AX101533
AX101533
    BELDEN
    LFLEX BIX/GIGABIX, WHITE ,
AX101533 数据手册
LabelFlex Labeling System Product Bulletin PB00175 The LabelFlex solution is aimed at simplifying network management. Using the labeling system (software and label types), you can rapidly produce quality, application-specific labels for most Belden products in a fraction of the time needed for traditional methods. Download your software here www.belden.com/labelflex BENEFITS F E AT U R E S • • • • • Full graphical browser Instructional videos Automatic web updates Print full-color background on the labels Fully upgraded label workshop (with prefix and suffix on sequence tool) • Copy and paste from other Windows applications • FREE download from Belden website • New label templates added: - FX ECX Patch Panels - REVConnect Preloaded Patch Panels • Wrap-around label options • Optical fiber flag labels • Tie-on cable labels for industrial applications • Wider selection of outlet/socket/equipment labels Copper and Fiber Patch Panel Labels Description Belden Part Number REVConnect Patch Panels 64 labels per sheet, 10 sheets per pack, white AX107527 KeyConnect Patch Panels 24 labels per sheet, 5 sheets per pack, white AX102299 KeyConnect Ultra-High-Density Patch Panels 24 labels per sheet, 5 sheets per pack, white AX103275 AngleFlex Patch Panels and 10GX IDC Patch Panels 180 labels per sheet, 5 sheets per pack, white AX103257 HD-Series Patch Panels 18 labels per sheet, 5 sheets per pack, white AX101554 28 labels per sheet, 5 sheets per pack, white AX103265 Flex Patch Panels 28 labels per sheet, 5 sheets per pack, white AX101551 LabelFlex for ECX Patch Panels 4 labels per sheet, 10 sheets per pack, white 1 Our End-to-End Expertise Your End-to-End Solution ECX-LBF-PK10 Ordering Information Copper and Fiber Cable Labels Description Belden Part Number Fiber Flag Labels 60 labels per sheet, 10 sheets per pack, print area 0.39x0.79 in., white AX107692 24 labels per sheet, 10 sheets per pack, print area 0.39x0.79 in., white AX107693 42 labels per sheet, 10 sheets per pack, print area 1.18x0.39 in., white AX107721 Cable Labels 48 labels per sheet, 25 sheets per pack, cable OD 0.24 in. Print Area 0.98x0.47 in., white AX101555 24 labels per sheet, 25 sheets per pack, cable OD 0.51 in. Print Area 0.98x0.78 in., white AX101556 72 labels per sheet, 25 sheets per pack, cable OD 0.20 in. Print Area 0.98x0.32 in., white AX107694 48 labels per sheet, 25 sheets per pack, cable OD 0.24 in. Print Area 0.98x0.75 in., white AX107695 24 labels per sheet, 25 sheets per pack, cable OD 0.24 in. Print Area 1.97x0.75 in., white AX107696 24 labels per sheet, 25 sheets per pack, cable OD 0.67 in. Print Area 0.98x0.98 in., white AX107697 8 labels per sheet, 25 sheets per pack, cable OD 0.79 in. Print Area 1.97x0.79 in., white AX107698 16 labels per sheet, 25 sheets per pack, cable OD 0.79 in. Print Area 0.98x0.79 in., white AX107699 32 labels per sheet, 25 sheets per pack, cable OD 0.39 in. Print Area 0.98x0.75 in., white AX107719 16 labels per sheet, 25 sheets per pack, cable OD 0.39 in. Print Area 1.97x0.75 in., white AX107720 Cable Tie-On Labels 48 labels per sheet, 10 sheets per pack, cable OD 0.39 in. Print Area 2.36x0.51 in., white AX107700 48 labels per sheet, 10 sheets per pack, cable OD 0.39 in. Print Area 2.36x0.51 in., yellow AX107701 32 labels per sheet, 10 sheets per pack, cable OD 0.39 in. Print Area 3.54x0.51 in., white AX107702 32 labels per sheet, 10 sheets per pack, cable OD 0.39 in. Print Area 3.54x0.51 in., yellow AX107703 22 labels per sheet, 10 sheets per pack, cable OD 0.39 in. Print Area 3.54x0.79 in., white AX107704 22 labels per sheet, 10 sheets per pack, cable OD 0.39 in. Print Area 3.54x0.79 in., yellow AX107705 Workstation Outlet Labels Description Belden Part Number KeyConnect/Interface Workstation Outlets AX101552 80 labels per sheet, 5 sheets per pack, white MediaFlex Workstation Outlets AX101821 30 labels per sheet, 10 sheets per pack, white Workstation Modules AX101553 450 labels per sheet, 5 sheets per pack, white Miscellaneous Labels Description Belden Part Number Cabinet Labels 96 labels per sheet, 10 sheets per pack, label 1.89x0.35 in, white AX107711 144 labels per sheet, 10 sheets per pack, label 0.94x0.47 in, white AX107712 30 labels per sheet, 10 sheets per pack, label 2.16x0.87 in, white AX107713 BIX, GigaBIX and 110 Cross-Connect Labels Description Belden Part Number Gray White Orange Red Yellow Green Blue Purple Brown Silver BIX and GigaBix Labels 15 labels per sheet, AX101532 AX101533 AX101534 AX101535 AX101536 AX101537 AX101538 AX101539 AX101540 AX101541 5 sheets per pack BIX Modular Jack Connector Labels 28 labels per sheet, AX101542 AX101543 AX101544 AX101545 AX101546 AX101547 AX101548 AX101549 AX101550 AX101584 5 sheets per pack 110 Cross-Connect Labels 18 labels per sheet, AX101557 AX101558 AX101559 AX101560 AX101561 AX101562 AX101563 AX101564 AX101565 5 sheets per pack © Copyright 2018, Belden Inc. LabelFlex Labeling System Product Bulletin_PB00175_ECOS_BDC_1218_ENG 2 Belden Technical 1.800.BELDEN.1 ww.belden.com BeldenSupport Technical Support 1.800.BELDEN.1 www.belden.com
AX101533 价格&库存
很抱歉,暂时无法提供与“AX101533”相匹配的价格&库存,您可以联系我们找货
AX101533
    • 1+802.795831+100.46141
