9L28310 010100
9L28310 010100
    BELDEN
    CBL RBIN 10COND 28AWG
9L28310 010100 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9L28310 Flat - Shielded Jacketed 9L283XX Series For more Information please call 1-800-Belden1 General Description: The shielded jacketed 9L283XX series provides shielding from external electrical interference and allows for greater flexibility, ease of termination, while providing exterior protection from the environment. Physical Characteristics (Overall) Conductor AWG: # Conductors AWG Stranding Conductor Material 10 28 7x36 TC - Tinned Copper Total Number of Conductors: 10 Conductor Spacing Center to Center: .050 +/- .002 Conductor Spacing Outside Center to Outside Center: .45 +/- .008 Insulation Insulation Material: Insulation Material Wall Thickness (in.) PVC - Polyvinyl Chloride .010 Insulation Resistance: >10, 000 Megaohms Outer Shield Outer Shield Material: Outer Shield Trade Name Type Outer Shield Material Beldfoil® Coverage (%) Tape Aluminum Foil-Polyester Tape (Foil Side In) 100.000 Outer Shield Drain Wire AWG: AWG Stranding Drain Wire Conductor Material 2-28 7x36 TC - Tinned Copper Outer Jacket Outer Jacket Material: Outer Jacket Material Nom. Wall Thickness (in.) PVC - Polyvinyl Chloride .038 Overall Cable Overall Nominal Thickness: .115 +/- .015 Overall Nominal Width: .570 +/- .035 Mechanical Characteristics (Overall) Operating Temperature Range: -20°C To +105°C Bulk Cable Weight: 47 lbs/1000 ft. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs UL Rating: UL AWM Style 2651, 20081 CSA Specification: AWM II A 105°C 300 V CSA Rating: 105°C, 300 V RMS, FT1 EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 10/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes Page 1 of 3 09-11-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9L28310 Flat - Shielded Jacketed 9L283XX Series CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Flame Test UL Flame Test: VW-1 CSA Flame Test: FT1 Plenum/Non-Plenum Plenum (Y/N): No Surface Printing (Overall) Surface Printing: BELDEN-T 28 AWG CSA AWM II A 105°C 300 V FT-1 LL7874 (UL LOGO) AWM STYLE 20081 VW-1 E12683 Electrical Characteristics (Overall) Nom. Characteristic Impedance: Description Impedance (Ohm) (GSG) with shield grounded 45 Nom. Inductance: Description Inductance (µH/ft) @ 1 MHz (GSG) with shield grounded .11 Nom. Capacitance Conductor to Conductor: Description Capacitance (pF/ft) @ 1 kHz (GSG) with shield grounded 70 @ 1 MHz (GSG) with shield grounded 50 Nominal Velocity of Propagation: Description VP (%) 60 Nominal Delay: Delay (ns/ft) 1.7 NS/FT. (GSG) with shield grounded Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 68.2 OHMS/1000 FT. MAX. Nom. Attenuation: Description Freq. (MHz) Attenuation (dB/100 ft.) (GSG) with shield grounded 10 6 (GSG) with shield grounded 20 9.5 (GSG) with shield grounded 30 12.5 (GSG) with shield grounded 40 14.9 (GSG) with shield grounded 50 17.2 (GSG) with shield grounded 60 19 (GSG) with shield grounded 70 21.5 (GSG) with shield grounded 80 23 (GSG) with shield grounded 90 24.5 (GSG) with shield grounded 100 26 Max. Operating Voltage - UL: Voltage 300 V RMS Max. Recommended Current: Current 1 Amp per conductor @ 20°C Typical Unbalanced Crosstalk: Description Pulse Rise Time (NS) (MHz) Near End % (MHz) Far End % (MHz) 10 ft. sample length with ground connected to shield 3 1.5 2 10 ft. sample length with ground connected to shield 5 .9 1.5 10 ft. sample length with ground connected to shield 7 .7 1.2 Notes (Overall) Notes: GSG=Ground-Signal-Ground Mode Polarity Identification (Overall) Polarity Identification: RED POLARITY STRIPE ON #1 CONDUCTOR Page 2 of 3 09-11-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9L28310 Flat - Shielded Jacketed 9L283XX Series Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 9L28310 010100 100 FT 5.200 LB BLACK E 10 #28 PVC FS PVC RIBBON Notes: E = MAY CONTAIN MORE THAN 1 PIECE. MINIMUM LENGTH OF ANY ONE PIECE IS 25' Revision Number: 3 Revision Date: 11-08-2012 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 3 of 3 09-11-2017
9L28310 010100 价格&库存
很抱歉,暂时无法提供与“9L28310 010100”相匹配的价格&库存,您可以联系我们找货
