9L28050-008-H100
9L28050-008-H100
    BELDEN
    9L28050-008-H100
9L28050-008-H100 数据手册
Part Number: 9L28050 Flat Gray Ribbon Cable 9L280 Series, #28-50c, .050" Pitch Product Description Belden .050" pitch gray ribbon cable was designed for general purpose electronic interconnect applications. The cable provides reliable mass-termination to standard IDC connectors. Technical Specifications Physical Characteristics (Overall) Conductor AWG 28 Material Construction n x D No. of Conductors TC - Tinned Copper Stranded 50 Conductor Count: 50 AWG Size: 28 Insulation Material Nominal Wall Thickness PVC - Polyvinyl Chloride 0.01 in Color Chart Number Color Gray 3 Outer Shield Material Material Unshielded Outer Jacket Material Nominal Wall Thickness 0.035 in Construction and Dimensions Cond Spacing Center-Center: .050 in Cabling Lay Length Twists 3 in 3 twist/ft OuterJacket1, Nominal Width: 2.50 in Electrical Characteristics Conductor DCR Max. DCR Unbalance Nominal Conductor DCR 3% 68.2 Ohm/1000ft Capacitance Element Nom. Capacitance Conductor to Conductor @ 1 kHz (GSG) 18 pF/ft @ 1 MHz (GS) 10 pF/ft @ 1 MHz (GSG) 15 pF/ft Inductance Element Nominal Inductance @ 1 MHz (GS) 0.29 µH/ft @ 1 MHz (GSG) 0.2 µH/ft Impedance Nominal Characteristic Impedance Nominal Characteristic Impedance Description 150 Ohm (GS) 105 Ohm (GSG) High Frequency (Nominal/Typical) Frequency [MHz] Nom. Insertion Loss 10 MHz 2.8 dB/100ft 20 MHz 4.8 dB/100ft 30 MHz 6.5 dB/100ft 40 MHz 8.3 dB/100ft 50 MHz 9.8 dB/100ft 60 MHz 12 dB/100ft 70 MHz 13 dB/100ft 80 MHz 14 dB/100ft 90 MHz 15.8 dB/100ft 100 MHz 17 dB/100ft Delay Nominal Delay Nominal Velocity of Propagation (VP) [%] 1.4 ns/ft 72 % Unbalanced Crosstalk Element Typical Unbalanced NEXT % Typical Unbalanced FEXT % Typical Cross Talk Pulse Rise Time (ns) 10 ft. sample length 4.8 MHz 7 MHz 3 MHz 10 ft. sample length 3.5 MHz 4.7 MHz 5 MHz 10 ft. sample length 3 MHz 3 MHz 7 MHz High Freq Frequency [MHz] 10 MHz 20 MHz 30 MHz 40 MHz 50 MHz 60 MHz 70 MHz 80 MHz 90 MHz 100 MHz Current Max. Recommended Current [A] per conductor @ 20°C : 1 A Voltage Dielectric Withstand Voltage UL Voltage Rating 2000 V RMS 300 V RMS Temperature Range Operating Temp Range: -40°C To +105°C Mechanical Characteristics Bulk Cable Weight: 65 lbs/1000ft Standards UL Rating: 105°C, 300 V RMS, VW-1 UL AWM Style: 2651 CSA Rating: 105°C, 300 V RMS, FT1 CSA AWM Specification: I A 105°C 300V FT1 Applicable Environmental and Other Programs EU Directive 2000/53/EC (ELV): Yes EU Directive 2003/96/EC (BFR): Yes EU Directive 2011/65/EU (ROHS II): Yes EU Directive 2012/19/EU (WEEE): Yes EU Directive 2015/863/EU: Yes EU Directive Compliance: EU Directive 2003/11/EC (BFR) EU CE Mark: Yes EU RoHS Compliance Date (yyyy-mm-dd): 2005-07-01 CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Suitability Suitability - Indoor: Yes Flammability, LS0H, Toxicity Testing UL Flammability: VW-1 CSA Flammability: FT1 Part Number Plenum (Y/N): No Variants Item # Color 9L28050 008H100 GRAY Product Notes Notes: GS=Ground-Signal Mode; GSG=Ground-Signal-Ground Mode © 2018 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS(Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be instock at Belden facilities and in our Distributor's inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden's knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 73/23/EEC), as amended by directive 93/68/EEC.
9L28050-008-H100 价格&库存
很抱歉,暂时无法提供与“9L28050-008-H100”相匹配的价格&库存,您可以联系我们找货
