1694F B591000
1694F B591000
    BELDEN
    #19 GIFHDLDPE DBLB FRPVC
1694F B591000 数据手册
Part Number: 1694F Serial Digital Coax, Flexible, RG6 Type, 19 AWG Stranded BC, Double TC braid, CM Product Description Low Loss Serial Digital Coax, RG-6/U Type, 19 AWG stranded bare copper conductor, foam HDPE core, double 95% tinned copper braid, CM rated, flexible PVC jacket Technical Specifications Product Overview Environmental Space: Indoor Suitable Applications: Digital Video, Analog Video Physical Characteristics (Overall) Conductor AWG Stranding 19 Stranded Material Nominal Diameter No. of Coax BC - Bare Copper 0.04 in Conductor Count: 1 1 Insulation Material Nominal Diameter Gas-injected FHDPE - Foam High Density Polyethylene 0.18 in Outer Shield Material Type Layer Material Coverage [%] Braid 1 TC - Tinned Copper 95 % Braid 2 TC - Tinned Copper 95 % Outer Jacket Material Material Nominal Diameter PVC - Polyvinyl Chloride 0.276 in Electrical Characteristics Conductor DCR Nominal Conductor DCR Nominal Outer Shield DCR Outer Conductor DCR 8.5 Ohm/1000ft 1.7 Ohm/1000ft Capacitance Nom. Capacitance Conductor to Shield 17.0 pF/ft Inductance Nominal Inductance 0.106 µH/ft Impedance Nominal Characteristic Impedance 75 Ohm 1.7 Ohm/1000ft Return Loss (RL) Frequency [MHz] Minimum Return (RL) 5 - 850 MHz 20 dB 850 - 6000 MHz 15 dB High Frequency (Nominal/Typical) Frequency [MHz] Nom. Insertion Loss 1 MHz 0.24 dB/100ft 3.58 MHz 0.45 dB/100ft 5 MHz 0.54 dB/100ft 6 MHz 0.55 dB/100ft 7 MHz 0.62 dB/100ft 10 MHz 0.72 dB/100ft 12 MHz 0.83 dB/100ft 25 MHz 1.18 dB/100ft 55 MHz 1.76 dB/100ft 67.5 MHz 1.9 dB/100ft 71.5 MHz 2.0 dB/100ft 88.5 MHz 2.2 dB/100ft 100 MHz 2.4 dB/100ft 135 MHz 2.8 dB/100ft 143 MHz 2.9 dB/100ft 180 MHz 3.3 dB/100ft 270 MHz 4.0 dB/100ft 360 MHz 4.7 dB/100ft 540 MHz 5.9 dB/100ft 720 MHz 6.9 dB/100ft 750 MHz 7.1 dB/100ft 1000 MHz 8.4 dB/100ft 1500 MHz 10.6 dB/100ft 2000 MHz 12.5 dB/100ft 2250 MHz 13.4 dB/100ft 3000 MHz 15.9 dB/100ft 4500 MHz 20.6 dB/100ft 6000 MHz 28.7 dB/100ft Delay Nominal Delay Nominal Velocity of Propagation (VP) [%] 1.27 ns/ft 80.0 % Voltage Non-UL Voltage Rating UL Voltage Rating 300 V RMS 300 V RMS Temperature Range UL Temp Rating: 75°C Operating Temp Range: -30°C To +75°C Mechanical Characteristics Bulk Cable Weight: 50 lbs/1000ft Max Recommended Pulling Tension: 90 lbs Min Bend Radius/Minor Axis: 2.75 in Standards NEC/(UL) Specification: CM RG Type: 6/U Type Applicable Environmental and Other Programs EU Directive 2000/53/EC (ELV): Yes EU Directive 2003/96/EC (BFR): Yes EU Directive 2011/65/EU (ROHS II): Yes EU Directive 2012/19/EU (WEEE): Yes EU Directive 2015/863/EU: Yes EU Directive Compliance: EU Directive 2003/11/EC (BFR) EU CE Mark: Yes EU RoHS Compliance Date (yyyy-mm-dd): 2004-01-01 CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Suitability Suitability - Indoor: Yes Flammability, LS0H, Toxicity Testing UL Flammability: UL 1685 - UL Loading UL voltage rating: 300 V RMS Plenum/Non-Plenum Plenum (Y/N): No Part Number Variants Item # 1694F B591000 Color Black, Matte 1694F B59N1000 Black, Matte 1694F B59N1000 Black, Matte UPC Length Footnote 612825356196 1,000 ft C 1,000 ft 1,000 ft 1694F G7X1000 Blue, Matte 612825356110 1,000 ft C 1694F G7W1000 Green, Matte 612825356127 1,000 ft C 1694F G8L1000 Orange, Matte 612825356097 1,000 ft C 1694F G7V1000 Red, Matte 612825356134 1,000 ft C 1694F Z4B1000 Violet Z4B 612825358176 1,000 ft C 1694F G7Y1000 White, Matte 612825356103 1,000 ft C 1694F G8M1000 Yellow, Matte 612825356080 1,000 ft C Footnote: C - CRATE REEL PUT-UP. History Update and Revision: Revision Number: 0.277 Revision Date: 08-22-2019 © 2019 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with all applicable environmental programs as listed in the data sheet. The information provided is correct to the best of Belden's knowledge, information and belief at the date of its publication. This information is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. The Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product.
1694F B591000 价格&库存
很抱歉,暂时无法提供与“1694F B591000”相匹配的价格&库存,您可以联系我们找货
