8920-WHT-100
8920-WHT-100
    BELDEN
    8920-WHT-100
8920-WHT-100 数据手册
Product: 8920 Lead Wire, #22 Str TC, PVC Ins, AWM 1015 AWM 1230 Product Description Low Temp Plastic Lead Wire, 22AWG (7x30) Tinned Copper, PVC Insulation, AWM 1015 AWM 1230 CSA TYPE TEW JQA-F 600V 105C Technical Specifications Product Overview Suitable Applications: inter-connection circuits, internal wiring of computer and electronic equipments, internal wiring of appliances, machine tool wire Physical Characteristics (Overall) Conductor AWG Stranding 22 7x30 Material No. of Conductors TC - Tinned Copper 1 Conductor Count: 1 Insulation Material Nominal Diameter Nominal Wall Thickness PVC - Polyvinyl Chloride 0.093 in 0.03 in Electrical Characteristics Voltage UL Voltage Rating 600 V RMS Temperature Range Non-UL Temp Rating: 105°C UL Temp Rating: 105°C Mechanical Characteristics Bulk Cable Weight: 5.8 lbs/1000ft Standards NEC Articles: Article 310 NEC/(UL) Compliance: MTW UL AWM Style Compliance: UL AWM Styles 1015, 1230 CSA Rating: 600 V, 105°C CSA AWM Compliance: CSA AWM I A/B CSA Type: AWM I A/B or TEW Applicable Environmental and Other Programs EU Directive 2000/53/EC (ELV): Yes EU Directive 2003/96/EC (BFR): Yes EU Directive 2011/65/EU (ROHS II): Yes EU Directive 2012/19/EU (WEEE): Yes EU Directive 2015/863/EU: Yes EU Directive Compliance: EU Directive 2003/11/EC (BFR) EU CE Mark: Yes EU RoHS Compliance Date (yyyy-mm-dd): 2005-07-01 CA Prop 65: Yes MII Order #39 (China RoHS): Yes Flammability, LS0H, Toxicity Testing UL Flammability: VW-1 CSA Flammability: FT1 UL voltage rating: 600 V RMS Plenum/Non-Plenum Plenum (Y/N): No Part Number Variants Item # 8920 010100 Color Putup Type Length UPC Black Reel 100 ft 612825220688 8920 0101000 Black Reel 1,000 ft 612825220695 8920 0105000 Black Reel 5,000 ft 612825220701 8920 013100 Blue, Dark Reel 100 ft 8920 0131000 Blue, Dark Reel 1,000 ft 612825220749 8920 0011000 Brown Reel 1,000 ft 612825220466 8920 0081000 Gray Reel 1,000 ft 612825220619 8920 0051000 Green, Dark Reel 1,000 ft 612825348047 8920 0031000 Orange Reel 1,000 ft 612825220534 8920 002100 Red Reel 100 ft 8920 0021000 Red Reel 1,000 ft 612825220503 8920 0025000 Red Reel 5,000 ft 612825220510 8920 0071000 Violet Reel 1,000 ft 612825220596 8920 009100 White Reel 100 ft 8920 0091000 White Reel 1,000 ft 612825220657 8920 004100 Yellow Reel 100 ft 8920 0041000 Yellow Reel 1,000 ft 612825220565 612825220732 612825220497 612825220640 612825220558 Footnote: C - CRATE REEL PUT-UP. Footnote: P - STRIPE COLORS ON STOCK SOLID COLORS. STRIPING ADDER OF $8.00/M= FOR 1 OR 2 STRIPES. 10,000' MINIMUM ORDER FOR COLOR COMBINATION. PUT-UP WILL BE SUBJECT TO TWO PIECES (+ OR -) 10% PER SPOOL, WITH A MINIMUM LENGTH OF 100'. History Update and Revision: Revision Number: 0.288 Revision Date: 07-26-2020 © 2020 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with all applicable environmental programs as listed in the data sheet. The information provided is correct to the best of Belden's knowledge, information and belief at the date of its publication. This information is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. The Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product.
8920-WHT-100 价格&库存
很抱歉,暂时无法提供与“8920-WHT-100”相匹配的价格&库存,您可以联系我们找货
