9GBSY-KC50
9GBSY-KC50
    BELDEN
    BELDEN - 9GBSY-KC50 - Multicore Cable, Screened, 9 Core, 0.75 mm², 164 ft, 50 m
9GBSY-KC50 数据手册
Technical Data Sheet – Armored (SY) PVC Control Cable MachFlex 350 SY VDE Registered GalvanizedSteel Wire Braid (GSWB) --> ExcellentMechanicalProtection Applications Designed for applications which are installed in occasional flexing and fixed locations. Cable applications include precision control sensors, multi axis control machines, temperature controllers, control panels, machine cutting tools, auxiliary equipment, motor speed control, production machinery and many more. General Reference Standards • • • • • DIN VDE 0295, IEC 60228, BS 6360 DIN EN 50290-2-22, DIN VDE 0207-363-4-1 IEC 60227-5, EN 50525-2-51, VDE 0281-13 DIN VDE 0482-332-1-2, DIN EN 60332-1-2, IEC 60332-1-2 RoHS, REACH & CE Directives Construction & Performance 1. Conductor Material Stranded bare copper (DIN VDE 0295 Class 5 / IEC 60228 class 5) 2. Insulation Material & Colour PVC (polyvinyl chloride), DIN VDE 0293-1 (colour) A) All black colour with number coding = without protective earth conductor. OR B) Black colour with number coding and 1 green & yellow colour conductor = with protective earth conductor. 3. Braid Shield Material GSWB (Galvanized Steel Wire Braid) 4. Jacket / Sheath Material PVC (polyvinyl chloride) 5. Flame Retardancy VDE 0482-332-1-2, DIN EN 60332-1-2, IEC 60332-1-2 6. Voltage Rating (Uo / U) 300 / 500 V 7. Oil Resistant DIN EN 50290-2-22 (TM54) 1 © 2014 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Technical Data Sheet – Armored (SY) PVC Control Cable 8. Temperature Range 9. Bending Radius 10. Other Properties -30°C TO +70°C (Occasional movement) -40°C TO +80°C (Fixed installation) 20 x OD (Occasional movement) 6 x OD (Fixed installation) Good UV resistance, chemical resistance & flexibility TABLE A Part Code Cable Description No. Of Cores Nom. Conductor Size (mm²) Nom. Cable Diameter (mm) Nom. Cable Weight (kg/km) 2XASY 2 X0.5 2 0.5 7.1 55 3XASY 3 X0.5 3 0.5 7.5 79 3GASY 3 G0.5 3 0.5 7.5 79 4XASY 4 X0.5 4 0.5 8.0 92 4GASY 4 G0.5 4 0.5 8.0 92 5XASY 5 X0.5 5 0.5 8.5 106 5GASY 5 G0.5 5 0.5 8.5 106 7XASY 7 X0.5 7 0.5 9.1 124 7GASY 7 G0.5 7 0.5 9.1 124 9XASY 9 X0.5 9 0.5 10.7 158 9GASY 9 G0.5 9 0.5 10.7 158 10XASY 10 X0.5 10 0.5 11.1 173 10GASY 10 G0.5 10 0.5 11.1 173 12XASY 12 X0.5 12 0.5 11.4 190 12GASY 12 G0.5 12 0.5 11.4 190 14XASY 14 X0.5 14 0.5 11.9 210 14GASY 14 G0.5 14 0.5 11.9 210 16XASY 16 X0.5 16 0.5 12.4 232 16GASY 16 G0.5 16 0.5 12.4 232 18XASY 18 X0.5 18 0.5 13.0 256 18GASY 18 G0.5 18 0.5 13.0 256 20XASY 20 X0.5 20 0.5 13.9 288 20GASY 20 G0.5 20 0.5 13.9 288 2XBSY 2 X0.75 2 0.75 7.7 81 3XBSY 3 X0.75 3 0.75 8.0 94 3GBSY 3 G0.75 3 0.75 8.0 94 2 © 2014 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Technical Data Sheet – Armored (SY) PVC Control Cable 4XBSY 4 X0.75 4 0.75 8.6 111 4GBSY 4 G0.75 4 0.75 8.6 111 5XBSY 5 X0.75 5 0.75 9.2 129 5GBSY 5 G0.75 5 0.75 9.2 129 7XBSY 7 X0.75 7 0.75 9.9 154 7GBSY 7 G0.75 7 0.75 9.9 154 9XBSY 9 X0.75 9 0.75 11.6 198 9GBSY 9 G0.75 9 0.75 11.6 198 10XBSY 10 X0.75 10 0.75 12.1 216 10GBSY 10 G0.75 10 0.75 12.1 216 12XBSY 12 X0.75 12 0.75 12.4 239 12GBSY 12 G0.75 12 0.75 12.4 239 14XBSY 14 X0.75 14 0.75 13.0 266 14GBSY 14 G0.75 14 0.75 13.0 266 16XBSY 16 X0.75 16 0.75 13.8 305 16GBSY 16 G0.75 16 0.75 13.8 305 18XBSY 18 X0.75 18 0.75 14.5 337 18GBSY 18 G0.75 18 0.75 14.5 337 20XBSY 20 X0.75 20 0.75 15.2 365 20GBSY 20 G0.75 20 0.75 15.2 365 Part Code Cable Description No. Of Cores Nom. Conductor Size (mm²) Nom. Cable Diameter (mm) Nom. Cable Weight (kg/km) 2XCSY 2 X1.0 2 1.0 8.1 93 3XCSY 3 X1.0 3 1.0 8.4 109 3GCSY 3 G1.0 3 1.0 8.4 109 4XCSY 4 X1.0 4 1.0 9.1 129 4GCSY 4 G1.0 4 1.0 9.1 129 5XCSY 5 X1.0 5 1.0 9.8 152 5GCSY 5 G1.0 5 1.0 9.8 152 7XCSY 7 X1.0 7 1.0 10.5 184 7GCSY 7 G1.0 7 1.0 10.5 184 9XCSY 9 X1.0 9 1.0 12.4 236 9GCSY 9 G1.0 9 1.0 12.4 236 10XCSY 10 X1.0 10 1.0 12.9 258 10GCSY 10 G1.0 10 1.0 12.9 258 12XCSY 12 X1.0 12 1.0 13.3 287 12GCSY 12 G1.0 12 1.0 13.3 287 14XCSY 14 X1.0 14 1.0 14.1 331 3 © 2014 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Technical Data Sheet – Armored (SY) PVC Control Cable 14GCSY 14 G1.0 14 1.0 14.1 331 16XCSY 16 X1.0 16 1.0 14.8 369 16GCSY 16 G1.0 16 1.0 14.8 369 18XCSY 18 X1.0 18 1.0 15.5 408 18GCSY 18 G1.0 18 1.0 15.5 408 20XCSY 20 X1.0 20 1.0 16.3 442 20GCSY 20 G1.0 20 1.0 16.3 442 2XDSY 2 X1.5 2 1.5 8.6 108 3XDSY 3 X1.5 3 1.5 9.0 124 3GDSY 3 G1.5 3 1.5 9.0 124 4XDSY 4 X1.5 4 1.5 9.7 153 4GDSY 4 G1.5 4 1.5 9.7 153 5XDSY 5 X1.5 5 1.5 10.5 181 5GDSY 5 G1.5 5 1.5 10.5 181 7XDSY 7 X1.5 7 1.5 11.3 215 7GDSY 7 G1.5 7 1.5 11.3 215 9XDSY 9 X1.5 9 1.5 13.4 285 9GDSY 9 G1.5 9 1.5 13.4 285 10XDSY 10 X1.5 10 1.5 14.2 321 10GDSY 10 G1.5 10 1.5 14.2 321 12XDSY 12 X1.5 12 1.5 14.6 352 12GDSY 12 G1.5 12 1.5 14.6 352 14XDSY 14 X1.5 14 1.5 15.3 403 14GDSY 14 G1.5 14 1.5 15.3 403 16XDSY 16 X1.5 16 1.5 16.0 450 16GDSY 16 G1.5 16 1.5 16.0 450 18XDSY 18 X1.5 18 1.5 16.8 499 18GDSY 18 G1.5 18 1.5 16.8 499 20XDSY 20 X1.5 20 1.5 17.7 543 20GDSY 20 G1.5 20 1.5 17.7 543 2XESY 2 X2.5 2 2.5 10.4 159 Part Code Cable Description No. Of Cores Nom. Conductor Size (mm²) Nom. Cable Diameter (mm) Nom. Cable Weight (kg/km) 3XESY 3 X2.5 3 2.5 11.0 191 3GESY 3 G2.5 3 2.5 11.0 191 4XESY 4 X2.5 4 2.5 11.9 233 4GESY 4 G2.5 4 2.5 11.9 233 5XESY 5 X2.5 5 2.5 12.9 278 4 © 2014 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Technical Data Sheet – Armored (SY) PVC Control Cable 5GESY 5 G2.5 5 2.5 12.9 278 7XESY 7 X2.5 7 2.5 14.2 353 7GESY 7 G2.5 7 2.5 14.2 353 9XESY 9 X2.5 9 2.5 17.1 459 9GESY 9 G2.5 9 2.5 17.1 459 10XESY 10 X2.5 10 2.5 17.8 505 10GESY 10 G2.5 10 2.5 17.8 505 12XESY 12 X2.5 12 2.5 18.4 568 12GESY 12 G2.5 12 2.5 18.4 568 1FXESY 14 X2.5 14 2.5 19.3 641 1FGESY 14 G2.5 14 2.5 19.3 641 1GXESY 16 X2.5 16 2.5 20.3 719 1GGESY 16 G2.5 16 2.5 20.3 719 18XESY 18 X2.5 18 2.5 21.4 801 18GESY 18 G2.5 18 2.5 21.4 801 20XESY 20 X2.5 20 2.5 22.6 873 20GESY 20 G2.5 20 2.5 22.6 873 2XFSY 2 X4 2 4 11.9 218 3XFSY 3 X4 3 4 12.6 268 3GFSY 3 G4 3 4 12.6 268 FXFSY 4 X4 4 4 13.9 341 FGFSY 4 G4 4 4 13.9 341 5XFSY 5 X4 5 4 15.1 410 5GFSY 5 G4 5 4 15.1 410 7XFSY 7 X4 7 4 16.4 514 7GFSY 7 G4 7 4 16.4 514 9XFSY 9 X4 9 4 19.9 671 9GFSY 9 G4 9 4 19.9 671 10XFSY 10 X4 10 4 20.8 740 10GFSY 10 G4 10 4 20.8 740 12XFSY 12 X4 12 4 21.5 839 12GFSY 12 G4 12 4 21.5 839 2XGSY 2 X6 2 6 14.0 308 3XGSY 3 X6 3 6 14.9 384 3GGSY 3 G6 3 6 14.9 384 FXGSY 4 X6 4 6 16.2 477 FGGSY 4 G6 4 6 16.2 477 5XGSY 5 X6 5 6 17.7 578 5GGSY 5 G6 5 6 17.7 578 5 © 2014 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Technical Data Sheet – Armored (SY) PVC Control Cable 7XGSY 7 X6 7 6 19.3 731 7GGSY 7 G6 7 6 19.3 731 9XGSY 9 X6 9 6 23.5 958 Part Code Cable Description No. Of Cores Nom. Conductor Size (mm²) Nom. Cable Diameter (mm) Nom. Cable Weight (kg/km) 9GGSY 9 G6 9 6 23.5 958 2XHSY 2 X10 2 10 17.0 456 3XHSY 3 X10 3 10 18.0 574 3GHSY 3 G10 3 10 18.0 574 4XHSY 4 X10 4 10 19.8 721 4GHSY 4 G10 4 10 19.8 721 5XHSY 5 X10 5 10 21.7 878 5GHSY 5 G10 5 10 21.7 878 7XHSY 7 X10 7 10 23.7 1119 7GHSY 7 G10 7 10 23.7 1119 9XHSY 9 X10 9 10 29.1 1473 9GHSY 9 G10 9 10 29.1 1473 2X1GSY 2 X16 2 16 20.1 666 3X1GSY 3 X16 3 16 21.4 851 3G1GSY 3 G16 3 16 21.4 851 4X1GSY 4 X16 4 16 23.6 1077 4G1GSY 4 G16 4 16 23.6 1077 5X1GSY 5 X16 5 16 25.9 1321 5G1GSY 5 G16 5 16 25.9 1321 7X1GSY 7 X16 7 16 28.4 1700 7G1GSY 7 G16 7 16 28.4 1700 2XJSY 2 X25 2 25 24.2 985 3XJSY 3 X25 3 25 25.9 1273 3GJSY 3 G25 3 25 25.9 1273 4XJSY 4 X25 4 25 28.6 1622 4GJSY 4 G25 4 25 28.6 1622 5XJSY 5 X25 5 25 31.2 1982 5GJSY 5 G25 5 25 31.2 1982 7XJSY 7 X25 7 25 33.9 2533 7GJSY 7 G25 7 25 33.9 2533 2X35SY 2 X35 2 35 27.6 1268 3X35SY 3 X35 3 35 29.5 1644 3G35SY 3 G35 3 35 29.5 1644 4X35SY 4 X35 4 35 32.2 2072 6 © 2014 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Technical Data Sheet – Armored (SY) PVC Control Cable 4G35SY 4 G35 4 35 32.2 2072 Sheath / Jacket Colour 1) 2) 3) 4) 5) Colour Grey (RAL 7001) Transparent* Black Blue Orange 003 6) Violet Colour Code G8U 368 010 006 007 * Transparent jacket colour by default will have a Grey (RAL 7001) inner jacket colour. For all other colours the inner and outer jacket colour will be the same. Special colours can also be provided upon request. Packaging *Belden can offer these cables with various packing options like coiled, plastic or wooden reels. This will be decided at the discretion of Belden based on the cable design and structure. Put-up Length Putup Length 1) 50 Meters 2) 100 Meters 3) 200 Meters* 4) 300 Meters* Putup Length Code 050M 100M 200M 300M *Applicable only for certain part codes, please check with Belden for more information. Stock Code Selection Procedure: 5 X 2 . 5 S Y Select the part code from Table A G 8 U Select the sheath / jacket colour code 2 0 0 M Select the putup length code 7 © 2014 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Technical Data Sheet – Armored (SY) PVC Control Cable 5 X 2 . 5 S Y G 8 U 2 0 0 M Cable Stock Code = 5X2.5SY G8U200M 8 © 2014 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale.
9GBSY-KC50 价格&库存
很抱歉,暂时无法提供与“9GBSY-KC50”相匹配的价格&库存,您可以联系我们找货
