Detailed Specifications & Technical Data
ENGLISH MEASUREMENT VERSION
1823R Multi-Conductor - CMR Rated Cable
For more Information
please call
1-800-Belden1
General Description:
22 AWG stranded (7x30) TC conductor, polyolefin insulation, individually shielded with bonded Beldfoil®,
numbered/color-coded PVC jackets, jackets and shields are bonded so both strip simultaneously, overall
black PVC jacket and nylon rip cord.
Physical Characteristics (Overall)
Conductor
AWG:
# Pairs AWG Stranding Conductor Material Dia. (in.)
32
22
7x30
TC - Tinned Copper .030
Total Number of Conductors:
64
Insulation
Insulation Material:
Insulation Material Dia. (in.)
PO - Polyolefin
0.050
Inner Shield
Inner Shield Material:
Inner Shield Trade Name Type Inner Shield Material
Beldfoil®
Coverage (%)
Tape Aluminum Foil-Polyester Tape 100
Inner Shield Drain Wire AWG:
AWG
22
Inner Shield Drain Wire Stranding:
7x30
Inner Shield Drain Wire Conductor Material:
TC - Tinned Copper
Inner Jacket
Inner Jacket Material:
Nom. Dia. (in.)
PVC - Polyvinyl Chloride 0.133
Inner Jacket Color Code Chart:
Number Color
1
Brown
2
Red
3
Orange
4
Yellow
5
Green
6
Blue
7
Purple
8
Gray
9
White
10
Black
11
Tan
12
Pink
13
Gray/Brown
14
Gray/Red
15
Gray/Orange
16
Gray/Yellow
17
Gray/Green
18
Gray/Blue
19
Gray/Purple
Gray/Gray
21
Gray/White
22
Gray/Black
23
Gray/Tan
Page 1 of 3
08-26-2016
24
Gray/Pink
25
Blue/Brown
26
Blue/Red
27
Blue/Orange
28
Blue/Yellow
29
Blue/Green
30
Blue/Blue
31
Blue/Purple
32
Blue/Gray
Outer Shield
Outer Shield Material:
Outer Shield Trade Name Type Outer Shield Material
Beldfoil®
Coverage (%)
Outer Shield Drain Wire AWG:
AWG Stranding Drain Wire Conductor Material
18
19x30
TC - Tinned Copper
Outer Jacket
Outer Jacket Material:
Outer Jacket Ripcord:
Yes
Overall Cable
Overall Nominal Diameter:
1.072 in.
Pair
Pair Color Code Chart:
Color
Red and Black
Mechanical Characteristics (Overall)
Operating Temperature Range:
-20°C To +60°C
Bulk Cable Weight:
625 lbs/1000 ft.
Max. Recommended Pulling Tension:
898.300 lbs.
Min. Bend Radius/Minor Axis:
10 in.
Applicable Specifications and Agency Compliance (Overall)
Applicable Standards & Environmental Programs
NEC/(UL) Specification:
CMR
CEC/C(UL) Specification:
CMG
EU Directive 2011/65/EU (ROHS II):
Yes
EU CE Mark:
Yes
EU Directive 2000/53/EC (ELV):
Yes
EU Directive 2002/95/EC (RoHS):
Yes
EU RoHS Compliance Date (mm/dd/yyyy):
01/01/2004
EU Directive 2002/96/EC (WEEE):
Yes
EU Directive 2003/11/EC (BFR):
Yes
CA Prop 65 (CJ for Wire & Cable):
Yes
MII Order #39 (China RoHS):
Yes
Flame Test
CSA Flame Test:
FT4
Plenum/Non-Plenum
Plenum (Y/N):
No
Electrical Characteristics (Overall)
Nom. Characteristic Impedance:
Impedance (Ohm)
50
Nom. Inductance:
Inductance (µH/ft)
Page 2 of 3
08-26-2016
.18
Nom. Capacitance Conductor to Conductor:
Capacitance (pF/ft)
31
Nom. Capacitance Cond. to Other Conductor & Shield:
Capacitance (pF/ft)
56
Nominal Velocity of Propagation:
VP (%)
66
Nom. Conductor DC Resistance:
DCR @ 20°C (Ohm/1000 ft)
14.8
Ind. Pair Nominal Shield DC Resistance @ 20 Deg. C:
14.100 Ohm/1000 ft
Max. Operating Voltage - UL:
Voltage
300 V RMS
Max. Recommended Current:
Current
1.45 Amps per conductor @ 25°C
Notes (Overall)
Notes: Pair jackets and shields are bonded so both strip simultaneously with automatic stripping equipment.
Put Ups and Colors:
Item #
Putup
Ship Weight
Color
Notes
Item Desc
1823R 0101000
1,000 FT
695.000 LB
BLACK
C
32 #22 FS PR PVC FS PVC
1823R 0102000
2,000 FT
1,418.000 LB
BLACK
C
Notes:
C = CRATE REEL PUT-UP.
Revision Number: 1
Revision Date: 10-17-2012
© 2016 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to
change without notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for
any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether
in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities
and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is
correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the
safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification.
Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the
product.
Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU).
Page 3 of 3
08-26-2016
很抱歉,暂时无法提供与“1823R 0101000”相匹配的价格&库存,您可以联系我们找货
