9271 060500
9271 060500
    BELDEN
    BELDEN - 9271 060500 - Twinaxial Cable, Computer Instrumentation, 25 AWG, 0.163 mm², 124 ohm, Blue, ...
9271 060500 数据手册
9271 Twinax - Twinaxial Cable For more information please call 1-800-Belden1 See Put-ups and Colors Description: 25 AWG stranded (7x33) tinned copper conductors, polyethylene insulation, Beldfoil® shield (100% coverage), stranded tinned copper drain wire, PVC jacket. PHYSICAL CHARACTERISTICS: CONDUCTOR: Number of Pairs 1 Total Number of Conductors 2 AWG 25 Stranding 7x33 Conductor Diameter .021 in. Conductor Material TC - Tinned Copper INSULATION: Insulation Material PE - Polyethylene Insulation Diameter .083 in. PAIR: Pair Diameter .170 in. Pair Color Code Chart : Number 1 Color Blue & Clear OUTER SHIELD: Outer Shield Trade Name Beldfoil® Outer Shield Type Tape Outer Shield Material Aluminum Foil-Polyester Tape Outer Shield %Coverage 100 % OUTER SHIELD DRAIN WIRE : Outer Shield Drain Wire AWG 22 Outer Shield Drain Wire Stranding 7x30 Outer Shield Drain Wire Conductor Material TC - Tinned Copper OUTER JACKET: Outer Jacket Material PVC - Polyvinyl Chloride Page 1 of 3 9271 Twinax - Twinaxial Cable OVERALL NOMINAL DIAMETER: Overall Nominal Diameter .240 in. MECHANICAL CHARACTERISTICS: Operating Temperature Range -20°C To +60°C UL Temperature Rating 60°C (UL AWM Style 2092) Bulk Cable Weight 25 lbs/1000 ft. Max. Recommended Pulling Tension 17 lbs. Min. Bend Radius (Install) 2.5 in. APPLICABLE SPECIFICATIONS AND AGENCY COMPLIANCE: APPLICABLE STANDARDS: NEC/(UL) Specification CM CEC/C(UL) Specification CM AWM Specification UL Style 2092 (300 V 60°C) EU CE Mark (Y/N) Yes EU RoHS Compliant (Y/N) Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 FLAME TEST: UL Flame Test UL1685 UL Loading PLENUM/NON-PLENUM: Plenum (Y/N) N ELECTRICAL CHARACTERISTICS: Nom. Characteristic Impedance 124 Ohms Nom. Inductance 0.188 µH/ft Nom. Capacitance Conductor to Conductor @ 1 KHz 12.2 pF/ft Nom. Cap. Cond. to Other Cond. & Shield @ 1 KHz 22.0 pF/ft Nominal Velocity of Propagation 66 % Nominal Delay 1.54 ns/ft Nom. Conductor DC Resistance @ 20 Deg. C 31.8 Ohms/1000 ft Nominal Outer Shield DC Resistance 12 Ohms/1000 ft Nom. Attenuation : Description Frequency (MHz) Start Frequency (MHz) 1 10 50 100 200 400 Page 2 of 3 Stop Frequency (MHz) Nom. Attenuation (dB/100 ft.) 0.6 1.7 3.6 5.0 6.9 9.6 9271 Twinax - Twinaxial Cable Max. Operating Voltage - UL 300 V RMS (UL AWM Style 2092) PUT-UPS AND COLORS: Item Description 9271 006100 TW PR FS PVC Put-Up (ft.) 100 Ship Weight (lbs.) 3.2 Jacket Color BLUE, LIGHT Notes 9271 0061000 TW PR FS PVC 1000 28 BLUE, LIGHT C 9271 006500 TW PR FS PVC 500 12.5 BLUE, LIGHT C 9271 006U1000 TW PR FS PVC U1000 27 BLUE, LIGHT C = CRATE REEL PUT-UP. Revision Number: 1 Revision Date: 09-09-2005 © Copyright 2006 Belden, Inc All Rights Reserved. Although Belden ("Belden") makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with the following environmental regulations: California Proposition 65 Consent Judgment For Wire & Cable Mfgs.(San Francisco Superior Court Nos. 312962 And 320342); EU RoHS (Directive 2002/95/EC, 27-Jan2003);Material manufactured prior to the compliance date may still be in stock at Belden facilities and in our Distributor's inventory. EU ELV (Directive 2000/53/EC, 18-Sept-2000); EU WEEE (Directive 2002/96/EC, 27-Jan-2003); And EU BFR (Directive 2003/11/EC, 6-Feb2003). The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden's knowledge, information and belief at the date of its publication. The information provided in the Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 73/23/EEC), as amended by directive 93/68/EEC. Page 3 of 3
9271 060500 价格&库存
很抱歉,暂时无法提供与“9271 060500”相匹配的价格&库存,您可以联系我们找货
