CPLCCT-SS59/11
CPLCCT-SS59/11
    BELDEN
    BELDEN - CPLCCT-SS59/11 - CABLE PRO STEEL COMPRESSION TOOL FS SERIES
CPLCCT-SS59/11 数据手册
The Industry Leader in True 360º Compression Connectors & Tooling Systems www.ppc-online.com Snap-N-Seal® ProSNS™ Compression Connectors Universal Hybrid ProSNS Compression Connectors................................................4 Plenum & CCTV ProSNS Compression Connectors................................................5 RG11 Hybrid ProSNS Compression Connectors.....................................................6 F-Conn™ Compression Connectors RGB/Mini Coax Compression Connectors...............................................................7 Right Angle Compression Connectors.....................................................................8 Double Bubble™ Compression Connectors Double Bubble Compression Connectors.............................................................. 9 Plenum & Security/ CCTV Compression Connectors............................................. 10 50 Ohm Compression Connectors......................................................................... 10 High Definition BNC Compression Connectors...................................................... 11 EX® Universal compression connector, series 6 cable EX6 Universal Compression Connectors................................................................ 11 Compression Connector Accessories Strain Relief Boots.................................................................................................. 12 Basic Connector Series Basic Compression Connector Series ................................................................... 13 Cable Pro® Tools Cable Strip Tools................................................................................................14-15 CPSNSCT-596 Compression Tool.......................................................................... 16 SNSUNI Compression Tool..................................................................................... 16 CPLCRBC-BR Double Bubble Compression Tool.................................................. 17 CPLCCT-1-S Compression Tool............................................................................. 17 CPLCCT-SLM Linear Compliant Compression Tool............................................... 18 CPLCCT-LS59/11 Compression Tool...................................................................... 18 CPLCCT-SS59/11 RG59, 6, 7, 11 Compression Tool............................................. 19 CPCAT5-PDT Punch Down Tool............................................................................. 20 CPRJ11-45 Strip/Crimp Tool.................................................................................. 20 Compression Tool and Connector Kits..............................................................21-22 Installation Tools & Accessories HDMI Cable............................................................................................................. 20 Cable Caddies........................................................................................................ 23 Cable Pro Torque Wrenches .............................................................................24-26 Cable Pro Installation Tools................................................................................27-32 Splitters................................................................................................................... 33 Compression Connector Sizing Chart............................................................... 34-35 www.ppc-online.com Quality Coaxial Connectivity Solutions PPC Belden is a global leader in end-to-end signal transmission solutions for data, video and audio applications. Our coaxial connectivity solutions products feature superior quality, high-performance compression connectors, tools and accessories for a variety of coaxial installation applications. The patented design features of our Snap-N-Seal®, Double Bubble™ and ProSNS™ connector brands provide a secure, dependable connection from start to finish. • TRUE 360º compression technology creating tools and connectors to work together as a complete, intregrated system • Connectors meet/exceed SCTE-IPC and Bellcore requirements • Connectors provides superior pullout strength • One-piece design option on connectors eliminate loose pins and sleeves • Non-blind entry sleeve and pin-guide in one-piece connectors assist with the insertion of the cable into the connector • Connectors feature internal compression rings to reduce/eliminate water migration Cable Size Connector Type Mini Coax RG59 RG59Q RG59 Plenum CCTV RG6 RG6Q RG6 Plenum CCTV Snap-N-Seal ProSNS X X X X X X X Double Bubble X X X X X X X RG7 RG11 X RG11 RG11Q Plenum X X X X PPC Customer Support 1.800.800.6652 3 Snap-N-Seal® ProSNS™ Compression Connectors www.ppc-online.com 4 Snap-N-Seal® ProSNS™ Universal Hybrid Compression Connectors INDUSTRY USE: COMMERCIAL PROFESSIONAL A/V CPLCCT-SLM SECURITY CPSNSCT-596 By combining the advanced, patented design features of F-Conn and the traditional, easy-to-use construction of Snap-N-Seal, the PPC ProSNS connectors provide the industry’s easiest to install, high-performance compression connector as part of the Snap-N-Seal family brand. PSA59/6 • Non-blind entry (disposable guide sleeve for F’s and sliding pin for RCA and BNC connectors) • Plastic sleeve is up to 50% easier to compress than all-brass connectors • Eliminates water migration through proven design features of multiple O-ring placement • Superior Ni-Tin plating yields durable finish, preventing corrosion • Clear product labeling and color-coded compression sleeves for easy product identification and re-ordering • Improved connector design offers the flexibility to be installed with most universal compression tools Part Number Cable Type Connector Description Color Band Tool Required FSNS6U RG6 Universal F Connector Green CPLCCT-SLM or CPSNSCT-596 FSNS6BNCU RG6 Universal BNC Connector Green CPLCCT-SLM or CPSNSCT-596 FSNS6RCAU RG6 Universal RCA Connector Green CPLCCT-SLM or CPSNSCT-596 FSNS59U RG59 Universal F Connector Red CPLCCT-SLM or CPSNSCT-596 FSNS59BNCU RG59 Universal BNC Connector Red CPLCCT-SLM or CPSNSCT-596 FSNS59RCAU RG59 Universal RCA Connector Red CPLCCT-SLM or CPSNSCT-596 PPC Customer Support 1.800.800.6652 www.ppc-online.com INDUSTRY USE: COMMERCIAL PROFESSIONAL A/V CPLCCT-SLM By combining the advanced, patented design features of F-Conn and the traditional, easy-to-use construction of Snap-N-Seal, the PPC ProSNS connectors provide the industry’s easiest to install, high-performance compression connector as part of the Snap-N-Seal family brand. SECURITY CPSNSCT-596 PSA59/6 Part Number Connector Description Color Band Tip Req’d Tool Req’d FSNS6PL RG6 Plenum F-type Size 1 Green LMTIP-S CPLCCT-SLM FSNS6PLQ RG6 Plenum F-type Size 2 Quad Green LMTIP-S CPLCCT-SLM FSNS6RCAPL RG6 Plenum RCA Size 1 Green LMTIP-S CPLCCT-SLM FSNS6BNCPL RG6 Plenum BNC Size 1 Green NONE CPLCCT-SLM FSNS59BNCSL RG59 Security (CCTV) BNC Red NONE CPLCCT-SLM FSNS59PL RG59 Plenum F-type Size 1 Red LMTIP-S CPLCCT-SLM FSNS59RCAPL RG59 Plenum RCA Size 1 Red LMTIP-S CPLCCT-SLM FSNS59BNCPL RG59 Plenum BNC Size 1 Red NONE CPLCCT-SLM FSNS59BNCPL3 RG59 Plenum BNC Size 3 Red NONE CPLCCT-SLM PPC Customer Support 1.800.800.6652 ProSNS™ Plenum & CCTV Compression Connectors Snap-N-Seal® ProSNS™ Plenum & CCTV Compression Connectors 5 Snap-N-Seal® ProSNS™ Hybrid RG11 Connectors www.ppc-online.com 6 Snap-N-Seal® ProSNS™ Hybrid RG11 Compression Connectors INDUSTRY USE: COMMERCIAL PROFESSIONAL A/V SECURITY CPLCCT-LS59/11 SNSUNI Efforts to improve the current design of Snap-N-Seal series 11 connectors provided PS11 Belden the opportunity to combine the patented design features of both Snap-N-Seal and F-Conn connector brands. The result is a quality, highperformance ProSNS Hybrid RG11 connector that requires low retention force to compress making installations quick and easy. • Designed utilizing an air dielectric for better performance and excellent return loss • The patented floating-pin insertion guide assists with the insertion of the cable into the connector • F-type connectors feature a patented internal O-ring at the base of the nut to facilitate a free-spinning nut • An additional O-ring placed at the base of the connector with a NiTin finish and UV resistant plastic provides a reliable, environmentally sealed product on the cable Part Number Connector Description Color Band Tool Required 716SNS1P11H 7/16” Hex Head Universal F Black CPLCCT-LS59/11 or SNSUNI 716SNS1P11HPLA 7/16” Hex Head F Connector, Plenum Grey CPLCCT-LS59/11 or SNSUNI 716SNS1P11HQ 7/16” Hex Head F Connector, Quad-Shield Only Purple CPLCCT-LS59/11 or SNSUNI SNS1P11H 9/16” Hex Head Universal F Black CPLCCT-LS59/11 or SNSUNI 90SNS1P11H 9/16” Hex Head F Connector, Right Angle Black CPLCCT-LS59/11 or SNSUNI FSNS11HBNC Universal BNC Connector Black SNSUNI FSNS11HBNCPLA BNC Connector, Plenum Grey SNSUNI FSNS11QHBNC BNC Connector, Quad-Shield Only Purple SNSUNI PPC Customer Support 1.800.800.6652 www.ppc-online.com INDUSTRY USE: COMMERCIAL PROFESSIONAL A/V CPLCCT-SLM SECURITY CPSNSCT-596 • Available in two sizes: • RG15 (22-24 AWG), purple PSA59/6 • RG1 (25-26 AWG), orange • Multi-piece connectors are for solid center wire or stranded cable • One-piece RGB connectors are for solid center conductor wire only, allowing installers to save time while retaining quality • Available in gold for one-piece or multi-piece configurations • Superior return loss numbers on all our RGB/mini coax connectors Part Number* Connector Description Color Band Tip Req’d Tool Req’d FSNS15 F, 1 Piece Solid Center Cond., RGB 22-24 AWG Purple LMTIP-S CPLCCT-SLM FSNS15BNC BNC, 1 Piece Solid Center Cond., RGB 22-24 AWG Purple NONE CPLCCT-SLM FSBNC15RGB BNC, Multi-Piece, RGB 22-24 AWG Purple NONE CPLCCT-SLM FSRCA15RGB RCA, Multi-Piece, RGB 22-24 AWG Purple LMTIP-S CPLCCT-SLM FS1BNC BNC, 1 Piece Solid Center Cond., RGB 24-26 AWG Orange NONE CPLCCT-SLM FS1RCA RCA, 1 Piece Solid Center Cond., RGB 24-26 AWG Orange LMTIP-S CPLCCT-SLM PPC Customer Support 1.800.800.6652 FS Series RGB/Mini Coax Compression Connectors F-Conn™ RGB/Mini Coaxial Compression Connectors 7 FS Series Right Angle Compression Connectors www.ppc-online.com 8 ProSNS™ Right Angle Compression Connectors INDUSTRY USE: COMMERCIAL PROFESSIONAL A/V CPLCCT-SLM SECURITY CPSNSCT-596 • Designed to allow for adequate cable bend radius PSA59/6 when space is limited • A great solution for flush mounts, TV rack mounts, plasma/LCD televisions, and dome security camera installations • Features a positive stop design to help guide the cable into the connector and prevent it from being over-compressed Part Number Connector Description Color Band Tip Req’d Tool Req’d FSNS59URA RG59 F-type Universal Right Angle Red LMTIP-RA CPLCCT-SLM FSBNC59URA RG59 BNC Universal Right Angle Red LMTIP-RA CPLCCT-SLM FSNS6URA RG6 F-type Universal Right Angle Green LMTIP-RA CPLCCT-SLM FSBNC6URA RG6 BNC Universal Right Angle Green LMTIP-RA CPLCCT-SLM PPC Customer Support 1.800.800.6652 www.ppc-online.com Double Bubble™ Compression Connectors CPLCRBC-BR The Double Bubble compression tool incorporates the dies into the design of the tool to mold the metal of the Double Bubble connector around the cable. This reduces the cost of the connector and eliminates the need for a compression sleeve for compression. PSA59/6 PS59/6/RGB • Double Bubble compression connectors are designed for structured wiring, security cameras and other exposed wiring installations • F, RCA and BNC for RG59 and RG6 cables • BNC and RCA connectors for RGB/mini coax cables Part Number Connector Description DB1BNC BNC, RGB/ Mini Coax (25-26AWG) DB59U F, RG59 Connector DB59BNCU BNC, RG59 Connector DB6U F, RG6 Connector DB6BNCU BNC, RG6 Connector Color Band Red Green - Tip Req’d Tool Req’d NONE CPLCRBC-BR LMTIP-S CPLCRBC-BR NONE CPLCRBC-BR LMTIP-S CPLCRBC-BR NONE CPLCRBC-BR PPC Customer Support 1.800.800.6652 Double Bubble™ Compression Connectors INDUSTRY USE: SECURITY COMMERCIAL LAW ENFORCEMENT CATV SATELLITE 9 www.ppc-online.com Double Bubble™ Compression Connectors Double Bubble™ Plenum and Security (CCTV) Compression Connectors INDUSTRY USE: SECURITY SATELLITE CATV CPLCRBC-BR • Custom designed plenum connectors make installations easier and provide a more accurate fit on the cable PSA59/6 • Security (SL) connectors are designed for RG59 • CCTV coaxial cables with copper braiding and solid copper center conductor in RCA and BNC Part Number Connector Description Tip Req’d Tool Req’d DB6PL2 RG6 Plenum Size 2 F-type LMTIP-S CPLCRBC-BR DB6BNCPL2 RG6 Plenum Size 2 BNC NONE CPLCRBC-BR DB59PL2/4 RG59 Plenum Size 2/4 F-type LMTIP-S CPLCRBC-BR DB59BNCPL2/4 RG59 Plenum Size 2/4 BNC NONE CPLCRBC-BR DB59BNCPL3 RG59 Plenum Size 3 BNC NONE CPLCRBC-BR DB59BNCSL RG59 Security BNC NONE CPLCRBC-BR Double Bubble™ DB58UHF 50 Ohm Compression Connectors INDUSTRY USE: SECURITY MOBILE RADIO LAW ENFORCEMENT CPLCRBC-BR • Mini-UHF Plug • Utilizes non-blind entry, one-piece design features • DB58UHF includes RBCTIP-UHF adapter tip with purchase 10 Part Number Connector Description Tip Req’d Tool Req’d DB58UHF 50 Ohm Connector RBCTIP-UHF CPLCRBC-BR DB58BNC 50 Ohm BNC Connector NONE CPLCRBC-BR PPC Customer Support 1.800.800.6652 www.ppc-online.com INDUSTRY USE: SECURITY PSA59/6 CPLCRBC-BR High Definition BNC connectors combine patented technologies with a proprietary manufacturing process to ensure the highest quality connections with superior return loss PSA59/6 Part Number Connector Description Color Band Tool Req’d DB6BNCHD RG6 Green CPLCRBC-BR DB59BNCHD RG59 Red CPLCRBC-BR DB15BNCHD RGB/ Mini Coax (22-24AWG) Purple CPLCRBC-BR DB1BNCHD RGB/ Mini Coax (25-26AWG) Orange CPLCRBC-BR EX® Universal Compression Connectors Double Bubble™ High Definition BNC Compression Connectors EX6 Universal Compression Connectors INDUSTRY USE: SATELLITE CATV PROFESSIONAL A/V COMMERCIAL CPLCCT-SLM PSA59/6 Installers are faced with the problem of identifying old unmarked 60% through Quad Shield Series 6 cable, and having to guess which connector is the best match. This results in unnecessary service calls due to the use of the wrong connector/cable match. The unique patented design of the EX® body achieves true universality on 60% through Quad Shield for PE, and PVC jackets. Part Number EX6XL Connector Description Tool Req’d EX® Universal compression connector, series 6 cable CPLCCT-SLM PPC Customer Support 1.800.800.6652 11 www.ppc-online.com Compression Connector Accessories Compression Connector Accessories 12 Strain Relief Boots INDUSTRY USE: SECURITY A/V COMMERCIAL Belden’s strain relief boots provide enhanced strain relief and connector protection for your installation. The boot is an optional cable termination sleeve designed and manufactured to protect the cable’s bend radius so as not to damage the cable and connection caused by wire strain. SLS-59/6 Strain Relief Boots for RG59 and RG6 Coaxial Cable • Extended design includes three tiers that can be cut to customize for RG59 or RG6 cable diameters • Extended weather resistant boot (black) with enhanced strain relief PPC Customer Support 1.800.800.6652 www.ppc-online.com Basic Compression Connector Series CPLCRBC-BR • The original universal design connector series for standard through quad-shield size cables • Available in F and RCA connector types Part Number Connector Description Tool Required RG59NR RG59 F-type Connector for Headend Cable CPLCRBC-BR RG59WR RG59 F-type Connector w/ Internal Sealing Rings for 67% to Quad Shield, Indoor CPLCRBC-BR RG59WRO RG59 F-type Connector w/ Internal Sealing Rings for 67% to Quad Shield, External O-Ring for Outdoor CPLCRBC-BR RG6WR RG6 F-type Connector w/ Internal Sealing Rings for 60% to Tri-Shield, Indoor CPLCRBC-BR RG6WRO RG6 F-type Connector w/ Internal Sealing Rings for 60% to Tri-Shield, External O-Ring for Outdoor CPLCRBC-BR RG6NR RG6 F-type Connector, for Quad Shield, Indoor CPLCRBC-BR RG6NRO RG6 F-type Connector, for Quad Shield, External O-Ring for Outdoor CPLCRBC-BR CF81GHZM F81 Splice w/ Round Seizure No Tool Required CF81GHZMHDW F81 Splice w/ Round Seizure and Nut/Washer No Tool Required PPC Customer Support 1.800.800.6652 Basic Compression Connector Series INDUSTRY USE: CATV 13 www.ppc-online.com Cable Pro® Cable Strip Tools Cable Pro® Cable Strip Tools • Lightweight and compact for easy transportation and storage • Integrated rollers ensure the strip tool rolls around the cable to create a clean, even cut • NO screws, keys or other adjustment pieces to manage PSA59/6 Cable Strip Tool • Preps RG59, RG6 and RG58 cable • Adjustable dial locates the perfect setting for cable preparation • Patented cable stop creates a precise 1/4”-1/4” cable preparation • Integrated side flaring tool for RG6 cable • Includes an extra replacement blade cartridge 14 Part Number Description PSA59/6 Preps RG59, RG6 and RG58 cable PSCA59/6 Replacement Cartridge for PSA59/6 tool PPC Customer Support 1.800.800.6652 www.ppc-online.com PS59/6/RGB Cable Strip Tool (1) Cartridge (PSC-RGB/red) specifically for RGB/mini coax cables (1) Cartridge for RG59 and RG6 cables Part Number Description PS59/6/RGB Preps RG59, RG6 and RGB/ mini coax cables PSC59/6/RGB Replacement cartridge for PS59/6/RGB tool PSC-RGB Replacement cartridge for PS59/6/RGB tool to prep RGB/ mini coax cables Cable Pro® Cable Strip Tools • Preps RG59, RG6 and RGB/mini coax cable • Patented cable stop creates a precise 1/4”-1/4” cable preparation • Includes TWO extra blade cartridges! PS11 Cable Strip Tool • Preps RG11 cable • Heavy-duty spring provides resistance against every day wear • Patented cable stop creates a precise 1/4”-1/4” cable preparation • Includes an extra replacement blade cartridge Part Number Description PS11 Preps RG11 cables PSC11 Replacement cartridge for PS11 tool to prep RG11 cable PPC Customer Support 1.800.800.6652 15 www.ppc-online.com Cable Pro® Compression Tools Cable Pro® Compression Tools Belden uses the finest materials and metals available on the market to manufacture superior quality custom installation compression tools and connectors providing exceptional solutions for professional installers. CPSNSCT-596 Compression Tool INDUSTRY USE: CATV SATELLITE COMMERCIAL A/V • Standard compression tool for Snap-N-Seal connectors including F Male, RCA, BNC, Right Angle, Inline Splices, Ground Blocks as well as the ProSNS line to fit series 59 and 6 coaxial cables • Plier-type tool with revited construction • Support plate centers connectors, while plate fingers provide 300° support during compression • 1-year warranty SNSUNI Compression Tool INDUSTRY USE: CATV SATELLITE COMMERCIAL A/V • A universal plier-type tool with revited construction for Snap-N-Seal connectors including F Male, RCA, BNC, Right Angle, Splices aswell as the ProSNS line to fit series 59, 6, 7 and 11 coaxial cables • Easy to use - the black nylon slide is clearly indicated on the tool to assist with selecting the correct position for the cable type in use • Black nylon slide includes T-slot to prevent the tool tilting • Support plate centers connectors, while plate fingers provide 300° support during compression • 1-year warranty 16 PPC Customer Support 1.800.800.6652 www.ppc-online.com CPLCRBC-BR Double Bubble™ Compression Tool BROADCAST CATV COMMERCIAL • Compress the Double Bubble connectors to create a secure, permanent “double bubble” connection • Self-adjusting plunger head provides a precise and constant compression each and every time • Includes 1 LMTIP-S interchangeable adapter tip for compression of F and RCA type connectors • 1-year warranty Part Number Description CPLCRBC-BR Double Bubble™ Compression Tool - Blue LMTIP-S Silver adapter tip for DB silver/nickel connectors RBCTIP-UHF Adapter tip for Double Bubble 50 Ohm connectors Cable Pro® Compression Tools INDUSTRY USE: SECURITY CPLCCT-1-S Compression Tool INDUSTRY USE: CATV • For F-Conn FS or Snap-N-Seal ProSNS series F and RCA compression connectors • No adjustment for compression! • Crafted so that it is lightweight and easy to use • Self-adjusting plunger head provides a precise and constant compression each and every time • 1-year warranty PPC Customer Support 1.800.800.6652 17 www.ppc-online.com Cable Pro® Compression Tools CPLCCT-SLM Linear Compliant Compression Tool INDUSTRY USE: PRO A/V SECURITY CATV COMMERCIAL • Compress Legacy Snap-N-Seal & ProSNS series RG59, RG6 F, RCA, & BNC connectors • Manufactured of solid steel for maximum strength and durability • Crafted so that it is lightweight and easy to use • Self-adjusting plunger head provides a precise and constant compression each and every time • Includes four interchangeable adapter tips to compress a full line of connectors • Used to compress F-Conn’s FS and RG Series Connectors • 1-year warranty Part Number Description CPLCCT-SLM Linear Complaint Compression Tool LMTIP-S Silver adapter tip for F-Conn’s silver/nickel connectors LMTIP-RA Right Angle adapter tip for F-Conn’s right angle connectors LMTIP-HOLDER Holder for adapter tips LMTIP-KIT Kit includes Holder + 4 tips S, RA, G, WP LMTIP-G Gold tip LMTIP-WP Wall Plate CPLCCT-LS59/11 Compression Tool INDUSTRY USE: CATV • Compress F-Conn RG59, RG6 connectors, Legacy Snap-N-Seal and ProSNS series RG59, RG6, RG7 or RG11 connectors • 1-year warranty 18 PPC Customer Support 1.800.800.6652 www.ppc-online.com CPLCCT-SS59/11 Compression Tool • For F-Conn FS or Snap-N-Seal ProSNS series RG59 and RG6 F connectors or F-Conn RG11 connectors (FS11V, FS11PL and FS11RA) • 1-year warranty PPC Customer Support 1.800.800.6652 Cable Pro® Compression Tools INDUSTRY USE: CATV 19 HDMI Cables www.ppc-online.com Perfect Path HDMI Cables Perfect Path developed and patented the first Locking Connector for HDMI Cables, with more than six times the holding retention of conventional HDMI. 1000 Series - High Speed HDMI® Cable with Ethernet Channel and Locking Connectors The embodiment of the perfect path. The HD • Supports 3D gaming and other 1000 breaks the boundaries of the HDMI system, 3D video applications now and for the future. 700 Series - High Speed HDMI® Cable with Locking Connectors Perfect for systems without the HDMI Ethernet Channel. The HD 700 gives you the groundbreaking performance of the HD 1000, without the Ethernet Channel feature. 600 Series - High Speed HDMI® Cable with High-Retention Connectors • Transmits digital content at extremely high resolution (4K) • Perfect Lock™ locking connectors with 25lbs retention • Audio Return Channel • Perfect Lock™ locking connectors with 25lbs retention in 1000 & 700 Series. Housetrained, but kind of a showoff. The HD 600 provides flagship performance in a nofrills package design. Features Perfect Path’s patented PerfectHold™ connector, for three times the holding retention of conventional HDMI connectors. 20 Part Number Description HD-600-3B High Retention, High Speed HDMI® Cable, 3 FT HD-600-6B High Retention, High Speed HDMI® Cable, 6 FT HD-600-12B High Retention, High Speed HDMI® Cable, 12 FT HD-700-2 High Speed Cable w/ PerfectLock™ Connectors 2 ft Gold CL2/FT4 HD-700-4 High Speed Cable w/ PerfectLock™ Connectors 4 ft Gold CL2/FT4 HD-700-8 High Speed Cable w/ PerfectLock™ Connectors 8 ft Gold CL2/FT4 HD-700-16 HD-700-25 High Speed Cable w/ PerfectLock™ Connectors 16 ft Gold CL2/FT4 High Speed Cable w/ PerfectLock™ Connectors 25 ft Gold CL2/FT4 HD-700-35 High Speed Cable w/ PerfectLock™ Connectors 35 ft Gold CL2/FT4 HD-700-50 High Speed Cable w/ PerfectLock™ Connectors 50 ft Gold CL2/FT4 HD-1000-2 High Speed Cable w/ Ethernet and PerfectLock™ Connectors 2 ft Gold CL2/FT4 HD-1000-4 HD-1000-8 HD-1000-16 HD-1000-25 HD-1000-35 HD-1000-50 High Speed Cable w/ Ethernet and PerfectLock™ Connectors 4 ft Gold CL2/FT4 High Speed Cable w/ Ethernet and PerfectLock™ Connectors 8 ft Gold CL2/FT4 High Speed Cable w/ Ethernet and PerfectLock™ Connectors 16 ft Gold CL2/FT4 High Speed Cable w/ Ethernet and PerfectLock™ Connectors 25 ft Gold CL2/FT4 High Speed Cable w/ Ethernet and PerfectLock™ Connectors 35 ft Gold CL2/FT4 High Speed Cable w/ Ethernet and PerfectLock™ Connectors 50 ft Gold CL2/FT4 PPC Customer Support 1.800.800.6652 www.ppc-online.com Cable Pro® Tech Express Tool Kits SLMPSAKIT Tech Express Tool Kit • CPLCCT-SLM Compression Tool and adapter tips • PSA59/6 Cable Strip Tool and extra blade cartridge Cable Pro® Tool Kits Belden continues to expand our product line to ensure professional installers have the tools they need to create a permanent, quality installation. • These tools work together as a complete integrated system with F-Conn’s FS and RG series as well as the Snap-N-Seal ProSNS series of compression connectors DBPSAKIT Tech Express Tool Kit • CPLCRBC-BR Compression Tool and silver adapter tip • PSA59/6 Cable Strip Tool and extra blade cartridge • These tools work together as a complete integrated system with Belden’s Double Bubble series of compression connectors PROPSAKIT Tech Express Tool Kit • Cable Pro® Standard Compression Tool (CPSNSCT-596) • Cable Pro® Cable Strip Tool (PSA59/6) for RG59, RG6 and RG6 Quad-Shield with Extra Blade Cartridge and RG6 Flare Tool PPC Customer Support 1.800.800.6652 21 www.ppc-online.com Connector and Tool Kits Compression Connector and Tool Kits PPC is recognized worldwide for our innovative line of 360º compression connectors, tools and accessories that work together as a complete system. STARTERKIT The PPC Starter Kit contains a Cable Pro® CPLCCT-SLM compression tool, PS59/6/RGB cable strip tool, and a variety of F-Conn™ FS or ProSNS™ compression connectors to create a high-quality, custom Audio/Video installation. STARTERKIT INCLUDES: • CPLCCT-SLM Compression Tool • PS59/6/RGB Cable Strip Tool • (5) FSNS6RCAU • (5) FSNS6URA • (5) FSBNC6URA • PSC59/6/RGB (Blue Spare Cartridge) • (5) FS6US • PSC-RGB (Red Spare Cartridge) • (5) FS6RCAUS • Wall Plate Inserts, Color Bands • (5) FS1RCA and Strain Relief Boots • (5) FS1BNC • (10) FSNS59U • (5) FS15RCA • (5) FSNS59BNCU • (5) FS15BNC • (10) FSNS6U • (2) SLS-59/6 • (5) FSNS6BNCU • (2) HIPUKM • (2) HIPUWM • (1) SLS-RGB-Red • (1) SLS-RGB-Yellow • (1) FSCR-B • (1) FSCR-Y • (1) HIPPOB • (1) HIPOY DBSTARTERKIT The Belden Double Bubble™ Starter Kit contains a Cable Pro CPLCRBCBR compression tool, PSA59/6 cable strip tool, and a variety of Double Bubble compression connectors to create a secure connection for structured wiring, security and satellite installations. DBSTARTERKIT INCLUDES: • CPLCRBC-BR Compression Tool • PSA59/6 Cable Strip Tool • FIT-59 Flaring/ Insertion Tool • SLS-59/6 • (25) DB59U 22 PPC Customer Support 1.800.800.6652 • (10) DB59BNCU • (10) DB59RCAU • (10) DB59BNCSL • (25) DB6U • (10) DB6BNCU www.ppc-online.com Cable Pro® Cable Caddies CC2016B Cable Caddie • Holds one 20” x 16” reel • Compact unit • Made of sturdy 3/4” tubing • CC2016B does not include wheels • Holds up to 100 lbs. Cable Pro® Cable Caddies PPC Cable Pro Cable Caddies are engineered using high quality, lightweight steel tubing and incorporates a unique folding mechanism. This allows professional installers to easily fold and transport the caddie to each cable installation location. Wheeled versions of the cable caddie are available to make moving from each location a breeze. CC2016B CC2024 Cable Caddie • Holds one 20” x 24” reel • Made of Sturdy 1” tubing • Features 6” wheels for easy movement • Holds up to 100 lbs. CC2024 CC2036D Cable Caddie • Holds a variety of reel combinations • Adjustable bar heights • Two simplified ways to load reels • Made of Sturdy 1” tubing • Holds up to 100 lbs. per reel CC2036D PPC Customer Support 1.800.800.6652 23 www.ppc-online.com Cable Pro® Torque Wrenches Cable Pro® Torque Wrenches TROE716SH Speed Head Torque Wrench INDUSTRY USE: CATV SATELLITE • “Speed” head for quick tightening without having to remove the wrench from the connector • Use to tighten 7/16" F-type fittings • Torque inch/pounds preset at factory (10-60 in./lbs.) Torque values: 10, 15, 20, 25, 30, 40, 50 & 60 • Medium carbon steel (heat treated) with black oxide finish • Blue cushioned grip TROE716E Easy Open End Torque Wrench INDUSTRY USE: CATV 24 SATELLITE • Available in 7/16” configuration for F-fittings • Coated with black oxide to offer the ultimate protection against daily wear and tear • A soft, blue, rubber grip provides a smooth gripping surface • Torque inch/pounds are preset at the factory based on your specifications from 10-60 in./lbs Torque values: 10, 15, 20, 25, 30, 40, 50 & 60 PPC Customer Support 1.800.800.6652 www.ppc-online.com INDUSTRY USE: CATV SATELLITE • Available in 7/16" or 9/16" configuration for F-fittings • Manufactured using chromemoly, a high-quality metal to provide installers with a durable, quality tool • Ergonomically designed to have a True Torque Grip giving you total control and precision when used • Torque inch/pounds are preset at the factory based on your specifications from 10-60 in./lbs Cable Pro® Torque Wrenches TROE716/TROE916 True Torque Open End Torque Wrench Swivel 7/16” Torque Wrench • Use to torque 7/16” F-type fittings • Designed to work with multi-part taps • Torque wrenches are preset in the factory to specified torque in./lbs. Part Number Description TRS716-* 7/16” Torque Wrench. Torque Values: 15, 20, 25, 30, 40, 50 & 60 TRS716SS-EX-* 7/16” Torque Wrench removes plastic sleeves. Torque Values: 30 & 40 only TRS716SS-* 7/16” Torque Wrench removes metal sleeves. Torque Values: 20, 30 & 40 only PPC Customer Support 1.800.800.6652 25 www.ppc-online.com Fixed/Swivel 3/8” Socket Drive Torque Wrench Cable Pro® Torque Wrenches 26 • Ability to use different size sockets • Torque wrenches are preset in the factory to specified torque in./lbs. Part Number Description TRS3/8 Swivel 3/8” Socket Drive Torque Wrench Torque Values: 30 only PPC Customer Support 1.800.800.6652 www.ppc-online.com Belden manufactures a full line of high-quality Cable Pro installation tools for the professional installer. Can Wrench • Used to open pedestals and tighten ground straps and taps Part Number Description CNW6 Can Wrench (3/8” & 7/16”) CNW8 Can Wrench (1/2” & 9/16”) Trap Wrench Cable Pro® Installation Tools Cable Pro® Installation Tools • Made of lightweight 6061 aluminum • 2 steel pins, press fitted into the aluminum tube, to remove traps • Anodized for superior protection and easy identification • Fits 7/16" hex F-fittings • Knurled hand grips assure controlled handling Part Number Description TW716 Trap Wrench - Red TWS716 Super Trap Wrench - Black Hex Head is made of hardened steel TWC716 Combo Trap Wrench - Blue For Metal Security Sleeves Combines standard trap wrench design with a security sleeve Security socket is made of hardened steel TWC716-EX Combo Trap Wrench - Blue For Plastic Security Sleeves Combines standard trap wrench design with a security sleeve Security socket is made of hardened steel PPC Customer Support 1.800.800.6652 27 www.ppc-online.com Extended Headend Socket Wrench Cable Pro® Installation Tools 28 • Use in headend or behind rack for installation and removal of 7/16” F-type or BNC fittings • Dual-end tool provides the use of two tools in one making installation quick and easy • One end of dual-end tool assists with insertion and removal, and the other end “locks-down” the patent-pending locking collar of the Locking BNC Connector • Dual-end and BNC socket wrenches feature tapered ends to make BNC installations on patch panel ports accessible and easy to manage • Manufactured from quality materials to provide a long-lasting, durable tool Part Number Description HT-716 Extended Headend F Connector Socket Wrench HT-BNC Extended Headend BNC Connector Socket Wrench PPC Customer Support 1.800.800.6652 www.ppc-online.com • GTT tools are designed to be used with theft proof Gilbert GTP Locking Terminators • GGT-PPLT combines a Cable Pro PPLT Locking Terminator with a Gilbert GTT Locking Terminator in one tool • Features solid steel spring ears • Available in two lengths: 4” and 7” Part Number Description GTT-4 4” Gilbert Terminating Tool GTT-7 7” Gilbert Terminating Tool GTT-PPLT-4 4” Cable Pro & Gilbert Terminating Tool GTT-PPLT-7 7” Cable Pro & Gilbert Terminating Tool Cable Pro® Installation Tools Gilbert Terminating Tool Viewsonics Terminating Tool • Use with Viewsonics Locking Terminators • Available in two lengths: 4” and 7” • Tools are made of zinc plated steel Part Number Description VTT-4 4” Viewsonics Terminating Tool VTT-7 7” Viewsonics Terminating Tool PPC Customer Support 1.800.800.6652 29 www.ppc-online.com Cable Pro® Installation Tools Security Wrench • Made of chrome 4130 steel • Includes steel spring handle and tightens to 40 in./lbs. Part Number Description SWU716 Universal Security Wrench for metal sleeves SWU716-EX Thick Wall Security Sleeve for plastic sleeves DSW716 Dual Security Wrench combines 7/16” socket for standard F-type fittings, and 1/2” socket for LRC seal nut and Gilbert TAC fittings SW-SACH Sach Security Wrench MSW716 Mini Security Wrench Installation Tool • Tools speed the installation and the removal of drop cable • Available in 7/16” and 9/16” sizes • Made from 6061 aluminum and features knurled surfaces, a cable slot, and a hard anodized finish 30 Part Number Description IT716 7/16” Installation Tool IT916 9/16” Installation Tool PPC Customer Support 1.800.800.6652 www.ppc-online.com Siamese Stripper Part Number Description SS-596 RG59 and RG6 Siamese Cable Separator Cable Pro® Installation Tools • Siamese strippers separate RG59 and RG6 wisted pair cable, coaxial siamese cable and messenger coaxial cable Flaring and Insertion Tool • Flaring expands jacket to ease the insertion of connectors on to Plenum, Quad and standard size cables • Insertion simplifies pushing the connector on to the cable Part Number Description FIT-6 Flaring/ Insertion Tool for RG6 Cable FIT-59 Flaring/ Insertion Tool for RG59 Cable FIT-11 Flaring/ Insertion Tool for RG11 Cable PPC Customer Support 1.800.800.6652 31 www.ppc-online.com Cable Pro® Installation Tools Pen Toner Continuity Testers • Convenient, easy-to-store cable tester • Loud audio tone identifies the line carrying signal • Viewable DC Short LED • Designed for RF cable applications • Ergonomic, rugged anodized b  rass body • Battery included Part Number Description CPPT-1 Pen Toner to test and identify terminated F cables CPPT-2 Pen Toner to test and identify terminated F or BNC cables. Uses AAA battery Toner Boxes Continuity Testers • Toner boxes feature loud audio signal • LED display detects splitters and shorts in cable drops • Two 9-volt batteries (18 volts) allow for testing longer cable drops 32 Part Number Description TS-18 Toner Set (Buzz Box and Battery Box) PPC Customer Support 1.800.800.6652 www.ppc-online.com Notes: ____________________________________________________ ____________________________________________________ ____________________________________________________ ____________________________________________________ ____________________________________________________ ____________________________________________________ ____________________________________________________ ____________________________________________________ ____________________________________________________ ____________________________________________________ ____________________________________________________ ____________________________________________________ ____________________________________________________ ____________________________________________________ ____________________________________________________ ____________________________________________________ ____________________________________________________ ____________________________________________________ ____________________________________________________ ____________________________________________________ ____________________________________________________ ____________________________________________________ PPC Customer Support 1.800.800.6652 33 www.ppc-online.com Connector Sizing Chart F-Conn Compression Connector Sizing Chart (Inches) Type Description Double Bubble ProSNS MIN-MAX RG1 (24-26AWG*) Center Conductor .015-.025 Dielectric .065-.078 ORANGE DB1BNCHD DB1RCA-R DB1BNC FS1BNC, FS1RCA FSBNC1RGB* FSRCA1RGB* FS1BNCSST* FS1RCASST* FSBNC1RA* MIN-MAX RG15 (22-24AWG*) Center Conductor .015-.025 Dielectric .095-.105 PURPLE DB15BNCHD DB15RCA-R DB15BNC FSNS15, FSNS15BNC FS15RCA FSBNC15RGB* FSRCA15RGB* FS15BNCSST* FS15RCASST* FSBNC15RA* Outer Jacket Outer Jacket Size .095-.110 .145-.160 *This AWG is a reference point only please make sure you spec the cable to ensure proper fit. RG59 PLENUM RED RG59 PLENUM 3 RED RG59 SECURITY RED RG59 UNIVERSAL RED Center Conductor Dielectric Outer Jacket MIN-MAX .0317.0339 .147-.157 .190-.220 DB59PL2 DB59BNCPL2 DB59RCAPL2 DB59PL2/4 DB59BNCPL2/4 DB59RCAPL2/4 FSNS59PL FSNS59BNCPL FSNS59RCAPL MIN-MAX .0210.0240 .130-.137 .190-.220 DB59BNCPL3 FSNS59BNCPL3 Center Conductor Dielectric Outer Jacket MIN-MAX .0317.0339 .137-.148 .232-.248 DB59BNCSL DB59RCASL FSNS59BNCSL Center Conductor Dielectric Outer Jacket Center Conductor Dielectric Outer Jacket MIN-MAX .0317.0339 .144-.157 .232-.273 DB59U DB59BNCU DB59RCAU DB59BNCHD FSNS59U FSNS59BNCU FSNS59RCAU FSRCA59URA FS59BNCUS FS59RCAUS *Actual cable sizes may vary from manufacturer specifications and testing may be required to verify correct connector fit. 34 PPC Customer Support 1.800.800.6652 www.ppc-online.com F-Conn Compression Connector Sizing Chart (Inches) Type RG59/ MINI CENTER CONDUCTOR RG59 ITS CONNECTOR RG6 PLENUM GREEN RG6 QUAD GREEN RG6 UNIVERSAL GREEN RG11 UNIVERSAL BLACK RG11 PLENUM GRAY DS3 CONNECTOR DS4 CONNECTOR Description Size Double Bubble DB59BNCBU Center Conductor Dielectric Outer Jacket MIN-MAX .021-.024 .144-.157 .232-.273 ProSNS Center Conductor Dielectric Outer Jacket MIN-MAX .024-.034 .190-.200 .295-.305 DB59BNCSL2-M DB59BNCSL2-F Center Conductor Dielectric Outer Jacket MIN-MAX .0399-.0418 .183-.193 .220-.250 DB6PL2 DB6BNCPL2 DB6RCAPL2 Center Conductor Dielectric Outer Jacket MIN-MAX .0399-.0418 .180-.193 .289-.305 Center Conductor Dielectric Outer Jacket MIN-MAX .0399-.0418 .180-.193 .265-.305 Center Conductor Dielectric Outer Jacket MIN-MAX .0634-.0647 .280-.294 .390-.417 716SNS1P11H, 716SNS1P11HQ FSNS11HBNC, FSNS11HQBNC 90SNS1P11H Center Conductor Dielectric Outer Jacket MIN-MAX .0634-.0647 .280-.294 .339-.355 716SNS1P11HPLA FSNS11HBNCPLA MIN-MAX .014-.020 .070-.085 .120-.140 DBDS3BNC Center Conductor Dielectric Outer Jacket MIN-MAX .317-.0339 .145-.155 .220-.240 DBDS4BNC Center Conductor Dielectric Outer Jacket FSNS6PL FSNS6BNCPL FSNS6RCAPL FSNS6PLQ FSNS6BNCPLQ FSNS6RCAPLQ DB6U DB6BNCU DB6RCAU DB6BNCHD FSNS6BNCU FSNS6RCAU FSNS1P6QS-R *Actual cable sizes may vary from manufacturer specifications and testing may be required to verify correct connector fit. Connector/ Cable Cross Reference Chart available at www.ppc-online.com PPC Customer Support 1.800.800.6652 35 Belden 6176 East Molloy Road East Syracuse, NY 13057 Customer Support 1.800.800.6652 ppc@ppc-online.com To view our full line of Belden Solutions please visit www.ppc-online.com BELDEN Product Families This publication contains the most current products and specifications as of this printing. Items may be added, deleted, discontinued, or revised without notice. Please contact PPC to verify product specifications and availability. 062014
CPLCCT-SS59/11 价格&库存
很抱歉,暂时无法提供与“CPLCCT-SS59/11”相匹配的价格&库存,您可以联系我们找货
