suitability - Indoor: Yes Suitability - Outdoor: Yes Flammability, LS0H, Toxicity Testing UL Flammability: VW-1 Part Number Plenum (Y/N): No Footnote: C - CRATE REEL PUT-UP. © 2018 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS(Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be instock at Belden facilities and in our Distributor's inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden's knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 73/23/EEC), as amended by directive 93/68/EEC.
9267 0101000 价格&库存
很抱歉,暂时无法提供与“9267 0101000”相匹配的价格&库存,您可以联系我们找货
