9502NH.00305
9502NH.00305
    BELDEN
    BELDEN - 9502NH.00305 - Multipair Cable, Comnputer EIA RS-232, Screened, 2 Pair, 24 AWG, 1000 ft, 30...
9502NH.00305 数据手册
Product: Version: Date: Page: 9502NH 1 Instrumentation and computer cable AWG24 (7xAWG32) 2 twisted pair Overall Beldfoil® + Drain wire FRNC (UV stabilised) sheath. 2 3 4 5 Applications • For EIA RS-232 data transmission applications. General Standards • EN 50290-2-27 Construction & Dimensions 1. Inner Conductor Material Diameter 2. Insulation Material Diameter over insulation Colour of insulation Tinned Copper AWG24 (7xAWG32) PE 1.12 ± 0.05 mm Pair 1: Black and red Pair 2: Black and White 3. Foil (Beldfoil®) Material Thickness Aluminium / Polyester 9 / 12 µm 4. Drain wire Material Diameter Tinned Copper AWG24 (7xAWG32) 5. Sheath Material Colour Nominal thickness Nominal diameter FRNC (UV stabilised) Chrome (RAL 7037) 0.90 mm 5.80 mm 9502NH 7 8-7-2013 1/2 Product: Version: Date: Page: 9502NH 7 8-7-2013 2/2 Mechanical characteristics Parameter Flame resistance Smoke density Oil resistance Radiation resistance Application specification Halogen content according to IEC 60754-1 Corrosivity of fire gasses to IEC 60754-2 Conductivity pH value Temperature range installing Temperature range operating (moving installation) Temperature range operating (fixed installation) Temperature range storage Minimum bending radius Maximum pulling tension Specification IEC 60332-3-24 IEC 61034 IEC 60811-404 IEC 60544 EN 50290-2-27 zero Unit ≤ 100 ≥ 4.3 -15 to +80 -15 to +80 -45 to +80 -45 to +80 10 x cable diameter 100 μS/cm ˚C ˚C ˚C ˚C N Electrical characteristics Parameter Nominal resistance conductor Nominal resistance shield Nominal capacitance conductor to conductor of a pair Nominal capacitance conductor to shield + other conductor Test voltage conductor-conductor Test voltage conductor-screen Voltage rating Maximum continues current per conductor @ 25 °C Specification 78.7 55.8 98.4 164.0 2500 2500 300 1.76 Unit Ω/km Ω/km pF/m pF/m VDC,3 seconds VDC,3 seconds V RMS A Belden declares this product to be in compliance with the environmental regulations EU RoHS (Directive 2011/65/EU, 02 Jan. 2013); this is valid for all material produced after the RoHS compliant date for this product.
9502NH.00305 价格&库存
很抱歉,暂时无法提供与“9502NH.00305”相匹配的价格&库存,您可以联系我们找货
9502NH.00305
  • 1+5560.02050
库存:2736
