123092A 0101000
123092A 0101000
    BELDEN
    BELDEN - 123092A 0101000 - COAXIAL CABLE, RG6, 18AWG, 75OHM, BLACK, 1000FT
123092A 0101000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 123092A Coax - ControlNet™ Quad Shielded Coax For more Information please call 1-800-Belden1 General Description: 18 AWG solid bare copper-covered steel conductor, foam polyethylene insulation, Duobond IV® quad shield (100% coverage), PVC inner jacket, aluminum interlocked armor, PVC sunlight-resistant outer jacket. Usage (Overall) Suitable Applications: ControlNet™, Modbus II, Industrial Coax Physical Characteristics (Overall) Conductor AWG: # Coax AWG Stranding Conductor Material 1 18 Solid Dia. (in.) BCCS - Bare Copper Covered Steel .040 Total Number of Conductors: 1 Insulation Insulation Material: Insulation Material Dia. (in.) FPE - Foam Polyethylene .180 Inner Jacket Inner Jacket Material: Inner Jacket Material Nom. Dia. (in.) PVC - Polyvinyl Chloride 0.298 Outer Shield Outer Shield Material: Layer # Outer Shield Trade Name Type Outer Shield Material 1 Bonded Duofoil® 2 3 Duofoil® 4 Coverage (%) Tape Bonded Aluminum Foil-Polyester Tape-Aluminum Foil 100 Braid AL - Aluminum 60 Tape Aluminum Foil-Polyester Tape-Aluminum Foil 100 Braid AL - Aluminum 40 Outer Jacket Outer Jacket Material: Outer Jacket Material Nom. Wall Thickness (in.) PVC - Polyvinyl Chloride 0.045 Armor Armor Type: Interlocking Armor Material: Aluminum Diameter over Armor: .501 Overall Cable Overall Nominal Diameter: 0.591 in. Mechanical Characteristics (Overall) Operating Temperature Range: -40°C To +75°C Bulk Cable Weight: 142 lbs/1000 ft. Max. Recommended Pulling Tension: 200 lbs. Min. Bend Radius/Minor Axis: 7.100 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CL2, CM EU Directive 2011/65/EU (ROHS II): Yes EU Directive 2000/53/EC (ELV): Yes Page 1 of 3 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 123092A Coax - ControlNet™ Quad Shielded Coax EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 10/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes RG Type: 6/U Flame Test UL Flame Test: UL1685 Vertical Tray Flame Test CSA Flame Test: FT4 Suitability Suitability - Indoor: Yes Suitability - Outdoor: Yes Sunlight Resistance: Yes Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 75 Nom. Inductance: Inductance (µH/ft) .097 Nom. Capacitance Conductor to Shield: Capacitance (pF/ft) 16.2 Nominal Velocity of Propagation: VP (%) 82 Nominal Delay: Delay (ns/ft) 1.28 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 28.0 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 3.6 Nom. Attenuation: Freq. (MHz) Attenuation (dB/100 ft.) 1 .35 2 .38 5 .45 10 .59 20 .86 50 1.37 100 1.97 200 2.82 300 3.48 400 4.04 Max. Operating Voltage - UL: Voltage 300 V RMS Minimum Structural Return Loss: Description Freq. (MHz) Start Freq. (MHz) Stop Freq. (MHz) Min. SRL (dB) 5 50 23 Notes (Overall) Notes: ControlNet is a ControlNet International trademark. Page 2 of 3 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 123092A Coax - ControlNet™ Quad Shielded Coax Notes: ControlNet is a ControlNet International trademark. Put Ups and Colors: Item # Putup Ship Weight Color 123092A J221000 1,000 FT 153.000 LB BLUE, STRONG 3092A ALUM ARMOR PVC 123092A J225000 5,000 FT 810.000 LB BLUE, STRONG 3092A ALUM ARMOR PVC 123092A 0101000 1,000 FT 153.000 LB BLACK 3092A ALUM ARMOR PVC 123092A 0102000 2,000 FT 316.000 LB BLACK TRANSFER REVIEW Revision Number: 3 Notes Item Desc Revision Date: 08-16-2012 © 2016 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 3 of 3 08-26-2016
123092A 0101000 价格&库存
很抱歉,暂时无法提供与“123092A 0101000”相匹配的价格&库存,您可以联系我们找货
