1633ENS.00500
1633ENS.00500
    BELDEN
    BELDEN - 1633ENS.00500 - SHLD CABLE, CAT5E, 4 PAIR, 24AWG, 500M
1633ENS.00500 数据手册
1633ENS Networking Cables Datatwist® cable CAT 5E SF/UTP LSNH 2012-07-11 v3 Applications • Horizontal and building backbone cable • Support current and future Category 5e applications, such as: 1000Base-T (Gigabit Ethernet), 100 Base-T, 10 Base-T, FDDI, ATM General standards • International standard: ISO/IEC 11801 2nd edition (2002) and ISO/IEC 11801 Amendment 2 (2010) • European standard: EN 50173-1 (2002) and EN 50173-1 Amendment 1 (2009) • U.S. Standards: ANSI/TIA/EIA 568-B.2-1 (2002) Construction & Dimensions 1 2 3 4 5 1. Conductor Material Diameter Solid bare copper ETP AWG 24 2. Insulation Material Nominal diameter over insulation Polyethylene 1.05 mm 3. Cable core Pair Number of pairs Colour code pair 1 Colour code pair 2 Colour code pair 3 Colour code pair 4 Foil 2 twisted insulated conductors 4, all twisted together White / Blue & Blue White / Orange & Orange White / Green & Green White / Brown & Brown Overlapping polyester foil over cable core 4. Foil shielding Material Position aluminium Drain wire material Drain wire diameter Laminated Aluminium / Polyester Facing outside, in contact with drain wire Solid tinned copper AWG 26 Braid material Coverage solid tinned copper ≥ 30 % 5. Jacket Material Diameter LSNH 6.0 ± 0.3 mm Electrical characteristics Reference standard: ISO/IEC 61156-5 edition 2.0 (2009) Low frequency and D.C. (at 20°C) D.C. resistance conductor Resistance unbalance: within a pair / between pairs Insulation resistance Dielectric strength conductor-conductor and conductor-screen (2 sec.) Mutual capacitance Capacitance unbalance pair to ground Nominal velocity of propagation (for information only) Delay skew (differential delay) Transfer impedance according IEC 61156-5 Coupling attenuation according IEC 61156-5 High frequency (at 20°), reference standard: ISO/IEC61156-5 TYPE 1* 4 10 16 20 Specification < 9,5 9 Unit % % % MPa Environmental and overall characteristics Maximum operating voltage (for all temperatures cable is intended to be used) Maximum continuous current per conductor (@25°C) Temperature rating installation Temperature rating operation Total cable weight Minimum bending radius (during operation and installation) Maximum pulling strength Burning load Smoke density acc. to IEC 61034-1/2 & EN50268-1/2; transmittance Amount of halogen acid gas acc. to IEC 60754-1/2 & EN50267-1/2; pH Amount of halogen acid gas acc. to IEC 60754-1/2 & EN50267-1/2; Conductivity Fire performance according IEC 60332-1 Specification 72 1.5 0 / 50 - 30 / 60 45 24 / 48 72 440 > 60 > 4.3 < 10 Pass Unit V D.C. A °C °C kg/km mm N kJ/m % µS/mm Belden declares this product to be in compliance with the environmental regulations EU RoHS (Directive 2002/95/EC, 27 January 2003); this is valid for all material produced after the RoHS compliant date for this product. 3
1633ENS.00500 价格&库存
很抱歉,暂时无法提供与“1633ENS.00500”相匹配的价格&库存,您可以联系我们找货
