7933A 1NH1000
7933A 1NH1000
    BELDEN
    CBL 2 BONDED PR 24AWG CAT5E SHLD
7933A 1NH1000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 7933A Multi-Conductor - Category 5e DataTuff® Twisted Pair Cable For more Information please call 1-800-Belden1 General Description: 24 AWG Bonded-Pairs solid bare copper conductors, polyolefin insulation, overall Beldfoil® shield (100% coverage) with drain wire, .030" industrial grade sunlight- and oil-resistant PVC jacket, drain wire. Sequential marking at two foot intervals. Usage (Overall) Suitable Applications: Industrial Ethernet, Harsh Environments, 200MHz Category 5e, M-12 Compatible, 100Base TX, 100BaseVG ANYLAN, 155A TM, 622A TM, NTSC/PAL Component or Composite Video, AES/EBU Digital Audio, AES51, RS-422, Noisy Environments, RJ-45 Compatible, EtherNet/IP Physical Characteristics (Overall) Conductor AWG: # Pairs AWG Stranding Conductor Material 2 24 Solid BC - Bare Copper Total Number of Conductors: 4 Insulation Insulation Material: Insulation Material PO - Polyolefin Outer Shield Outer Shield Material: Outer Shield Trade Name Type Outer Shield Material Beldfoil® Coverage (%) Tape Aluminum Foil-Polyester Tape 100 Outer Shield Drain Wire AWG: AWG Stranding Drain Wire Conductor Material 24 7x32 TC - Tinned Copper Outer Jacket Outer Jacket Material: Outer Jacket Material Industrial Grade PVC - Polyvinyl Chloride Overall Cable Overall Nominal Diameter: 0.235 in. Pair Pair Color Code Chart: Number Color 1 White/Orange Stripe & Orange 2 White/Green Stripe & Green Mechanical Characteristics (Overall) Storage Temperature Range: -40°C To +85°C Installation Temperature Range: -25°C To +75°C Operating Temperature Range: -40°C To +75°C Bulk Cable Weight: 30 lbs/1000 ft. Max. Recommended Pulling Tension: 20 lbs. Min. Bend Radius/Minor Axis: 0.500 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMR CEC/C(UL) Specification: CMR Page 1 of 3 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 7933A Multi-Conductor - Category 5e DataTuff® Twisted Pair Cable EU Directive 2011/65/EU (ROHS II): Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Other Specification: NEMA WC-63.1 Category 5e, UL verified to Category 5e, EtherNet/IP Compliant Applicable Patents: Country www.belden.com/p Flame Test UL Flame Test: UL1666 Riser CSA Flame Test: FT4 IEEE Flame Test: 1202 Suitability Suitability - Outdoor: Yes Sunlight Resistance: Yes Oil Resistance: Yes Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Mutual Capacitance: Capacitance (pF/ft) 15 Maximum Capacitance Unbalance (pF/100 m): 150 Nominal Velocity of Propagation: VP (%) 70 Maximum Delay: Delay (ns/100 m) 538 @ 100MHz Max. Delay Skew: Delay Skew (ns/100 m) 45 Maximum Conductor DC Resistance: DCR @ 20°C (Ohm/100 m) 9.38 Max. Operating Voltage - UL: Voltage 300 V RMS Maximum DCR Unbalanced: DCR Unbalance @ 20°C (%) 3 Electrical Characteristics-Premise (Overall) Premise Cable Electrical Table 1: Freq. (MHz) Max. Attenuation (dB/100 m) Min. NEXT (dB) Min. PSNEXT (dB) Min. ACR (dB) Min. PSACR (dB) Min RL (dB) Min. SRL (dB) 1 2.0 65.3 62.3 63.0 60.0 20.0 23 4 4.1 56.3 53.3 51.0 49.0 23.6 23.0 8 5.8 51.8 48.8 46.0 43.0 25.4 24.5 10 6.5 50.3 47.3 43.0 41.0 26.0 25.0 16 8.2 47.3 44.3 39.0 36.0 26.0 25.0 20 9.3 45.8 42.8 36.5 33.5 26.0 25.0 25 10.4 44.3 41.3 33.9 30.9 25.5 24.3 31.25 11.7 42.9 39.9 31.0 28.0 25.0 23.6 Page 2 of 3 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 7933A Multi-Conductor - Category 5e DataTuff® Twisted Pair Cable 62.5 17.0 38.4 35.4 22.0 19.0 23.5 21.5 100 22.0 35.3 32.3 14.0 11.0 22.5 20.1 155 28.1 32.5 29.5 4.4 1.4 15.8 200 32.0 30.8 27.8 4.0 1.0 15.0 Premise Cable Electrical Table 2: Freq. (MHz) Input (Unfitted) Imp. (Ohms) Fitted Impedance Min. ELFEXT (dB) Min. PSELFEXT (dB) 1 100 ± 15 102.5 ± 7.5 63.8 60.8 4 100 ± 15 102.5 ± 7.5 51.7 48.7 8 100 ± 15 101 ± 6 45.7 42.7 10 100 ± 15 101 ± 6 43.8 40.8 16 100 ± 15 101 ± 6 39.7 36.7 20 100 ± 15 101 ± 6 37.7 34.7 25 100 ± 15 101 ± 6 35.8 32.8 31.25 100 ± 15 101 ± 6 33.9 30.9 62.5 100 ± 15 101 ± 6 27.8 24.8 100 100 ± 15 101 ± 6 23.8 20.8 155 100 ± 25 100 ± 15 19.9 16.9 200 100 ± 25 100 ± 15 17.7 14.7 Notes (Overall) Notes: EtherNet IP is a trademark of ControlNet International Ltd. under license by DeviceNet Vendor Assoication, Inc. Operating Temperature subject to length de-rating. Notes (Cont'd.): Cable passes -40C Cold Bend per UL 1581. T568A Plug Compatible Part Number: R301603 T568B Plug Compatible Part Number: R301604 Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 7933A 0101000 1,000 FT 33.000 LB BLACK C 2 PR #24 PP FS FRPVC 7933A 0102000 2,000 FT 66.000 LB BLACK C 2 PR #24 PP FS FRPVC 7933A 1NH1000 1,000 FT 33.000 LB TEAL 1NH C 2 PR #24 PP FS FRPVC Notes: C = CRATE REEL PUT-UP. Revision Number: 9 Revision Date: 07-19-2016 © 2016 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 3 of 3 08-26-2016
7933A 1NH1000
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一种光耦器件。
2. 器件简介:EL817是一种通用型高速光耦器件,具有较高的响应速度和CMOS兼容性。
3. 引脚分配:EL817有6个引脚,其中1脚为发光二极管的阳极,2脚为阴极,3脚为集电极,4脚为发射极,5脚为GND,6脚为Vcc。
4. 参数特性:主要参数包括Vcc的范围为4.5V至5.5V,Ic的最大值为50mA,Ctr的范围为2%至10%。
5. 功能详解:EL817通过光电效应实现电信号的隔离,适用于高速数字电路。
6. 应用信息:广泛应用于高速数字电路、通信设备、工业控制系统等领域。
7. 封装信息:采用DIP-6封装形式。
7933A 1NH1000 价格&库存
很抱歉,暂时无法提供与“7933A 1NH1000”相匹配的价格&库存,您可以联系我们找货
7933A 1NH1000
  • 1+36.603111+4.75730
  • 50+28.9521050+3.76290
  • 100+25.82215100+3.35610
  • 305+22.86608305+2.97190
7933A 1NH1000
    • 1000+17.350891000+2.25510
