30808 009100
30808 009100
    BELDEN
    BELDEN - 30808 009100 - HOOK UP WIRE, 8AWG, 100FT, COPPER, WHITE
30808 009100 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 30808 Hook-up/Lead - UL AWM Style 3125 For more Information please call 1-800-Belden1 General Description: The glass braid offers abrasion resistance, is treated to prevent fraying.The Silicone insulation strips easy and clean.Recommended for high-temperature applications in motors, lighting fixtures, clothes dryers, stoves, therapeutic and electronic devices Physical Characteristics (Overall) Conductor AWG: # Conductors AWG Stranding Conductor Material 1 8 54x25 TC - Tinned Copper Total Number of Conductors: 1 Insulation Insulation Material: Insulation Material Wall Thickness (in.) Silicone with Lacquered Glass Braid Covering .060 Separator Separator Material over Conductor: Y Overall Insulation Overall Cable Overall Nominal Diameter: 0.313 in. Mechanical Characteristics (Overall) UL Temperature Rating: 200°C (UL AWM Style 3125) Bulk Cable Weight: 96 lbs/1000 ft. Recommended Maximum Baking Cycles: 24 hours @ 410°F (210°C) Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs UL AWM Style: UL Style 3125 (600 V 200°C) UL Rating: 600 V, 200°C, VW-1 CSA Rating: 600 V, 200°C CSA Type: SEW-2 EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Max. Operating Voltage - UL: Voltage 600 V RMS (UL AWM Style 3125) Page 1 of 2 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 30808 Hook-up/Lead - UL AWM Style 3125 Put Ups and Colors: Item # Putup Ship Weight Color 30808 009100 100 FT 9.500 LB WHITE Notes Item Desc 30808 009500 500 FT 46.500 LB WHITE 30808 010100 100 FT 9.500 LB BLACK 30808 0103000 3,000 FT 276.000 LB BLACK CG #8 SIL GL BRD 200C 600V 30808 010500 500 FT 46.500 LB BLACK CF #8 SIL GL BRD 200C 600V #8 SIL GL BRD 200C 600V CF #8 SIL GL BRD 200C 600V #8 SIL GL BRD 200C 600V Notes: C = CRATE REEL PUT-UP. F = MAY CONTAIN MORE THAN 1 PIECE. MINIMUM LENGTH OF ANY ONE PIECE IS 50' G = MAY CONTAIN MORE THAN 1 PIECE. MINIMUM LENGTH OF ANY ONE PIECE IS 100' Revision Number: 2 Revision Date: 09-30-2009 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 2 of 2 01-05-2017
30808 009100 价格&库存
很抱歉,暂时无法提供与“30808 009100”相匹配的价格&库存,您可以联系我们找货
