1280R B591000
1280R B591000
    BELDEN
    6#25LDPE/GIFHDLDPE SH FRPVCPVC
1280R B591000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1280R Coax - Mini Hi-Res Component Video Cable For more Information please call 1-800-Belden1 General Description: 25 AWG solid .018” tinned copper conductors, Gas-injected FHDPE insulation, Duobond® foil plus a tinned copper interlocked serve shield (95% coverage), PVC inner jacket, PVC jacket. Usage (Overall) Suitable Applications: RGB Projectors, LCD Projectors, Video Distribution, Component Video, Graphic Displays, Special Effects Editing, Animation, Video Post Production, Home Theater, Offices, Boardrooms, Auditoriums, Teleconferencing, Theaters Physical Characteristics (Overall) Conductor AWG: # Coax AWG Stranding Conductor Material Dia. (in.) 6 25 Solid TC - Tinned Copper .018 Total Number of Conductors: 6 Insulation Insulation Material: Insulation Material Dia. (in.) Gas-injected FHDPE - Foam High Density Polyethylene 0.074 Inner Shield Inner Shield Material: Layer # Inner Shield Trade Name Type Inner Shield Material 1 Aluminum Foil-Polyester Tape Lightly bonded to dielectric 100 Duobond® Tape 2 Coverage (%) Interlocked Serve TC - Tinned Copper 95 Inner Jacket Inner Jacket Material: Inner Jacket Material Nom. Dia. (in.) PVC - Polyvinyl Chloride .114 Inner Jacket Color Code Chart: Number Color 1 Red 2 Green 3 Blue 4 Yellow 5 Black 6 White Outer Jacket Outer Jacket Material: Outer Jacket Material PVC - Polyvinyl Chloride Outer Jacket Ripcord: Yes Overall Cable Overall Nominal Diameter: 0.423 in. Mechanical Characteristics (Overall) Operating Temperature Range: -40°C To +75°C UL Temperature Rating: 60°C Non-UL Temperature Rating: 75°C Bulk Cable Weight: 78 lbs/1000 ft. Max. Recommended Pulling Tension: 135 lbs. Min. Bend Radius (Each Coax): 1.100 in. Min. Bend Radius (Overall): 4.250 in. Page 1 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1280R Coax - Mini Hi-Res Component Video Cable Min. Bend Radius (Overall): 4.250 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMR CEC/C(UL) Specification: CMG EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: No EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Flame Test UL Flame Test: UL1666 Vertical Shaft CSA Flame Test: FT4 Suitability Suitability - Indoor: Yes - Risers Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 75 Nom. Inductance: Inductance (µH/ft) .087 Nom. Capacitance Conductor to Shield: Capacitance (pF/ft) 17.0 Nominal Velocity of Propagation: VP (%) 80 Nominal Delay: Delay (ns/ft) 1.24 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 34 Nom. Inner Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 5.4 Nom. Attenuation: Freq. (MHz) Attenuation (dB/100 ft.) 1 0.52 5 1.17 50 3.7 100 4.9 200 6.7 400 9.5 750 13.4 900 15.0 1000 15.8 3000 31.2 Max. Operating Voltage - UL: Voltage Page 2 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1280R Coax - Mini Hi-Res Component Video Cable 300 V RMS Max. Operating Voltage - Non-UL: Voltage 300 V RMS Minimum Return Loss: Description Freq. (MHz) Start Freq. (MHz) Stop Freq. (MHz) Min. RL (dB) 5 850 20 Sweep Test Sweep Testing: 5 - 850 MHz Misc. Information (Overall) Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 1280R B591000 1,000 FT 87.000 LB BLACK, MATTE C 6#25LDPE/GIFHDLDPE SH FRPVCPVC 1280R B59500 500 FT 44.000 LB BLACK, MATTE C 6#25LDPE/GIFHDLDPE SH FRPVCPVC Notes: C = CRATE REEL PUT-UP. Revision Number: 3 Revision Date: 09-11-2012 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 3 of 3 01-05-2017
1280R B591000 价格&库存
很抱歉,暂时无法提供与“1280R B591000”相匹配的价格&库存,您可以联系我们找货
