8778MN 004100
8778MN 004100
    BELDEN
    CBL 6PR 22AWG SHLD
8778MN 004100 数据手册
Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 8778MN Multi-Conductor - SpaceMaker Audio, Control and Instrumentation Cable For more Information please call 1-800-Belden1 General Description: 22 AWG stranded (19x34) tinned copper conductor, polypropylene insulation, six twisted pairs, individually shielded with Beldfoil® (100% coverage), 24 AWG stranded tinned copper drain wire, overall shielded with Beldfoil® (100% coverage), 22 AWG stranded tinned copper drain wire, overall PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Pairs AWG Stranding Conductor Material 6 22 19x34 TC - Tinned Copper Total Number of Conductors: 12 Insulation Insulation Material: Insulation Material Wall Thickness (mm) PP - Polypropylene 0.254 Inner Shield Inner Shield Material: Inner Shield Trade Name Type Inner Shield Material Beldfoil® Coverage (%) Tape Aluminum Foil-Polyester Tape 100.000 Inner Shield Drain Wire AWG: AWG Stranding Conductor Material 24 19x36 TC - Tinned Copper Outer Shield Outer Shield Material: Outer Shield Trade Name Type Outer Shield Material Beldfoil® Coverage (%) Tape Aluminum Foil-Polyester Tape 100.000 Outer Shield Drain Wire AWG: AWG Stranding Drain Wire Conductor Material 22 19x34 TC - Tinned Copper Outer Jacket Outer Jacket Material: Outer Jacket Material Nom. Wall Thickness (mm) PVC - Polyvinyl Chloride 0.406 Overall Cable Overall Nominal Diameter: 8.052 mm Pair Pair Color Code Chart: Number Color 1 Black & White 2 Red & Dark Green 3 Brown & Dark Blue 4 Orange & Yellow 5 Purple & Gray 6 Pink & Tan Mechanical Characteristics (Overall) Operating Temperature Range: -20°C To +80°C Bulk Cable Weight: 90.780 Kg/Km Page 1 of 3 10-17-2016 Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 8778MN Multi-Conductor - SpaceMaker Audio, Control and Instrumentation Cable Max. Recommended Pulling Tension: 698.367 N Min. Bend Radius/Minor Axis: 32.258 mm Min. Bend Radius (Continuous Flexing): 80.518 mm Flex Cycle Rating: 1 Million Flexes Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC Articles: 800 EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Other Specification: UL Style AWM 2937 (300V 80C), NFPA 79 Flame Test CSA Flame Test: FT2 Suitability Suitability - Indoor: Yes Electrical Characteristics (Overall) Nom. Inductance: Inductance (µH/m) 0.59058 Nom. Capacitance Conductor to Shield: Capacitance (pF/m) 205.719 Nom. Capacitance Conductor to Conductor: Capacitance (pF/m) 108.273 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/km) 48.887 Max. Operating Voltage - UL: Voltage 300V RMS Put Ups and Colors: Item # Putup Ship Weight Color 8778MN 004100 100 FT 9.600 LB YELLOW Notes Item Desc 6 FS PR #22 PO FS PVC 8778MN 0041000 1,000 FT 66.000 LB YELLOW 6 FS PR #22 PO FS PVC 8778MN 006100 100 FT 9.600 LB BLUE, LIGHT 6 FS PR #22 PO FS PVC 8778MN 0061000 1,000 FT 66.000 LB BLUE, LIGHT 6 FS PR #22 PO FS PVC 8778MN 008100 100 FT 9.600 LB GRAY 6 FS PR #22 PO FS PVC 8778MN 0081000 1,000 FT 66.000 LB GRAY 6 FS PR #22 PO FS PVC Revision Number: 0 Revision Date: 09-22-2016 © 2016 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Page 2 of 3 10-17-2016 Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 8778MN Multi-Conductor - SpaceMaker Audio, Control and Instrumentation Cable Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 3 of 3 10-17-2016
8778MN 004100 价格&库存
很抱歉,暂时无法提供与“8778MN 004100”相匹配的价格&库存,您可以联系我们找货
