C3GESY-K200
C3GESY-K200
    BELDEN
    BELDEN - C3GESY-K200 - Multicore Cable, MachFlex 375 SY Control, Screened, 3 Core, 2.5 mm², 656 ft, ...
C3GESY-K200 数据手册
      Technical Data Sheet – Armored (SY) PVC Control Cable MachFlex 375 SY    Galvanized Steel Wire Braid (GSWB) ‐‐> Excellent Mechanical Protection  Applications  Designed for applications which are installed in occasional flexing and fixed locations. Cable applications include  precision control sensors, multi axis control machines, temperature controllers, control panels, machine cutting  tools, auxiliary equipment, motor speed control, production machinery and many more.  General Reference Standards   DIN VDE 0295, IEC 60228, BS 6360  DIN EN 50290‐2‐22, DIN VDE 0207‐363‐4‐1  IEC 60227‐5, EN 50525‐2‐51, VDE 0281‐13  DIN VDE 0482‐332‐1‐2, DIN EN 60332‐1‐2, IEC 60332‐1‐2  RoHS, REACH & CE Directives Construction & Performance  1.  Conductor Material  Stranded bare copper (DIN VDE 0295 Class 5 / IEC 60228 class 5)  2.  Insulation Material & Colour  PVC (polyvinyl  chloride), VDE 0293‐308 (colour) up to  5 cores: colour‐coded according to VDE 0293‐308,  From 6 cores : Belden MachFlex colour code   A) G = with GN‐YE protective conductor   OR B) X = without protective earth conductor 3. GSWB (Galvanized Steel Wire Braid)  Braid Shield Material 4.  Jacket / Sheath Material  PVC (polyvinyl  chloride)  5.  Flame Retardancy  VDE 0482‐332‐1‐2, DIN EN 60332‐1‐2, IEC 60332‐1‐2  6. Voltage Rating (Uo / U) Up to 1.5 mm²: 300 / 500 V  From 2.5 mm²: 450 / 750 V  7. Oil Resistant DIN EN 50290‐2‐22 (TM54)  8. Temperature Range ‐5°C TO +70°C (Occasional movement)  ‐40°C TO +80°C (Fixed installation)  9. Bending Radius 20 x OD (Occasional movement)  6 x OD (Fixed installation)  10.  Other Properties  Good UV resistance, chemical resistance & flexibility  1 © 2014 Belden, Inc  All Rights Reserved.  Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and  specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages  (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in  connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale.          Technical Data Sheet – Armored (SY) PVC Control Cable       Part Code  C2X0.5SY  C3X0.5SY  C3G0.5SY  C4X0.5SY  C4G0.5SY  C5X0.5SY  C5G0.5SY  C7X0.5SY  C7G0.5SY  C9X0.5SY  C9G0.5SY  C10X0.5SY  C10G0.5SY  C12X0.5SY  C12G0.5SY  C14X0.5SY  C14G0.5SY  C16X0.5SY  C16G0.5SY  C18X0.5SY  C18G0.5SY  C20X0.5SY  C20G0.5SY  C2X0.75SY  C3X0.75SY  C3G0.75SY  C4X0.75SY  C4G0.75SY  C5X0.75SY  C5G0.75SY  C7X0.75SY  C7G0.75SY  C9X0.75SY  C9G0.75SY  C10X0.75SY  C10G0.75SY  C12X0.75SY  C12G0.75SY  C14X0.75SY  C14G0.75SY  C16X0.75SY  C16G0.75SY  C18X0.75SY  C18G0.75SY  C20X0.75SY  C20G0.75SY        Cable  Description  2 X0.5  3 X0.5  3 G0.5  4 X0.5  4 G0.5  5 X0.5  5 G0.5  7 X0.5  7 G0.5  9 X0.5  9 G0.5  10 X0.5  10 G0.5  12 X0.5  12 G0.5  14 X0.5  14 G0.5  16 X0.5  16 G0.5  18 X0.5  18 G0.5  20 X0.5  20 G0.5  2 X0.75  3 X0.75  3 G0.75  4 X0.75  4 G0.75  5 X0.75  5 G0.75  7 X0.75  7 G0.75  9 X0.75  9 G0.75  10 X0.75  10 G0.75  12 X0.75  12 G0.75  14 X0.75  14 G0.75  16 X0.75  16 G0.75  18 X0.75  18 G0.75  20 X0.75  20 G0.75    TABLE A    No. Of  Cores  Nom. Conductor  Size (mm²)  Nom. Cable  Diameter (mm)  Nom. Cable Weight  (kg/km)  2  3  3  4  4  5  5  7  7  9  9  10  10  12  12  14  14  16  16  18  18  20  20  2  3  3  4  4  5  5  7  7  9  9  10  10  12  12  14  14  16  16  18  18  20  20  0.5  0.5  0.5  0.5  0.5  0.5  0.5  0.5  0.5  0.5  0.5  0.5  0.5  0.5  0.5  0.5  0.5  0.5  0.5  0.5  0.5  0.5  0.5  0.75  0.75  0.75  0.75  0.75  0.75  0.75  0.75  0.75  0.75  0.75  0.75  0.75  0.75  0.75  0.75  0.75  0.75  0.75  0.75  0.75  0.75  0.75  7.4  7.7  7.7  8.3  8.3  8.8  8.8  9.5  9.5  11.1  11.1  11.5  11.5  11.9  11.9  12.4  12.4  13.0  13.0  13.8  13.8  14.5  14.5  7.9  8.3  8.3  8.9  8.9  9.5  9.5  10.2  10.2  12.1  12.1  12.5  12.5  12.9  12.9  13.7  13.7  14.4  14.4  15.1  15.1  15.9  15.9  78  87  87  101  101  116  116  137  137  174  174  191  191  209  209  231  231  256  256  291  291  317  317  89  102  102  120  120  140  140  168  168  215  215  234  234  259  259  300  300  331  331  366  366  401  401  2 © 2014 Belden, Inc  All Rights Reserved.  Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and  specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages  (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in  connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale.          Technical Data Sheet – Armored (SY) PVC Control Cable   Part Code  Cable  Description  No. Of  Cores  Nom. Conductor  Size (mm²)  Nom. Cable  Diameter (mm)  Nom. Cable Weight  (kg/km)  C2X1.0SY  C3X1.0SY  C3G1.0SY  C4X1.0SY  C4G1.0SY  C5X1.0SY  C5G1.0SY  C7X1.0SY  C7G1.0SY  C9X1.0SY  C9G1.0SY  C10X1.0SY  C10G1.0SY  C12X1.0SY  C12G1.0SY  C14X1.0SY  C14G1.0SY  C16X1.0SY  C16G1.0SY  C18X1.0SY  C18G1.0SY  C20X1.0SY  C20G1.0SY  C2X1.5SY  C3X1.5SY  C3G1.5SY  C4X1.5SY  C4G1.5SY  C5X1.5SY  C5G1.5SY  C7X1.5SY  C7G1.5SY  C9X1.5SY  C9G1.5SY  C10X1.5SY  C10G1.5SY  C12X1.5SY  C12G1.5SY  C14X1.5SY  C14G1.5SY  C16X1.5SY  C16G1.5SY  C18X1.5SY  C18G1.5SY  C20X1.5SY  C20G1.5SY  C2X2.5SY  2 X1.0  3 X1.0  3 G1.0  4 X1.0  4 G1.0  5 X1.0  5 G1.0  7 X1.0  7 G1.0  9 X1.0  9 G1.0  10 X1.0  10 G1.0  12 X1.0  12 G1.0  14 X1.0  14 G1.0  16 X1.0  16 G1.0  18 X1.0  18 G1.0  20 X1.0  20 G1.0  2 X1.5  3 X1.5  3 G1.5  4 X1.5  4 G1.5  5 X1.5  5 G1.5  7 X1.5  7 G1.5  9 X1.5  9 G1.5  10 X1.5  10 G1.5  12 X1.5  12 G1.5  14 X1.5  14 G1.5  16 X1.5  16 G1.5  18 X1.5  18 G1.5  20 X1.5  20 G1.5  2 X2.5  2  3  3  4  4  5  5  7  7  9  9  10  10  12  12  14  14  16  16  18  18  20  20  2  3  3  4  4  5  5  7  7  9  9  10  10  12  12  14  14  16  16  18  18  20  20  2  1.0  1.0  1.0  1.0  1.0  1.0  1.0  1.0  1.0  1.0  1.0  1.0  1.0  1.0  1.0  1.0  1.0  1.0  1.0  1.0  1.0  1.0  1.0  1.5  1.5  1.5  1.5  1.5  1.5  1.5  1.5  1.5  1.5  1.5  1.5  1.5  1.5  1.5  1.5  1.5  1.5  1.5  1.5  1.5  1.5  1.5  2.5  8.3  8.7  8.7  9.4  9.4  10.1  10.1  10.8  10.8  12.9  12.9  13.4  13.4  14.0  14.0  14.6  14.6  15.4  15.4  16.1  16.1  16.9  16.9  8.8  9.3  9.3  10.0  10.0  10.8  10.8  11.6  11.6  14.1  14.1  14.6  14.6  15.1  15.1  15.8  15.8  16.6  16.6  17.4  17.4  18.4  18.4  11.9  100  117  117  139  139  164  164  197  197  255  255  278  278  320  320  358  358  397  397  439  439  483  483  116  133  133  164  164  193  193  231  231  315  315  344  344  376  376  432  432  481  481  533  533  587  587  198  3 © 2014 Belden, Inc  All Rights Reserved.  Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and  specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages  (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in  connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale.          Technical Data Sheet – Armored (SY) PVC Control Cable   Part Code  Cable  Description  No. Of  Cores  Nom. Conductor  Size (mm²)  Nom. Cable  Diameter (mm)  Nom. Cable Weight  (kg/km)  C3X2.5SY  C3G2.5SY  C4X2.5SY  C4G2.5SY  C5X2.5SY  C5G2.5SY  C7X2.5SY  C7G2.5SY  C9X2.5SY  C9G2.5SY  C10X2.5SY  C10G2.5SY  C12X2.5SY  C12G2.5SY  C14X2.5SY  C14G2.5SY  C16X2.5SY  C16G2.5SY  C18X2.5SY  C18G2.5SY  C20X2.5SY  C20G2.5SY  C2X4SY  C3X4SY  C3G4SY  C4X4SY  C4G4SY  C5X4SY  C5G4SY  C7X4SY  C7G4SY  C9X4SY  C9G4SY  C10X4SY  C10G4SY  C12X4SY  C12G4SY  C2X6SY  C3X6SY  C3G6SY  C4X6SY  C4G6SY  C5X6SY  C5G6SY  C7X6SY  C7G6SY  C9X6SY  3 X2.5  3 G2.5  4 X2.5  4 G2.5  5 X2.5  5 G2.5  7 X2.5  7 G2.5  9 X2.5  9 G2.5  10 X2.5  10 G2.5  12 X2.5  12 G2.5  14 X2.5  14 G2.5  16 X2.5  16 G2.5  18 X2.5  18 G2.5  20 X2.5  20 G2.5  2 X4  3 X4  3 G4  4 X4  4 G4  5 X4  5 G4  7 X4  7 G4  9 X4  9 G4  10 X4  10 G4  12 X4  12 G4  2 X6  3 X6  3 G6  4 X6  4 G6  5 X6  5 G6  7 X6  7 G6  9 X6  3  3  4  4  5  5  7  7  9  9  10  10  12  12  14  14  16  16  18  18  20  20  2  3  3  4  4  5  5  7  7  9  9  10  10  12  12  2  3  3  4  4  5  5  7  7  9  2.5  2.5  2.5  2.5  2.5  2.5  2.5  2.5  2.5  2.5  2.5  2.5  2.5  2.5  2.5  2.5  2.5  2.5  2.5  2.5  2.5  2.5  4  4  4  4  4  4  4  4  4  4  4  4  4  4  4  6  6  6  6  6  6  6  6  6  6  12.6  12.6  13.9  13.9  15.1  15.1  16.4  16.4  19.9  19.9  20.7  20.7  21.4  21.4  22.5  22.5  23.7  23.7  25.0  25.0  26.5  26.5  13.3  14.4  14.4  15.7  15.7  17.1  17.1  18.6  18.6  22.7  22.7  23.7  23.7  24.5  24.5  15.0  15.9  15.9  17.4  17.4  19.0  19.0  20.7  20.7  25.4  238  238  300  300  358  358  439  439  574  574  633  633  709  709  803  803  897  897  1000  1000  1105  1105  263  331  331  407  407  491  491  610  610  801  801  886  886  1000  1000  346  428  428  532  532  643  643  811  811  1065  4 © 2014 Belden, Inc  All Rights Reserved.  Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and  specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages  (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in  connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale.          Technical Data Sheet – Armored (SY) PVC Control Cable   Part Code  Cable  Description  No. Of  Cores  Nom. Conductor  Size (mm²)  Nom. Cable  Diameter (mm)  Nom. Cable Weight  (kg/km)  C9G6SY  C2X10SY  C3X10SY  C3G10SY  C4X10SY  C4G10SY  C5X10SY  C5G10SY  C7X10SY  C7G10SY  C9X10SY  C9G10SY  C2X16SY  C3X16SY  C3G16SY  C4X16SY  C4G16SY  C5X16SY  C5G16SY  C7X16SY  C7G16SY  C2X25SY  C3X25SY  C3G25SY  C4X25SY  C4G25SY  C5X25SY  C5G25SY  C2X35SY  C3X35SY  C3G35SY  9 G6  2 X10  3 X10  3 G10  4 X10  4 G10  5 X10  5 G10  7 X10  7 G10  9 X10  9 G10  2 X16  3 X16  3 G16  4 X16  4 G16  5 X16  5 G16  7 X16  7 G16  2 X25  3 X25  3 G25  4 X25  4 G25  5 X25  5 G25  2 X35  3 X35  3 G35  9  2  3  3  4  4  5  5  7  7  9  9  2  3  3  4  4  5  5  7  7  2  3  3  4  4  5  5  2  3  3  6  10  10  10  10  10  10  10  10  10  10  10  16  16  16  16  16  16  16  16  16  25  25  25  25  25  25  25  35  35  35  25.4  17.4  18.6  18.6  20.4  20.4  22.3  22.3  24.4  24.4  30.0  30.0  21.5  23.0  23.0  25.3  25.3  27.9  27.9  30.5  30.5  24.2  25.9  25.9  28.6  28.6  31.2  31.2  27.6  29.5  29.5  1065  483  607  607  760  760  926  926  1177  1177  1549  1549  741  940  940  1189  1189  1458  1458  1859  1859  1001  1293  1293  1647  1647  2011  2011  1288  1670  1670        Sheath / Jacket Colour      Colour     1) Grey (RAL 7001)  2) Transparent*    3) Black      4) Blue      5) Orange     6) Violet        Colour Code    G8U    368    010    006    003    007  * Transparent jacket colour by default will have a Grey (RAL 7001) inner jacket colour. For all other colours the inner and outer jacket colour will be the same. Special colours can also be provided upon request.     5 © 2014 Belden, Inc  All Rights Reserved.  Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and  specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages  (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in  connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale.          Technical Data Sheet – Armored (SY) PVC Control Cable     Packaging    *Belden can offer these cables with various packing options like coiled, plastic or wooden reels. This  will be decided at the discretion of Belden based on the cable design and structure.         Put‐up Length    Putup Length                    Putup Length Code  1) 100 Meters                    100M  2) 200 Meters*                    200M    3) 300 Meters*                    300M  *Applicable only for certain part codes, please check with Belden for more information.        Stock Code Selection Procedure:     C   5 G   2 . 5 S Y G 5 G 2 U 1 Select the sheath / jacket color code Select the part code from Table A C 8 . 5 S Y G 8 0 0 M Select the putup length code U 1 0 0 M Cable Stock Code = C5G2.5SY G8U100M 6 © 2014 Belden, Inc  All Rights Reserved.  Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and  specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages  (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in  connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale.
C3GESY-K200 价格&库存
很抱歉,暂时无法提供与“C3GESY-K200”相匹配的价格&库存,您可以联系我们找货
