1672A TIN500
1672A TIN500
    BELDEN
    #29 TFE SH TINNED COAX
1672A TIN500 数据手册
Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 1672A Coax - 75 Ohm High-Frequency Cable Conformable® Coax Cable For more Information please call 1-800-Belden1 General Description: 29 AWG solid .011" silver-coated copper-covered steel conductor, TFE Teflon® insulation, copper-tin composite shield (100% coverage), unjacketed. Physical Characteristics (Overall) Conductor AWG: # Coax AWG Stranding Conductor Material 1 29 Solid Dia. (mm) SCCCS - Silver-coated Copper-covered Steel 0.28956 Total Number of Conductors: 1 Insulation Insulation Material: Insulation Trade Name Insulation Material Teflon® Dia. (mm) TFE - Tetrafluoroethylene 1.5748 Outer Shield Outer Shield Material: Layer # Type Outer Shield Material Coverage (%) 1 Tape Copper Foil 100 2 Braid Tin-Filled Composite 100 Outer Jacket Outer Jacket Material: Outer Jacket Material Unjacketed Overall Cable Overall Nominal Diameter: 2.210 mm Mechanical Characteristics (Overall) Operating Temperature Range: -70°C To +200°C UL Temperature Rating: 105°C Non-UL Temperature Rating: 200°C Bulk Cable Weight: 17.412 Kg/Km Max. Recommended Pulling Tension: 88.964 N Min. Bend/Installation: 3.175 mm Min. Bend Radius (Overall): 25.400 mm Min. Flexing Radius: 0.953 cm Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs AWM Specification: UL Style 10245 EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes Page 1 of 3 10-14-2013 Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 1672A Coax - 75 Ohm High-Frequency Cable Conformable® Coax Cable EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Flame Test Other Flame Test: Horizontal Wire Suitability Suitability - Indoor: Yes Suitability - Outdoor: Yes Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 75 Nom. Inductance: Inductance (µH/m) 0.357629 Nom. Capacitance Conductor to Shield: Capacitance (pF/m) 63.9795 Nominal Velocity of Propagation: VP (%) 69.5 Nominal Delay: Delay (ns/m) 4.79026 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/km) 672.605 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/km) 32.81 Nom. Attenuation: Freq. (MHz) Attenuation (dB/100m) 1 5.2496 10 5.9058 50 13.4521 100 21.3265 200 29.529 400 41.9968 700 59.058 1000 72.5101 Nom. Power Rating: Freq. (MHz) Rating (W) 1 520 10 295 Page 2 of 3 10-14-2013 Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 1672A Coax - 75 Ohm High-Frequency Cable Conformable® Coax Cable 50 195 100 160 200 140 400 130 700 127 1000 125 Max. Operating Voltage - UL: Voltage 30 V RMS Max. Operating Voltage - Non-UL: Voltage 900 V RMS Minimum Structural Return Loss: Description Freq. (MHz) Start Freq. (MHz) Stop Freq. (MHz) Min. SRL (dB) 10 1000 25 Misc. Information (Overall) Notes (Overall) Notes: Teflon® is a registered trademark of E. I. duPont de Nemours and Co. used under license by Belden, Inc. Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 1672A TIN1000 305 MT 6.350 KG TIN - COLOR V #29 TFE SH TINNED COAX 1672A TIN500 152 MT 2.948 KG TIN - COLOR V #29 TFE SH TINNED COAX Notes: V = 250' PUT-UP EXACT LENGTH MAXIMUM OF 3 PIECESMINIMUM LENGTH 50'500' PUT-UP EXACT LENGTH MAXIMUM OF 5 PIECESMINIMUM LENGTH 50' Revision Number: 4 Revision Date: 06-24-2013 © 2013 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 73/23/EEC), as amended by directive 93/68/EEC. Page 3 of 3 10-14-2013
1672A TIN500 价格&库存
很抱歉,暂时无法提供与“1672A TIN500”相匹配的价格&库存,您可以联系我们找货
