Detailed Specifications & Technical Data
ENGLISH MEASUREMENT VERSION
29501 Multi-Conductor - 1000V UL Flexible Motor Supply Cable
For more Information
please call
1-800-Belden1
General Description:
4-cond. (3) stranded tinned copper circuit conductors plus(1) ground wire with PVC insulation, XLPE
insulation, overall Duofoil® (100% coverage) plus a tinned copper braid shield (85% coverage) , tinned
copper drain wire, sun- & oil-resistant PVC jacket.
Usage (Overall)
Suitable Applications:
AC Motor Drives, VFD, Variable Frequency Drive
Physical Characteristics (Overall)
Conductor
AWG:
# Conductors AWG Stranding Conductor Material
3
14
41x30
TC - Tinned Copper
Total Number of Conductors:
3
Ground Wire
Ground Wire (Y/N):
Y
Ground Wire AWG:
14
Ground Wire Stranding:
41x30
Ground Wire Conductor Material:
TC - Tinned Copper
Ground Wire Insulation Material:
PVC - Polyvinyl Chloride
Insulation
Insulation Material
Wall Thickness (in.)
XLP - Cross-Linked Polyolefin 0.045
Insulation Resistance:
300 Megaohms/1000 ft.
Insulation Color Code Chart:
Number Color
1
Black and Numbered 1
2
Black and Numbered 2
3
Black and Numbered 3
3
Green/Yellow
Outer Shield
Outer Shield Material:
Layer # Outer Shield Trade Name Type Outer Shield Material
1
Duofoil®
Coverage (%)
Tape Aluminum Foil-Polyester Tape 100
2
Braid TC - Tinned Copper
85
Outer Shield Drain Wire AWG:
AWG Stranding Drain Wire Conductor Material
14
41x30
TC - Tinned Copper
Outer Jacket
Outer Jacket Material:
Nom. Wall Thickness (in.)
PVC - Polyvinyl Chloride 0.073
Overall Cable
Overall Nominal Diameter:
0.604 in.
Mechanical Characteristics (Overall)
Wet Temperature Range:
-40°C To +90°C
Dry Temperature Range:
-40°C To +90°C
Bulk Cable Weight:
190 lbs/1000 ft.
Page 1 of 3
08-26-2016
Max. Recommended Pulling Tension:
212 lbs.
Min. Bend Radius/Minor Axis:
4.800 in.
Applicable Specifications and Agency Compliance (Overall)
Applicable Standards & Environmental Programs
NEC/(UL) Specification:
TC-ER, Unlisted Singles, WTTC
NEC Articles:
336 - ER
CEC/C(UL) Specification:
600V Type CIC TC
CSA Specification:
1000 V AWM I/II A/B
EU Directive 2011/65/EU (ROHS II):
Yes
EU CE Mark:
Yes
EU Directive 2000/53/EC (ELV):
Yes
EU Directive 2002/95/EC (RoHS):
Yes
EU RoHS Compliance Date (mm/dd/yyyy):
10/13/2005
EU Directive 2002/96/EC (WEEE):
Yes
EU Directive 2003/11/EC (BFR):
Yes
CA Prop 65 (CJ for Wire & Cable):
Yes
MII Order #39 (China RoHS):
Yes
PMSHA Specification:
P-07-KA070003
Other Specification:
Flame Test
UL Flame Test:
UL1685 UL Loading
CSA Flame Test:
FT4
IEEE Flame Test:
1202, IEEE 383 Vertical Tray Flame Test (70,000 BTU)
Suitability
Suitability - Indoor:
Yes
Suitability - Outdoor:
Yes
Suitability - Burial:
Yes
Sunlight Resistance:
Yes
Oil Resistance:
Yes
Electrical Characteristics (Overall)
Nom. Characteristic Impedance:
Impedance (Ohm)
80
Nom. Inductance:
Inductance (µH/ft)
.213
Nom. Capacitance Conductor to Conductor:
Capacitance (pF/ft)
23
Nom. Capacitance Cond. to Other Conductor & Shield:
Capacitance (pF/ft)
42
Nom. Conductor DC Resistance:
DCR @ 20°C (Ohm/1000 ft)
2.52
Max. Operating Voltage - UL:
Voltage
1000 V RMS (Flexible Motor Supply Cable)
600 V RMS (NEC Type TC)
Max. Operating Voltage - Other:
Voltage
Description
1000 V RMS CSA AWM I/II A/B
Max. Recommended Current:
Page 2 of 3
08-26-2016
Current
25 Amps per conductor @ 30°C (per NEC)
Put Ups and Colors:
Item #
Putup
Ship Weight
Color
29501 010100
100 FT
27.000 LB
BLACK
Notes
Item Desc
29501 0101000
1,000 FT
238.000 LB
BLACK
CZ
#14/4C XLPE SHPVC
29501 010250
250 FT
61.000 LB
BLACK
CZ
#14/4C XLPE SHPVC
29501 010500
500 FT
119.500 LB
BLACK
CZ
#14/4C XLPE SHPVC
29501 0105000
5,000 FT
1,240.000 LB
BLACK
CZ
#14/4C XLPE SH PVC
#14/4C XLPE SH PVC
Notes:
C = CRATE REEL PUT-UP.
Z = FINAL PUT-UP LENGTH MAY VARY (+ OR -) 10% FOR SPOOLS OR REELS AND(+ OR -) 5% FOR UNREEL CARTONS FROM LENGTH SHOWN.
Revision Number: 2
Revision Date: 04-04-2016
© 2016 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to
change without notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for
any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether
in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities
and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is
correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the
safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification.
Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the
product.
Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU).
Page 3 of 3
08-26-2016
很抱歉,暂时无法提供与“29501 010100”相匹配的价格&库存,您可以联系我们找货
