6546PA 0081000
6546PA 0081000
    BELDEN
    CBL 8PR 22AWG FEP SHLD
6546PA 0081000 数据手册
Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 6546PA Multi-Conductor - Pro Audio and Intercom Systems For more Information please call 1-800-Belden1 General Description: Security, Pro Audio & Intercom Cable, Plenum-CMP, 8-22 AWG stranded bare copper pairs with FEP insulation, Individually Beldfoil® shielded and PVDF jacket with ripcord Physical Characteristics (Overall) Conductor AWG: # Pairs AWG Stranding Conductor Material Dia. (mm) 8 22 7x30 BC - Bare Copper 0.7366 Total Number of Conductors: 16 Insulation Insulation Material: Insulation Trade Name Insulation Material Teflon® Wall Thickness (mm) Dia. (mm) FEP - Fluorinated Ethylene Propylene 0.254 1.2446 Inner Shield Inner Shield Material: Inner Shield Trade Name Type Inner Shield Material Beldfoil® Coverage (%) Tape Aluminum Foil-Polyester Tape 100 Inner Shield Drain Wire AWG: AWG 24 Inner Shield Drain Wire Conductor Material: TC - Tinned Copper Outer Shield Outer Shield Material: Outer Shield Material Unshielded Outer Jacket Outer Jacket Material: Outer Jacket Material Nom. Wall Thickness (mm) PVDF - Fluorocopolymer 0.4318 Outer Jacket Ripcord: Yes Overall Cable Overall Nominal Diameter: 8.433 mm Pair Pair Color Code Chart: Number Color 1 Black & Red 2 Black & White 3 Black & Green 4 Black & Blue 5 Black & Yellow 6 Black & Brown 7 Black & Orange 8 Red & White Pair Lay Length & Direction: Lay Length (mm) Twists (twist/m) 34.925 22.639 Mechanical Characteristics (Overall) Operating Temperature Range: -20°C To +150°C UL Temperature Rating: 75°C Bulk Cable Weight: 115.336 Kg/Km Page 1 of 3 09-11-2017 Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 6546PA Multi-Conductor - Pro Audio and Intercom Systems Bulk Cable Weight: 115.336 Kg/Km Max. Recommended Pulling Tension: 794.449 N Min. Bend Radius/Minor Axis: 82.550 mm Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMP CEC/C(UL) Specification: CMP EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 04/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Flame Test UL Flame Test: NFPA 262 C(UL) Flame Test: FT6 Plenum/Non-Plenum Plenum (Y/N): Yes Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 50 Nom. Inductance: Inductance (µH/m) 0.59058 Nom. Capacitance Conductor to Conductor: Capacitance (pF/m) 90.2275 Nom. Capacitance Cond. to Other Conductor & Shield: Capacitance (pF/m) 162.41 Nominal Velocity of Propagation: VP (%) 69 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/km) 53.8084 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/km) 50.1993 Max. Operating Voltage - UL: Voltage 300 V RMS Max. Recommended Current: Current 1.5 Amps per conductor @ 25°C Notes (Overall) Notes: Teflon® is a registered trademark of E. I. duPont de Nemours and Co. used under license by Belden, Inc. Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 6546PA 0081000 1,000 FT 85.000 LB GRAY C 8 FS PR #22 FEP SLF Page 2 of 3 09-11-2017 Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 6546PA Multi-Conductor - Pro Audio and Intercom Systems Notes: C = CRATE REEL PUT-UP. Revision Number: 1 Revision Date: 03-13-2013 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 3 of 3 09-11-2017
6546PA 0081000 价格&库存
很抱歉,暂时无法提供与“6546PA 0081000”相匹配的价格&库存,您可以联系我们找货
