Part Number: 2202ELV
Category 6A Nonbonded-Pair S/FTP LSZH Cable, CPR Euroclass B2ca
Product Description
Category 6A (500MHz), 4-Pair, S/FTP shielded, Premise Horizontal Cable, 23 AWG Solid Bare Copper conductors, Foam Polyolefin insulation, each pair with
Beldfoil® shield, tinned copper braid shield (30%), LSZH jacket, CPR Euroclass B2ca
Technical Specifications
Product Overview
Environmental Space:
Indoor - Euroclass B2ca
Suitable Applications:
Horizontal and building backbone cable; Support current and future Category 6A and 6 applications, such as: 10GBase-T (10 Gigabit Ethernet), 1000Base-T
(Gigabit Ethernet), 100 Base-T, 10 Base-T, FDDI, ATM
Physical Characteristics (Overall)
Conductor
Element
AWG Stranding
Individual shielded pair 23
Solid
Material
No. of Pairs
BC - Bare Copper 4
Conductor Count:
8
Total Number of Pairs:
4
Conductor Size:
23 AWG
Insulation
Element
Type
Material
Nominal Diameter
Individual shielded pair Dielectric FPE - Foamed Polyethylene 1.32 mm
Color Chart
Number
Color
Pair 1
White & Blue
Pair 2
White & Orange
Pair 3
White & Green
Pair 4
White & Brown
Inner Shield Material
Element
Type
Material
Coverage [%]
Individual shielded pair Tape Aluminum / Polyester 100 %
InnerShield, Table Note:
Aluminum facing outside
Outer Shield Material
Type
Material
Min. Coverage [%]
Braid TC - Tinned Copper 30 %
Outer Jacket Material
Material
Nominal Diameter Diameter +/- Tolerance Ripcord
LSZH / FRNC 7.5 mm
0.3 mm
Yes
Construction and Dimensions
Min Elongation at Breakof Conductors:
10 %
Min Elongation at Breakof Insulation:
100 %
Cabling
Description
4 pairs twisted together
Min Elongation at Breakof Jacket:
100 %
Min Tensile Strength of Jacket:
9 MPa
Electrical Characteristics
Conductor DCR
Max. Conductor DCR Max DCR Unbalanced Between Pairs [%] Max. DCR Unbalanced Within Pair [%]
95 Ohm/km
4%
2 Ohm
Capacitance
Max. Capacitance Unbalance Max. Mutual Capacitance
1,600 pF/m
56 pF/m
Shielding:
S/FTP - Overall Braid / Individual Foil
Impedance
Nominal Characteristic Impedance
100 Ohm
Delay
Max. Delay Skew Nominal Velocity of Propagation (VP) [%]
45 ns/100m
77 %
High Freq
Frequency
[MHz]
Max. Insertion Loss
(Attenuation)
Min.
NEXT
[dB]
Min.
PSNEXT
[dB]
Min.
ACR
[dB]
Min.
PSACR
[dB]
Min. ACRF
(ELFEXT) [dB]
Min. PSACRF
(PSELFEXT) [dB]
Min. RL
(Return Loss)
[dB]
Min.
PSANEXT
Min.
PSAACRF
Min.
Min.
TCL [dB] ELTCTL [dB]
1 MHz
2.1 dB/100m
75.3 dB
72.3 dB
73.2 dB
70.2 dB
68 dB
65 dB
20 dB
67 dB
67 dB
40 dB
35 dB
4 MHz
3.8 dB/100m
66.3 dB
63.3 dB
62.5 dB
59.5 dB
56 dB
53 dB
23 dB
67 dB
66.2 dB
34 dB
23 dB
10 MHz
5.9 dB/100m
60.3 dB
57.3 dB
54.4 dB
51.4 dB
48 dB
45 dB
25 dB
67 dB
58.2 dB
30 dB
15 dB
16 MHz
7.5 dB/100m
57.2 dB
54.2 dB
49.8 dB
46.8 dB
43.9 dB
40.9 dB
25 dB
67 dB
54.1 dB
28 dB
10.9 dB
31.2 MHz
10.5 dB/100m
52.9 dB
49.9 dB
42.4 dB
39.4 dB
38.1 dB
35.1 dB
23.6 dB
67 dB
48.3 dB
25.1 dB
5.1 dB
62.5 MHz
15 dB/100m
48.4 dB
45.4 dB
33.4 dB
30.4 dB
32.1 dB
29.1 dB
21.5 dB
65.6 dB
42.3 dB
22 dB
100 MHz
19.1 dB/100m
45.3 dB
42.3 dB
26.2 dB
23.2 dB
28 dB
25 dB
20.1 dB
62.5 dB
38.2 dB
20 dB
125 MHz
21.5 dB/100m
43.8 dB
40.8 dB
22.3 dB
19.3 dB
26.1 dB
23.1 dB
19.4 dB
61 dB
36.3 dB
19 dB
200 MHz
27.6 dB/100m
40.8 dB
37.8 dB
13.2 dB
10.2 dB
22 dB
19 dB
18 dB
58 dB
32.2 dB
17 dB
250 MHz
31.1 dB/100m
39.3 dB
36.3 dB
8.3 dB
5.3 dB
20 dB
17 dB
17.3 dB
56.5 dB
30.2 dB
16 dB
300 MHz
34.3 dB/100m
38.1 dB
35.1 dB
3.9 dB
0.9 dB
18.5 dB
15.5 dB
17.3 dB
55.3 dB
28.7 dB
500 MHz
45.3 dB/100m
34.8 dB
31.8 dB
-10.4 dB
-13.4 dB
14 dB
11 dB
17.3 dB
52 dB
24.2 dB
High Freq Table Note:
Limits below 4MHz and at 625MHz are for information only.
Coupling Attenuation Class:
Type II
Transfer Impedance
Frequency [MHz] Description Transfer Impedance
1 Mhz
Grade 2
Max.50 mOhm/m
10 Mhz
Max. 100 mOhm/m
30 Mhz
Max. 200 mOhm/m
100 Mhz
Max. 1000 mOhm/m
Transfer Impedance Class:
Grade 2
Current
Max. Recommended Current [A]
1.5 A
Voltage
Voltage Rating [V]
72 V
Temperature Range
Installation Temp Range:
0°C To +50°C
Operating Temp Range:
-30°C To +60°C
Mechanical Characteristics
Bulk Cable Weight:
60 kg/km
Max Recommended Pulling Tension:
85 N
Min Bend Radius During Installation:
58 mm
Min Bend Radius During Operation:
29 mm
Standards
ISO/IEC Compliance:
ISO/IEC 11801 Ed. 2.2:2002/A2:2010/C1:2011
CPR Euroclass:
B2ca-s1,d1,a1
CENELEC Compliance:
EN 50173-1 Ed. 3:2011
Data Category:
Category 6A
ANSI Compliance:
ANSI/TIA/EIA 568-B.2-1 (2002)
Applicable Environmental and Other Programs
EU RoHS Compliance Date (yyyy-mm-dd):
2018-01-03
Flammability, LS0H, Toxicity Testing
ISO/IEC Flammability:
IEC 60332-1
Burning Load:
650 kJ/m
Amount of Halogen acc. to IEC 60754-1 &
EN50267-1:
Zero
Part Number
Patent:
https://www.belden.com/resources/patents
History
Revision Number:
1
© 2018 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without
notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages
(including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract,
negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with all applicable environmental programs as listed in the data sheet. The information provided is correct to the best of Belden's knowledge, information and belief
at the date of its publication. This information is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. The Product
Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and
regulations based on their individual usage of the product.
很抱歉,暂时无法提供与“2202ELV.00500”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+24.315711+3.14140
- 100+19.24265100+2.48600
- 300+17.23092300+2.22610
- 500+15.21919500+1.96620
