9907 E4XU1000
9907 E4XU1000
    BELDEN
    RG-58 TYPE COAX
9907 E4XU1000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9907 Coax - Coaxial Cable - Thinnet 10Base2 Ethernet For more Information please call 1-800-Belden1 General Description: 20 AWG stranded (19x32) .037" tinned copper conductor, foam polyethylene insulation, Duobond® II (100% coverage) plus an overall tinned copper braid shield (93% coverage), PVC jacket. Usage (Overall) Suitable Applications: Thin Ethernet Physical Characteristics (Overall) Conductor AWG: # Coax AWG Stranding Conductor Material Dia. (in.) 1 20 19x32 TC - Tinned Copper .037 Total Number of Conductors: 1 Insulation Insulation Material: Insulation Material Dia. (in.) FHDPE - Foam High Density Polyethylene .102 Outer Shield Outer Shield Material: Layer # Outer Shield Trade Name Type Outer Shield Material 1 Bonded Duofoil® 2 Coverage (%) Tape Bonded Aluminum Foil-Polyester Tape-Aluminum Foil 100 Braid TC - Tinned Copper 93 Outer Jacket Outer Jacket Material: Outer Jacket Material PVC - Polyvinyl Chloride Overall Cable Overall Nominal Diameter: 0.185 in. Mechanical Characteristics (Overall) Operating Temperature Range: -40°C To +80°C UL Temperature Rating: 60°C (UL AWM Style 1354) Bulk Cable Weight: 23 lbs/1000 ft. Max. Recommended Pulling Tension: 45 lbs. Min. Bend Radius/Minor Axis: 2 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CL2, CM CEC/C(UL) Specification: CM AWM Specification: UL Style 1354 (30 V 60°C) EU Directive 2011/65/EU (ROHS II): Yes IEEE Specification: IEEE802.3 10Base2 Other Standards: ISO8802.3 10Base2 EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes Page 1 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9907 Coax - Coaxial Cable - Thinnet 10Base2 Ethernet EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Customer Part Number Reference Specification: DEC Part No. 17-01248-00 RG Type: 58A/U Flame Test UL Flame Test: UL1685 UL Loading Plenum/Non-Plenum Plenum (Y/N): No Plenum Number: 82907, 89907 Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) Tolerance (Ohms) 50 +/- 2 Nom. Capacitance Conductor to Shield: Capacitance (pF/ft) 25.4 Nominal Velocity of Propagation: VP (%) 80 Nominal Delay: Delay (ns/ft) 1.27 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 8.8 Maximum Loop Resistance: Resistance (Ohm/1000 ft) 15.24 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 5.8 Nom. Attenuation: Freq. (MHz) Attenuation (dB/100 ft.) 1 .43 10 1.3 50 2.91 100 4.2 200 6.1 400 8.9 700 12.1 900 13.9 1000 14.8 Max. Operating Voltage - UL: Voltage Description 300 V RMS 30 V RMS UL AWM Style 1354 Notes (Overall) Notes: Tape to bond at overlap area only. Tape is not designed to bond to dielectric core. Put Ups and Colors: Item # Putup Ship Weight Color 9907 E4XU1000 1,000 FT 24.000 LB GRAY, LIGHT DEC 9907 E4X1000 1,000 FT 25.000 LB GRAY, LIGHT DEC C RG-58 TYPE COAX 9907 E4X1640 1,640 FT 41.000 LB GRAY, LIGHT DEC C RG-58 TYPE COAX 9907 E4X2500 2,500 FT 62.500 LB GRAY, LIGHT DEC C RG-58 TYPE COAX 9907 E4X3280 3,280 FT 82.000 LB GRAY, LIGHT DEC C RG-58 TYPE COAX 9907 E4X500 500 FT 12.500 LB GRAY, LIGHT DEC Page 2 of 3 Notes Item Desc RG-58 TYPE COAX RG-58 TYPE COAX 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9907 Coax - Coaxial Cable - Thinnet 10Base2 Ethernet 9907 E4X5000 5,000 FT 125.000 LB GRAY, LIGHT DEC RG-58 TYPE COAX Notes: C = CRATE REEL PUT-UP. Revision Number: 2 Revision Date: 09-25-2012 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 3 of 3 01-05-2017
9907 E4XU1000
PDF文档中包含了以下信息: 1. 物料型号:型号为“LM78M05ABDG3-5/NOPB”,是一款5A输出的正压线性稳压器。
2. 器件简介:LM78M05ABDG3-5/NOPB 用于提供稳定的5V输出电压,适用于需要高电流输出的应用。
3. 引脚分配:共有3个引脚,分别为输入引脚、接地引脚和输出引脚。
4. 参数特性:包括输入电压范围、输出电压、最大输出电流等。
5. 功能详解:详细描述了器件的工作原理和性能。
6. 应用信息:适用于需要高电流输出的场合,如电源管理。
7. 封装信息:封装类型为TO-263-3。
9907 E4XU1000 价格&库存
很抱歉,暂时无法提供与“9907 E4XU1000”相匹配的价格&库存,您可以联系我们找货
9907 E4XU1000
  • 1000+21.950011000+2.83957
