Detailed Specifications & Technical Data
ENGLISH MEASUREMENT VERSION
8777 Multi-Conductor - Shielded Twisted Pair Cable
For more Information
please call
1-800-Belden1
General Description:
22 AWG stranded (7x30) tinned copper conductors, polypropylene insulation, twisted pairs individually
Beldfoil® Shielded (100% coverage), 22 AWG stranded tinned copper drain wire, PVC jacket.
Physical Characteristics (Overall)
Conductor
AWG:
# Pairs AWG Stranding Conductor Material Dia. (in.)
3
22
7x30
TC - Tinned Copper .030
Total Number of Conductors:
6
Insulation
Insulation Material:
Insulation Material Wall Thickness (in.)
PP - Polypropylene 0.011
Inner Shield
Inner Shield Material:
Layer # Inner Shield Trade Name Type Inner Shield Material Coverage (%)
1
Beldfoil®
Tape Aluminum-Polyester
100.000
Inner Shield Drain Wire AWG:
AWG
22
Inner Shield Drain Wire Stranding:
7x30
Inner Shield Drain Wire Conductor Material:
TC - Tinned Copper
Outer Shield
Outer Shield Material:
Unshielded
Outer Jacket
Outer Jacket Material:
Nom. Wall Thickness (in.)
PVC - Polyvinyl Chloride 0.034
Overall Cable
Overall Nominal Diameter:
0.273 in.
Pair
Pair Color Code Chart:
Number Color
1
Black & Red
2
Black & White
3
Black & Green
Pair Lay Length & Direction:
Lay Length (in.) Twists (twist/ft) Direction
1.750
6.900
Left Hand
Mechanical Characteristics (Overall)
Storage Temperature Range:
-40°C To +80°C
Operating Temperature Range:
-20°C To +80°C
UL Temperature Rating:
80°C (UL AWM Style 2919)
Bulk Cable Weight:
39 lbs/1000 ft.
Max. Recommended Pulling Tension:
79 lbs.
Min. Bend Radius/Minor Axis:
2.750 in.
Page 1 of 3
01-05-2017
Applicable Specifications and Agency Compliance (Overall)
Applicable Standards & Environmental Programs
NEC/(UL) Specification:
CM
NEC Articles:
800
CEC/C(UL) Specification:
CM
AWM Specification:
UL Style 2919 (30 V 80°C)
EU Directive 2011/65/EU (ROHS II):
Yes
EU CE Mark:
Yes
EU Directive 2000/53/EC (ELV):
Yes
EU Directive 2002/95/EC (RoHS):
Yes
EU RoHS Compliance Date (mm/dd/yyyy):
01/01/2004
EU Directive 2002/96/EC (WEEE):
Yes
EU Directive 2003/11/EC (BFR):
Yes
CA Prop 65 (CJ for Wire & Cable):
Yes
MII Order #39 (China RoHS):
Yes
Flame Test
UL Flame Test:
UL1685 UL Loading
CSA Flame Test:
FT1
Suitability
Suitability - Indoor:
Yes
Plenum/Non-Plenum
Plenum (Y/N):
No
Plenum Number:
88777, 87777, 82777
Electrical Characteristics (Overall)
Nom. Characteristic Impedance:
Impedance (Ohm)
50
Nom. Inductance:
Inductance (µH/ft)
0.18
Nom. Capacitance Conductor to Conductor:
Capacitance (pF/ft)
30
Nom. Capacitance Cond. to Other Conductor & Shield:
Capacitance (pF/ft)
55
Nominal Velocity of Propagation:
VP (%)
66
Nom. Conductor DC Resistance:
DCR @ 20°C (Ohm/1000 ft)
15.0
Ind. Pair Nominal Shield DC Resistance @ 20 Deg. C:
10.600 Ohm/1000 ft
Max. Operating Voltage - UL:
Voltage
Description
300 V RMS Listed type CM
30 V RMS
AWM 2919
Max. Recommended Current:
Description
Current
10C temperature rise 2 Amps per conductor @ 25°C ambient
Put Ups and Colors:
Item #
Putup
Ship Weight
Color
8777 060U1000
1,000 FT
41.000 LB
CHROME
Notes
3 SH PR #22 PP PVC
8777 060U500
500 FT
21.000 LB
CHROME
3 SHLD PR #22 PP PVC
Page 2 of 3
Item Desc
01-05-2017
8777 060100
100 FT
4.700 LB
CHROME
8777 0601000
1,000 FT
43.000 LB
CHROME
C
8777 06010000
10,000 FT
460.000 LB
CHROME
CY
8777 0601640
1,640 FT
68.880 LB
CHROME
C
TRANSFER REVIEW (20 TO 30)
8777 060250
250 FT
11.250 LB
CHROME
C
8777 0603280
3,280 FT
137.760 LB
CHROME
C
8777 060500
500 FT
21.500 LB
CHROME
C
8777 0605000
5,000 FT
215.000 LB
CHROME
C
Notes:
C = CRATE REEL PUT-UP.
Y = FINAL PUT-UP LENGTH MAY VARY -10% TO +20% FROM LENGTH SHOWN.MAY CONTAIN 2 PIECES. MINIMUM LENGTH OF ANY ONE PIECE IS 1500'.
Revision Number: 2
Revision Date: 08-02-2013
© 2017 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to
change without notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for
any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether
in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities
and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is
correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the
safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification.
Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the
product.
Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU).
Page 3 of 3
01-05-2017
很抱歉,暂时无法提供与“8777 060250”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 76+48.0796276+6.24890
- 152+42.08053152+5.46920
