AX100650
AX100650
    BELDEN
    Module
    EZ-MDVO UTP MODULE, CAT5E,
AX100650 数据手册
Part Number: EZ-MDVO JACKS EZ-MDVO Modular Jack Product Description EZ-MDVO Jacks are available in several colors and wiring schemes. Technical Specifications Product Overview Environmental Space: Indoor Suitable Applications: IBDN System 1200, TIA Category 5e, ISO Class D, 1000BASE-T Physical Characteristics (Overall) Height: 0.71 in Width: 0.75 in Depth: 1.25 in Wiring Scheme: T568A/B Packaging: Individually packaged in a plastic bag. Standard pack of 50 units. Weight: 0.013 lbs Connectors Materials Description Material Type Front Connection Copper Alloy with 50 µ inch Gold over Nickel Lead Frame Rear Connection Copper Alloy with Nickel Plating Connector Body IDC Plastic - UL940V-0 Electrical Characteristics Dielectric Strength: 1,000 V RMS @ 60 Hz for 1 minute Current Rating: 1.500 A Insulation Resistance: 500 M-Ohm Minimum Max Contact Resistance: 20 mOhm Termination Resistance: 2.5 mOhm Temperature Range Installation Temp Range: -10°C To +60°C Storage Temp Range: -40°C To +70°C Operating Temp Range: -10°C To +60°C Mechanical Characteristics Footprint/Type: MDVO Plug /Jack Compatibility: RJ45, RJ11 Termination Front Connection: Mated Connection Termination Front Connection Durability: 1,000 cycles Termination Rear Connection: Gas Tight IDC Connection Termination Rear Connection Durability: 20 terminations Connector/Hardware Retention: 20 lbs Plug/Connector Retention: 11.250 lbs Termination Interface Durabilities 1,000 cycles Dimensions (WxHxD) Width Height Depth 0.75 0.71 1.25 Standards Data Category: Category 5e Telecommunications Standards: Category 5e - TIA 568.C.2, Category 5 - ISO/IEC 11801:2002 Ed.2 Other Standards: FCC Part 68, Subpart F, IEC 60603-7 Applicable Environmental and Other Programs EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (yyyy-mm-dd): 2006/01/01 MII Order #39 (China RoHS): EUP 50 Suitability Suitability - Indoor: Yes Flammability, LS0H, Toxicity Testing Safety Listing: ACA, c(UL)us Listed Part Number Related Parts: Compatible with Interface and MDVO Style Faceplates, Adapters, Boxes and Patch Panels Variants Item # Color Packaging Wiring Scheme AX100646 Almond Single Pack Category 5E AX100578 Almond Single Pack Category 5E AX100589 Almond Single Pack USOC AX100172 Almond Single Pack USOC AX100648 Black Single Pack Category 5E AX100580 Black Single Pack Category 5E AX100591 Black Single Pack USOC AX100174 Black Single Pack USOC AX100645 Gray Single Pack Category 5E AX100577 Gray Single Pack Category 5E AX100588 Gray Single Pack USOC AX100171 Gray Single Pack USOC AX100653 TIA Blue Single Pack Category 5E AX100585 TIA Blue Single Pack Category 5E AX100596 TIA Blue Single Pack USOC AX100179 TIA Blue Single Pack USOC AX100655 TIA Brown Single Pack Category 5E AX100587 TIA Brown Single Pack Category 5E AX100598 TIA Brown Single Pack USOC AX100181 TIA Brown Single Pack USOC AX100652 TIA Green Single Pack Category 5E AX100584 TIA Green Single Pack Category 5E AX100595 TIA Green Single Pack USOC AX100178 TIA Green Single Pack USOC AX100649 TIA Orange Single Pack Category 5E AX100581 TIA Orange Single Pack Category 5E AX100592 TIA Orange Single Pack USOC AX100175 TIA Orange Single Pack USOC AX100654 TIA Purple Single Pack Category 5E AX100586 TIA Purple Single Pack Category 5E AX100597 TIA Purple Single Pack USOC AX100180 TIA Purple Single Pack USOC AX100650 TIA Red Single Pack Category 5E AX100582 TIA Red Single Pack Category 5E AX100593 TIA Red Single Pack USOC AX100176 TIA Red Single Pack USOC AX100651 TIA Yellow Single Pack Category 5E AX100583 TIA Yellow Single Pack Category 5E AX100594 TIA Yellow Single Pack USOC AX100177 TIA Yellow Single Pack USOC AX100647 White Single Pack Category 5E AX100579 White Single Pack Category 5E AX100590 White Single Pack USOC AX100173 White Single Pack USOC Product Notes Included Parts: Center Stuffercap Coded A/B Notes: Please See Installation Guide PX102753 © 2019 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with all applicable environmental programs as listed in the data sheet. The information provided is correct to the best of Belden's knowledge, information and belief at the date of its publication. This information is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. The Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product.
AX100650 价格&库存
很抱歉,暂时无法提供与“AX100650”相匹配的价格&库存,您可以联系我们找货
