9151 009U1000
9151 009U1000
    BELDEN
    BELDEN  9151 009U1000  UNSHIELDED MULTICONDUCTOR CABLE 2 CONDUC
9151 009U1000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9151 Multi-Conductor - High-Conductivity Copper Speaker Cable Open Twisted Const For more Information please call 1-800-Belden1 General Description: 22 AWG stranded (7x30) ETP high-conductivity copper conductors, PVC insulation, cabled: (1) tinned, (1) bare. Physical Characteristics (Overall) Conductor AWG: # Conductors AWG Stranding Conductor Material 1 22 7x30 Tinned High-Conductivity ETP Copper 1 22 7x30 Bare High-Conductivity ETP Copper Total Number of Conductors: 2 Insulation Insulation Material: Insulation Material Dia. (in.) PVC - Polyvinyl Chloride 0.053 Outer Shield Outer Shield Material: Outer Shield Material Unshielded Outer Jacket Outer Jacket Material: Outer Jacket Material Unjacketed Overall Cable Overall Nominal Diameter: 0.105 in. Mechanical Characteristics (Overall) Operating Temperature Range: -35°C To +105°C Bulk Cable Weight: 6 lbs/1000 ft. Max. Recommended Pulling Tension: 17 lbs. Min. Bend Radius/Minor Axis: 1.250 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 10/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Other Specification: UL AWM 10226 Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Inductance: Page 1 of 2 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9151 Multi-Conductor - High-Conductivity Copper Speaker Cable Open Twisted Const Inductance (µH/ft) .19 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 15 Max. Operating Voltage - UL: Voltage 90 V RMS Max. Recommended Current: Current 2.9 Amps per conductor @ 25°C Put Ups and Colors: Item # Putup Ship Weight Color 9151 009U1000 1,000 FT 7.000 LB WHITE Revision Number: 2 Notes Item Desc TW PR NAT & NAT Revision Date: 08-01-2014 © 2016 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 2 of 2 08-26-2016
9151 009U1000 价格&库存
很抱歉,暂时无法提供与“9151 009U1000”相匹配的价格&库存,您可以联系我们找货
