9930 0101000
9930 0101000
    BELDEN
    HOOK-UP 30AWG STR BLK
9930 0101000 数据手册
Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 9930 Hook-up/Lead - UL AWM Style 1007 For more Information please call 1-800-Belden1 General Description: Tinned copper conductor, PVC insulation. Rated 80ºC, 300V. Rated 600V peak for electronic circuits, and internal wiring of electronic and electrical equipment. Physical Characteristics (Overall) Conductor AWG: # Conductors AWG Stranding Conductor Material 1 30 7x38 TC - Tinned Copper Total Number of Conductors: 1 Insulation Insulation Material: Insulation Material Wall Thickness (mm) Min. Avg. Wall (mm) PVC - Polyvinyl Chloride 0.406 0.381 Overall Insulation Overall Cable Overall Nominal Diameter: 1.118 mm Mechanical Characteristics (Overall) Bulk Cable Weight: 1.786 Kg/Km Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs UL AWM Style: UL Style 1007 (300 V 80°C) UL Rating: 300 V RMS, 80°C EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 10/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Flame Test UL Flame Test: VW-1 Plenum/Non-Plenum Plenum (Y/N): No Put Ups and Colors: Page 1 of 2 10-14-2013 Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 9930 Hook-up/Lead - UL AWM Style 1007 Item # Putup Ship Weight Color Notes Item Desc 9930 0011000 305 MT 0.907 KG BROWN P 30 STR PVC BRN 9930 002100 30 MT 0.091 KG RED 9930 0021000 305 MT 0.907 KG RED 9930 003100 30 MT 0.091 KG ORANGE 9930 0041000 305 MT 0.907 KG YELLOW 9930 005100 30 MT 0.091 KG GREEN, DARK 9930 0051000 305 MT 0.907 KG GREEN, DARK 9930 007100 30 MT 0.091 KG VIOLET 30 STR PVC VIO 9930 008100 30 MT 0.091 KG GRAY 30 STR PVC GRY 9930 009100 30 MT 0.091 KG WHITE 9930 0091000 305 MT 0.907 KG WHITE 9930 010100 30 MT 0.091 KG BLACK 9930 0101000 305 MT 0.907 KG BLACK 9930 013100 30 MT 0.091 KG BLUE, DARK 9930 0131000 305 MT 0.907 KG BLUE, DARK 30 STR PVC RED P 30 STR PVC RED 30 STR PVC ORG P 30 STR PVC YEL 30 STR PVC GRN P 30 STR PVC GRN 30 STR PVC WHT P 30 STR PVC WHT 30 STR PVC BLK P 30 STR PVC BLK 30 STR PVC DBLU P 30 STR PVC DBLU Notes: P = STRIPE COLORS ON STOCK SOLID COLORS. STRIPING ADDER OF $8.00/M' FOR1 OR 2 STRIPES. 10000' MINIMUM ORDER FOR COLOR COMBINATION.PUT-UP WILL BE SUBJECT TO TWO PIECES (+ OR -) 10% PER SPOOL Revision Number: 2 Revision Date: 10-01-2008 © 2013 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 73/23/EEC), as amended by directive 93/68/EEC. Page 2 of 2 10-14-2013
9930 0101000 价格&库存
很抱歉,暂时无法提供与“9930 0101000”相匹配的价格&库存,您可以联系我们找货
