Part Number: 49726A
D-Subminiature Assembly, 10 ft, (15) 24 AWG (7x32) TC, S-R PVC/PVC, Foil
Shld, CM
Product Description
Fifteen 24 AWG stranded (7x32) tinned copper conductors, S-R PVC insulation, Beldfoil® shield, PVC jacket, ten foot length.
Technical Specifications
Physical Characteristics (Overall)
Conductor
AWG Stranding
24
7x32
Material
Nominal Diameter No. of Conductors
TC - Tinned Copper 0.024 in
Conductor Count:
15
AWG Size:
24
15
Insulation
Material
Nominal Wall Thickness
S-R PVC - Semi-Rigid Polyvinyl Chloride 0.01 in
Outer Shield Material
Type
Material
Material Trade Name Coverage [%] Drainwire Material
Tape Aluminum Foil-Polyester Tape Beldfoil®
100 %
Drainwire AWG Drainwire Construction n x D
TC - Tinned Copper 24
Outer Jacket Material
Material
Nominal Diameter Nominal Wall Thickness
PVC - Polyvinyl Chloride 0.284 in
0.032 in
Construction and Dimensions
Stranding
Lay Length
Point to Point. Pin #1 on end 1 to Pin #1 on end 2, Pin #2 to Pin #2, etc. Cable shield connected to connector shell. mm
Electrical Characteristics
Voltage
UL Voltage Rating
300V RMS (UL AWM Style 2464)
Temperature Range
UL Temp Rating:
80°C (UL AWM Style 2464)
Standards
NEC/(UL) Specification:
CM (cable only)
UL AWM Style:
UL Style 2464 (300 V 80°C) (cable only)
Applicable Environmental and Other Programs
EU Directive Compliance:
EU Directive 2003/11/EC (BFR)
CA Prop 65 (CJ for Wire &
Cable):
Yes
7x32 mm
MII Order #39 (China
RoHS):
Yes
Part Number
Plenum (Y/N):
No
Variants
Item #
Color
49726A 060S2 CHROME
Product Notes
Notes:
Molded handles are 100% shielded to assist in FCC compliance and guard against EMI/RFI. All connectors tin-plated and male connectors have detents for positive ground
connection. Wiring is point-to-point with the shield to connector shell.
© 2018 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without
notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages
(including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract,
negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with EU RoHS(Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be instock at Belden facilities and in our Distributor's
inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden's knowledge,
information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product
itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for
determining the applicability of legislation and regulations based on their individual usage of the product.
Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 73/23/EEC), as amended by directive 93/68/EEC.
很抱歉,暂时无法提供与“49726A 060S2”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+5507.517471+706.39828
