5500FE.00152
5500FE.00152
    BELDEN
    BELDEN - 5500FE.00152 - Multicore Cable, Security Audio, Screened, 2 Core, 22 AWG, 0.324 mm², 498.69...
5500FE.00152 数据手册
Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 5500FE Multi-Conductor - Commercial Audio Systems - 2 Conductors Cabled For more Information please call 1-800-Belden1 General Description: Security & Alarm Cable, Riser-CMR, 2-22 AWG stranded bare copper conductors with polyolefin insulation, Beldfoil® shield and PVC jacket with ripcord Usage (Overall) Suitable Applications: Intercom/PA Systems, Sound/Audio Systems Physical Characteristics (Overall) Conductor AWG: # Conductors AWG Stranding Conductor Material 2 22 7x30 BC - Bare Copper Total Number of Conductors: 2 Insulation Insulation Material: Insulation Material Wall Thickness (mm) PP - Polypropylene 0.203 Outer Shield Outer Shield Material: Outer Shield Trade Name Type Outer Shield Material Beldfoil® Coverage (%) Tape Aluminum Foil-Polyester Tape w/Shorting Fold 100 Outer Shield Drain Wire AWG: AWG Stranding Drain Wire Conductor Material 24 Solid TC - Tinned Copper Outer Jacket Outer Jacket Material: Outer Jacket Material Nom. Wall Thickness (mm) PVC - Polyvinyl Chloride 0.432 Outer Jacket Ripcord: Yes Overall Cable Overall Cabling Lay Length & Direction: Length (mm) Direction Twists (twist/m) 63.500 Left Hand 15.749 Overall Cabling Color Code Chart: Number Color 1 Black 2 Red Overall Nominal Diameter: 3.200 mm Mechanical Characteristics (Overall) Operating Temperature Range: -20°C To +75°C UL Temperature Rating: 75°C Bulk Cable Weight: 14.138 Kg/Km Page 1 of 3 10-30-2013 Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 5500FE Multi-Conductor - Commercial Audio Systems - 2 Conductors Cabled Max. Recommended Pulling Tension: 105.422 N Min. Bend Radius/Minor Axis: 31.750 mm Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMR NEC Articles: 800 CEC/C(UL) Specification: CMG EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 04/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Flame Test UL Flame Test: UL1666 Vertical Shaft C(UL) Flame Test: FT4 Suitability Suitability - Indoor: Yes Plenum/Non-Plenum Plenum Number: 6500FE Surface Printing (Overall) Electrical Characteristics (Overall) Nom. Capacitance Conductor to Conductor: Capacitance (pF/m) 113.195 Nom. Capacitance Cond. to Other Conductor & Shield: Capacitance (pF/m) 203.422 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/km) 52.8241 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/km) 52.8241 Max. Operating Voltage - UL: Voltage 300 V RMS Max. Recommended Current: Description Current 10C Temperature Rise 2.8 Amps per conductor @ 25°C ambient Put Ups and Colors: Page 2 of 3 10-30-2013 Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 5500FE Multi-Conductor - Commercial Audio Systems - 2 Conductors Cabled Item # Putup Ship Weight Color 5500FE 008U1000 305 MT 4.990 KG GRAY 2 #22 PP FS FRPVC 5500FE 008U500 152 MT 2.722 KG GRAY 2 #22 PP FS FRPVC 5500FE 0081000 305 MT 4.990 KG GRAY 2 #22 PP FS FRPVC 5500FE 008500 152 MT 2.495 KG GRAY 2 #22 PP FS FRPVC 5500FE 009U1000 305 MT 4.990 KG WHITE 2 #22 PP FS FRPVC 5500FE 010U1000 305 MT 4.990 KG BLACK 2 #22 PP FS FRPVC Revision Number: 3 Notes Item Desc Revision Date: 10-02-2013 © 2013 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 73/23/EEC), as amended by directive 93/68/EEC. Page 3 of 3 10-30-2013
5500FE.00152 价格&库存
很抱歉,暂时无法提供与“5500FE.00152”相匹配的价格&库存,您可以联系我们找货
5500FE.00152
  • 1+14.326391+1.85320
  • 50+11.5310050+1.49160
  • 100+10.13330100+1.31080
  • 152+8.99767152+1.16390
5500FE.00152
  • 1+1222.11585
库存:304
