7924A 0101000
7924A 0101000
    BELDEN
    BELDEN - 7924A 0101000 - UNSHIELDED MULTIPAIR CABLE 4PR 1000FT 30
7924A 0101000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 7924A Multi-Conductor - Category 5e DataTuff® Twisted Pair Cable For more Information please call 1-800-Belden1 General Description: 24 AWG Bonded-Pairs stranded (7x32) tinned copper conductors, polyolefin insulation, industrial grade sunlight- and oil-resistant PVC jacket. Sequential marking at two foot intervals. Usage (Overall) Suitable Applications: Industrial Ethernet Cable, Harsh Environments, 350MHz Enhanced Category 5e, Gigabit Ethernet, 100BaseTX, 100BaseVG ANYLAN, 155ATM, 622ATM, NTSC/PAL Component or Composite Video, AES/EBU Digital Audio, AES51, RS-422, CMX - Outdoor, RJ-45 Compatible, Flexible Applications Physical Characteristics (Overall) Conductor AWG: # Pairs AWG Stranding Conductor Material Dia. (in.) 4 24 7x32 TC - Tinned Copper .022 Total Number of Conductors: 8 Insulation Insulation Material: Insulation Material Wall Thickness (in.) Dia. (in.) PO - Polyolefin 0.008 0.042 Outer Shield Outer Shield Material: Outer Shield Material Unshielded Outer Jacket Outer Jacket Material: Outer Jacket Material Nom. Wall Thickness (in.) Industrial Grade PVC - Polyvinyl Chloride .030 Overall Cable Overall Nominal Diameter: 0.242 in. Pair Pair Color Code Chart: Number Color 1 White/Orange Stripe & Orange 2 White/Blue Stripe & Blue 3 White/Green Stripe & Green 4 White/Brown Stripe & Brown Mechanical Characteristics (Overall) Storage Temperature Range: -40°C To +80°C Installation Temperature Range: -25°C To +75°C Operating Temperature Range: -40°C To +75°C Bulk Cable Weight: 26 lbs/1000 ft. Max. Recommended Pulling Tension: 40 lbs. Min. Bend Radius/Minor Axis: 2.500 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMR, CMX-Outdoor, UL444 CEC/C(UL) Specification: CMR EU Directive 2011/65/EU (ROHS II): Yes EU Directive 2000/53/EC (ELV): Yes Page 1 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 7924A Multi-Conductor - Category 5e DataTuff® Twisted Pair Cable EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Other Specification: NEMA WC-63.1 Category 5, ICEA 661, Category 5e Patch, UL verified to TIA/EI-568-B.2, Category 5e Applicable Patents: Country www.belden.com/p Flame Test UL Flame Test: UL1666 Riser CSA Flame Test: FT4 IEEE Flame Test: 1202 Suitability Suitability - Indoor: Yes Suitability - Outdoor: Yes Sunlight Resistance: Yes Oil Resistance: Yes Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Mutual Capacitance: Capacitance (pF/ft) 15 Maximum Capacitance Unbalance (pF/100 m): 66 Nominal Velocity of Propagation: VP (%) 70 Maximum Delay: Delay (ns/100 m) 510 Max. Delay Skew: Delay Skew (ns/100 m) 25 Maximum Conductor DC Resistance: DCR @ 20°C (Ohm/100 m) 9 Max. Operating Voltage - UL: Voltage 300 V RMS Maximum DCR Unbalanced: DCR Unbalance @ 20°C (%) 3 Electrical Characteristics-Premise (Overall) Premise Cable Electrical Table 1: Freq. (MHz) Max. Attenuation (dB/100 m) Min. NEXT (dB) Min. PSNEXT (dB) Min. PSACR (dB) Min RL (dB) 1 2.4 65.3 65.3 62.9 20.0 4 4.8 56.3 56.3 51.5 23.0 8 6.8 51.8 51.8 45.0 24.5 10 7.7 50.3 50.3 42.6 25.0 16 9.7 47.3 47.3 37.5 25.0 20 11.0 45.8 45.8 34.8 25.0 25 12.4 44.3 44.3 31.9 24.3 31.25 13.9 42.9 42.9 29.0 23.6 62.5 20.2 38.4 38.4 18.3 21.5 Page 2 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 7924A Multi-Conductor - Category 5e DataTuff® Twisted Pair Cable 100 26.0 35.3 35.3 9.2 20.1 155 33.2 32.5 32.5 0 19.0 200 38.4 30.8 30.8 19.0 250 43.7 29.3 29.3 18.0 300 48.6 28.2 28.2 18.0 310 49.5 27.9 27.9 18.0 350 53.2 27.2 27.2 17.0 Premise Cable Electrical Table 2: Freq. (MHz) Input (Unfitted) Imp. (Ohms) Fitted Impedance Min. ELFEXT (dB) Min. PSELFEXT (dB) 1 100 ± 12 105 ± 10 63.8 60.8 4 100 ± 12 100 ± 10 51.7 48.7 8 100 ± 12 100 ± 10 45.7 42.7 10 100 ± 12 100 ± 10 43.8 40.8 16 100 ± 12 100 ± 10 39.7 36.7 20 100 ± 12 100 ± 10 37.7 34.7 25 100 ± 15 100 ± 10 35.8 32.8 31.25 100 ± 15 100 ± 10 33.9 30.9 62.5 100 ± 15 100 ± 10 27.8 24.8 100 100 ± 18 100 ± 10 23.8 20.8 155 100 ± 18 100 ± 10 19.9 16.9 200 100 ± 20 100 ± 10 17.7 14.7 250 100 ± 20 100 ± 10 15.8 12.8 300 100 ± 20 100 ± 10 14.2 11.2 310 100 ± 20 100 ± 10 13.9 10.9 350 100 ± 22 100 ± 10 12.9 9.9 Notes (Overall) Notes: EtherNet/IP is a trademark of ControlNet Internation, Ltd. under license by Open DeviceNet Vendor Association, Inc. Operating temperatures are subject to length de-rating. Cable passes -40C Cold Bend per UL 1581. Notes (Cont'd.): T568A Plug Compatible Part Number: R301603 T568B Plug Compatible Part Number: R301604 Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 7924A 0021000 1,000 FT 30.000 LB RED C 4 PR #24 PP PVC 7924A 0061000 1,000 FT 30.000 LB BLUE, LIGHT C 4 PR #24 PP PVC 7924A 0081000 1,000 FT 30.000 LB GRAY C 4 PR #24 PP PVC 7924A 0101000 1,000 FT 30.000 LB BLACK C 4 PR #24 PP PVC 7924A 0102000 2,000 FT 58.000 LB BLACK C 4 PR #24 PP PVC 7924A 0105000 5,000 FT 145.000 LB BLACK C 4 PR #24 PP PVC 7924A 1NH1000 1,000 FT 30.000 LB TEAL 1NH C 4 PR #24 PP PVC Notes: C = CRATE REEL PUT-UP. Revision Number: 7 Revision Date: 01-05-2017 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 3 of 3 01-05-2017
7924A 0101000 价格&库存
很抱歉,暂时无法提供与“7924A 0101000”相匹配的价格&库存,您可以联系我们找货
7924A 0101000
  • 1+2283.511521+295.80769
7924A 0101000
  • 1+7794.81952
库存:915
7924A 0101000
  • 1+46.863671+6.07076
  • 5+41.884875+5.42580
  • 10+39.8771910+5.16572
  • 25+37.3658825+4.84041
  • 50+35.5530150+4.60557
  • 100+33.81787100+4.38079
库存:16574
7924A 0101000
  • 1000+21.137811000+2.73821
库存:16574
