AX100172
AX100172
    BELDEN
    EZ-MDVO UTP MODULE,
AX100172 数据手册
Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION AX100172 Modular Connectors - USOC EZ-MDVO Modular Jack - MDVO style For more Information please call 1-800-Belden1 General Description: USOC EZ-MDVO Modular Jack, RJ11, Almond Usage (Overall) Suitable Applications: Voice Applications Related Parts: Compatible with Interface and MDVO Style Faceplates, Adapters, Boxes and Patch Panels Physical Characteristics (Connectivity) Dimensions Dimensions: Height (mm) Width (mm) Depth (mm) 18.034 19.050 31.750 Materials Materials: Description Type Material Front Connection Lead Frame Copper Allow with 50u inch Gold over Nickel Rear Connection IDC Copper Allow with Nickel Plating Connector body Plastic - UL940V-0 Color Color: Almond Wiring Scheme Wiring Scheme: USOC Weight Weight: 0.006 kg Included Parts Included Parts: Center Stuffercap Coded USOC Packaging Packaging: Individually packaged in a plastic bag. Standard pack of 50 units. Mechanical Characteristics (Connectivity) Footprint/Type: MDVO-Style Plug / Jack Compatibility: RJ11 Termination Interface: Termination Connection Durabilities Front Mated Connection 1,000 cycles Rear Gas Tight IDC Connection 10 terminations Connector/Hardware Retention: 88.964 N Plug/Connector Retention: 50.042 N Storage Temperature Range: -40°C To +70°C Installation Temperature Range: -10°C To +60°C Operating Temperature Range: -10°C To +60°C Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs Other Standards: FCC Part 68, Subpart F, IEC 60603-7 EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2006 MII Order #39 (China RoHS): EUP 50 Safety Listing: ACA, Bi-national Standard Listed Page 1 of 2 11-10-2016 Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION AX100172 Modular Connectors - USOC EZ-MDVO Modular Jack - MDVO style Suitability Suitability - Indoor: Yes - Indoor Transmission Characteristics (Connectivity) Dielectric Strength: 1,000 V RMS @ 60 Hz for 1 minute Current Rating: 1.500 A Insulation Resistance: 500 M-Ohm Minimum Max. Contact Resistance: 20 m-Ohm Termination Resistance: 2.5 m-Ohm Notes (Overall) Notes: Please See Installation Guide PX102753 Product Family Part Number List: Item Number Color AX100171 Gray AX100172 Almond AX100173 White AX100174 Black AX100175 Orange (TIA 606) AX100176 Red (TIA 606) AX100177 Yellow (TIA 606) AX100178 Green (TIA 606) AX100179 Blue (TIA 606) AX100180 Purple (TIA 606) AX100181 Brown (TIA 606) Put Ups and Colors: Item # Putup Ship Weight AX100172 1 EA 0.024 LB Revision Number: 0 Color Notes Item Desc EZ-MDVO UTP MODULE, Revision Date: 04-13-2009 © 2016 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 2 of 2 11-10-2016
AX100172 价格&库存
很抱歉,暂时无法提供与“AX100172”相匹配的价格&库存,您可以联系我们找货
AX100172
    • 10+65.5908010+8.48418
