9451 008U500
9451 008U500
    BELDEN
    BELDEN - 9451 008U500 - Multipair Cable, Audio Control, Screened, 1 Pair, 22 AWG, 0.325 mm², 500 ft,...
9451 008U500 数据手册
9451 Paired - Single-Pair Cables For more information please call 1-800-Belden1 See Put-ups and Colors Description: 22 AWG stranded (7x30) TC conductors, polypropylene insulation, twisted pair, overall Beldfoil shield (100% coverage), 22 AWG stranded TC drain wire, PVC jacket. PHYSICAL CHARACTERISTICS: CONDUCTOR: Number of Pairs 1 Total Number of Conductors 2 AWG 22 Stranding 7x30 Conductor Material TC - Tinned Copper INSULATION: Insulation Material PP - Polypropylene Nom. Insulation Wall Thickness .008 in. Lay Length 1.75 in. Twists/ft. 6.86 Pair Color Code Chart : Number 1 Color Black & Red OUTER SHIELD: Outer Shield Material Trade Name Beldfoil® Outer Shield Type Tape Outer Shield Material Aluminum Foil-Polyester Tape Outer Shield %Coverage 100 % OUTER SHIELD DRAIN WIRE : Outer Shield Drain Wire AWG 22 Outer Shield Drain Wire Stranding 7x30 Outer Shield Drain Wire Conductor Material TC - Tinned Copper OUTER JACKET: Outer Jacket Material PVC - Polyvinyl Chloride Page 1 of 4 9451 Paired - Single-Pair Cables Outer Jacket Nominal Wall Thickness .020 in. OVERALL NOMINAL DIAMETER: Overall Nominal Diameter .135 in. MECHANICAL CHARACTERISTICS: Operating Temperature Range -20°C To +75°C UL Temperature Rating 60°C Bulk Cable Weight 13.6 lbs/1000 ft. Max. Recommended Pulling Tension 27 lbs. Min. Bend Radius (Install) 1.4 in. APPLICABLE SPECIFICATIONS AND AGENCY COMPLIANCE: APPLICABLE STANDARDS: NEC/(UL) Specification CMR CEC/C(UL) Specification CMG EU CE Mark (Y/N) Yes EU RoHS Compliant (Y/N) Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 FLAME TEST: UL Flame Test UL1666 Vertical Shaft CSA Flame Test FT4 PLENUM/NON-PLENUM: Plenum (Y/N) N ELECTRICAL CHARACTERISTICS: Nom. Characteristic Impedance 45 Ohms Nom. Inductance .17 µH/ft Nom. Capacitance Conductor to Conductor @ 1 KHz 35 pF/ft Nom. Cap. Cond. to Other Cond. & Shield @ 1 KHz 67 pF/ft Nominal Velocity of Propagation 66 % Nominal Delay 1.5 ns/ft Nom. Conductor DC Resistance @ 20 Deg. C 14.1 Ohms/1000 ft Nominal Outer Shield DC Resistance @ 20 Deg. C 14.3 Ohms/1000 ft Max. Operating Voltage - UL 300 V RMS Max. Recommended Current 2.9 Amps per conductor @ 25°C NOTES: Notes The jacket and shield are bonded so both can be removed on automatic stripping equipment. Drain wire is inside foil shield. For cross-connect use with 1814R (et. al.) Snake Cables. Page 2 of 4 9451 Paired - Single-Pair Cables PUT-UPS AND COLORS: Item Description Put-Up (ft.) 9451 0015000 2 #22 PP FS PVC FR 5000 Ship Weight (lbs.) 70 Jacket Color BROWN 9451 001U1000 2 #22 PP FS PVC FR U1000 15 BROWN 9451 0025000 2 #22 PP FS PVC FR 5000 75 RED 9451 002U1000 2 #22 PP FS PVC FR U1000 15 RED 9451 0035000 2 #22 PP FS PVC FR 5000 75 ORANGE 9451 003U1000 2 #22 PP FS PVC FR U1000 15 ORANGE 9451 0045000 2 #22 PP FS PVC FR 5000 75 YELLOW 9451 004U1000 2 #22 PP FS PVC FR U1000 15 YELLOW 9451 0065000 2 #22 PP FS PVC FR 5000 75 BLUE, LIGHT 9451 006U1000 2 #22 PP FS PVC FR U1000 15 BLUE, LIGHT 9451 0075000 2 #22 PP FS PVC FR 5000 75 VIOLET 9451 007U1000 2 #22 PP FS PVC FR U1000 15 VIOLET 9451 008500 2 #22 PP FS PVC FR 500 8 GRAY 9451 0085000 2 #22 PP FS PVC FR 5000 75 GRAY 9451 008T1000 2 #22 PP FS PVC FR T1000 18 GRAY 9451 008U1000 2 #22 PP FS PVC FR U1000 15 GRAY 9451 008U500 2 #22 PP FS PVC FR U500 8.5 GRAY 9451 0095000 2 #22 PP FS PVC FR 5000 75 WHITE 9451 009U1000 2 #22 PP FS PVC FR U1000 15 WHITE 9451 0105000 2 #22 PP FS PVC FR 5000 75 BLACK 9451 010U1000 2 #22 PP FS PVC FR U1000 15 BLACK 9451 N3U5000 2 #22 PP FS PVC FR 5000 70 GREEN, MIL 9451 N3UU1000 2 #22 PP FS PVC FR U1000 15 GREEN, MIL C = CRATE REEL PUT-UP. N = FINAL PUT-UP LENGTH MAY VARY -0% TO +10% FROM LENGTH SHOWN. Page 3 of 4 Notes CN CN CN CN CN CN CN CN CN CN 9451 Paired - Single-Pair Cables Revision Number: 1 Revision Date: 07-27-2005 © 2005 Belden Wire & Cable Company All Rights Reserved. Although Belden Electronics Division ("Belden") makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden CDT Electronics Division believes this product to be in compliance with the following environmental regulations: California Proposition 65 Consent Judgment For Wire & Cable Mfgs.(San Francisco Superior Court Nos. 312962 And 320342); EU RoHS (Directive 2002/95/EC, 27-Jan-2003);Material manufactured prior to the compliance date may still be in stock at Belden facilities and in our Distributor's inventory. EU ELV (Directive 2000/53/EC, 18-Sept-2000); EU WEEE (Directive 2002/96/EC, 27-Jan-2003); And EU BFR (Directive 2003/11/EC, 6-Feb-2003). The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden's knowledge, information and belief at the date of its publication. The information provided in the Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden CDT Electronics Division declares this product to be in compliance with EU LVD (Low Voltage Directive 73/23/EEC), as amended by directive 93/68/EEC. Page 4 of 4
9451 008U500 价格&库存
很抱歉,暂时无法提供与“9451 008U500”相匹配的价格&库存,您可以联系我们找货
