9272 006500
9272 006500
    BELDEN
    双轴 缆线 20AWG 500.0'(152.40m) 78 Ohms
9272 006500 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9272 Twinax - Twinaxial Cable For more Information please call 1-800-Belden1 General Description: 20 AWG stranded (7x28) .038" tinned copper conductors, polyethylene insulation, tinned copper braid shield (93% Coverage), PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Pairs AWG Stranding Conductor Material Dia. (in.) 1 20 7x28 TC - Tinned Copper .038 Total Number of Conductors: 2 Insulation Insulation Material: Insulation Material Wall Thickness (in.) PE - Polyethylene 0.019 Outer Shield Outer Shield Material: Type Outer Shield Material Coverage (%) Braid TC - Tinned Copper 93 Outer Jacket Outer Jacket Material: Outer Jacket Material Nom. Wall Thickness (in.) PVC - Polyvinyl Chloride 0.033 Overall Cable Overall Nominal Diameter: 0.244 in. Pair Pair Color Code Chart: Number Color 1 Clear & Blue Mechanical Characteristics (Overall) Operating Temperature Range: -20°C To +60°C UL Temperature Rating: 60°C (UL AWM Style 2092) Bulk Cable Weight: 37 lbs/1000 ft. Max. Recommended Pulling Tension: 68 lbs. Min. Bend Radius/Minor Axis: 2.500 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CM CEC/C(UL) Specification: CM AWM Specification: UL Style 2092 (300 V 60°C) EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes Page 1 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9272 Twinax - Twinaxial Cable CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Flame Test UL Flame Test: UL1685 UL Loading Plenum/Non-Plenum Plenum (Y/N): No Plenum Number: 89272 Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 78 Nom. Inductance: Inductance (µH/ft) .020 Nom. Capacitance Conductor to Conductor: Capacitance (pF/ft) 19.7 Nominal Velocity of Propagation: VP (%) 66 Nominal Delay: Delay (ns/ft) 1.54 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 9.5 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 3.4 Nom. Attenuation: Freq. (MHz) Attenuation (dB/100 ft.) 1 0.6 10 2.1 50 5.0 100 7.5 200 11.0 400 16.0 Max. Operating Voltage - UL: Voltage 300 V RMS Put Ups and Colors: Item # Putup Ship Weight Color 9272 006U1000 1,000 FT 39.000 LB BLUE, LIGHT Notes Item Desc 78 OHM TWINAX 9272 006U500 500 FT 20.000 LB BLUE, LIGHT 78 OHM TWINAX 9272 006100 100 FT 4.500 LB BLUE, LIGHT 9272 0061000 1,000 FT 41.000 LB BLUE, LIGHT C 78 OHM TWINAX 9272 006500 500 FT 20.500 LB BLUE, LIGHT C 78 OHM TWINAX 78 OHM TWINAX Notes: C = CRATE REEL PUT-UP. Revision Number: 3 Revision Date: 10-16-2012 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 2 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9272 Twinax - Twinaxial Cable product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 3 of 3 01-05-2017
9272 006500 价格&库存
很抱歉,暂时无法提供与“9272 006500”相匹配的价格&库存,您可以联系我们找货
