9842NH
9842NH
    BELDEN
    BELDEN - 9842NH - Multipair Cable, Computer, RS-485, LSZH, Screened, 2 Pair, 24 AWG, 1000 ft, 305 m
9842NH 数据手册
Part Number: 9842NH RS485, #24-2pr, PO, O/A Foil+Braid, LSZH Jkt, CM-LS, 120Ω Product Description Computer EIA RS-485 Cable, 24 AWG stranded (7x32) tinned copper conductors, polyethylene insulation, 2 twisted pairs, overall Beldfoil® (100% coverage) + tinned copper braid shield (90% coverage), 24 AWG stranded tinned copper drain wire, LSZH jacket Technical Specifications Product Overview Environmental Space: Indoor - Euroclass Dca Suitable Applications: Instrumentation and computer cable; For EIA RS-485 data transmission applications Physical Characteristics (Overall) Conductor AWG Stranding 24 7x32 Material No. of Pairs TC - Tinned Copper 2 Conductor Count: 4 Total Number of Pairs: 2 AWG Size: 24 Insulation Material Nominal Diameter Diameter +/- Tolerance Nominal Wall Thickness Polyethylene 1.73 mm 0.05 mm 0.02 in Color Chart Number Color Pair 1 White/Blue & Blue/White Pair 2 White/Orange & Orange/White Outer Shield Material Type Layer Material Tape 1 Aluminum / Polyester Braid 2 Tinned copper Material Trade Name Coverage [%] Thickness of Foil Drainwire Material Drainwire AWG Drainwire Construction n x D Z-fold® 100 % 9 / 23 µm Tinned copper 90 % Outer Jacket Material Material Color Nominal Diameter Nominal Wall Thickness LSZH / FRNC (UV stabilised) Chrome (like RAL 7037) 8.65 mm Construction and Dimensions Stranding Lay Length Lay Direction 1 in Left Hand Twists 12 twist/ft Cabling Filler Polypropylene (2x) (White, 2.87 mm) Electrical Characteristics 0.9 mm AWG24/7 7x32 mm Conductor DCR Nominal Conductor DCR Nominal Inner Shield DCR Nominal Outer Shield DCR 78.7 Ohm/km 7.2 Ohm/km 2.2 Ohm/1000ft Capacitance Nom. Capacitance Conductor to Conductor Nom. Capacitance Conductor to Other Conductor to Shield 42 pF/m 75.5 pF/m Impedance Frequency [MHz] Nominal Characteristic Impedance 1 120 Ohm High Frequency (Nominal/Typical) Frequency [MHz] Nom. Insertion Loss 0.6 MHz 1.97 dB/100m Delay Max. Delay Skew Nominal Delay Nominal Velocity of Propagation (VP) [%] 66 ns/100m 1.54 ns/ft ns/ft 66 % Current Element Max. Recommended Current [A] Conductor 2.1 A Voltage UL Voltage Rating Voltage Rating [V] 300V RMS 300 V Temperature Range Installation Temp Range: -15°C To +80°C UL Temp Rating: 80°C Storage Temp Range: -45°C To +80°C Operating Temp Range: -20°C To +80°C Operating Temp Range (Flexible Install): -15°C To +80°C Operating Temp Range (Fixed Install): -45°C To +80°C Mechanical Characteristics Oil Resistance: IEC 60811-404 Bulk Cable Weight: 49 lbs/1000ft Max Recommended Pulling Tension: 395 N Min Bend Radius During Installation: 86.5 mm Min Bend Radius/Minor Axis: 3.25 in Standards NEC/(UL) Specification: CMG CEC/C(UL) Specification: CMG CPR Euroclass: Dca-s2,d2,a1 CENELEC Compliance: EN 50290-2-27 Applicable Environmental and Other Programs EU Directive Compliance: EU Directive 2003/11/EC (BFR) EU CE Mark: Yes EU RoHS Compliance Date (yyyy-mm-dd): 2012-05-10 CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Suitability Suitability - Indoor: Yes Suitability - Non-Halogenated: Yes Flammability, LS0H, Toxicity Testing C(UL) Flammability: FT4 UL Flammability: UL1685 FT4 Loading ISO/IEC Flammability: IEC 60332-3-24 Amount of Halogen acc. to IEC 60754-1 & EN50267-1: Zero Part Number Plenum (Y/N): No Variants Item # Color 9842NH.02500 BLACK 9842NH.022500 BLACK 9842NH.02520 BLACK 9842NH.001000 CHROME 9842NH.00152 CHROME 9842NH.00305 CHROME 9842NH.00500 CHROME Footnote 9842NH 0601000 CHROME C 9842NH 060500 CHROME 9842NH.002500 CHROME 9842NH 0601000 CHROME C 9842NH.011000 WHITE 9842NH.01305 WHITE Footnote: C - CRATE REEL PUT-UP. © 2018 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS(Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be instock at Belden facilities and in our Distributor's inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden's knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 73/23/EEC), as amended by directive 93/68/EEC.
9842NH 价格&库存
很抱歉,暂时无法提供与“9842NH”相匹配的价格&库存,您可以联系我们找货
