AX101071
AX101071
    BELDEN
    CAT6+ JACK MDVO BLUE TIA606
AX101071 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION AX101071 Modular Connectors - CAT6+ Modular Jack - MDVO style For more Information please call 1-800-Belden1 General Description: CAT6+ Modular Jack, RJ45, MDVO style, Blue (TIA 606) Usage (Overall) Suitable Applications: IBDN System 2400 and 4800, TIA Category 6+, ISO Class E, 1000 BASE-T Related Parts: Compatible with Interface and MDVO Style Faceplates, Adapters, Boxes and Patch Panels Physical Characteristics (Connectivity) Dimensions Dimensions: Height (in.) Width (in.) Depth (in.) 0.765 0.770 1.290 Materials Materials: Description Type Material Front Connection Lead Frame Copper Allow with 50u inch Gold over Nickel Rear Connection IDC Copper Allow with Nickel Plating Connector Body Plastic - UL940V-0 Color Color: Blue (TIA 606) Wiring Scheme Wiring Scheme: T568A/B Weight Weight: 0.014 lbs. Included Parts Included Parts: 1 T-Bar +1 Dust Cap Packaging Packaging: Individually packaged in a plastic bag. Standard pack of 50 units. Mechanical Characteristics (Connectivity) Footprint/Type: MDVO-Style Plug / Jack Compatibility: RJ45, RJ11 Termination Interface: Termination Connection Durabilities Front Mated Connection 1,000 cycles Rear Gas Tight IDC Connection 20 terminations Connector/Hardware Retention: 20 lbs. Plug/Connector Retention: 11.250 lbs. Storage Temperature Range: -40°C To +70°C Installation Temperature Range: -10°C To +60°C Operating Temperature Range: -10°C To +60°C Tool Compatibility: Belden 110 Connecting Tool, MediaFlex Termination Station Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs Other Standards: FCC Part 68, Subpart F, IEC 60603-7 EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 07/01/2006 MII Order #39 (China RoHS): EUP 50 Page 1 of 3 02-27-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION AX101071 Modular Connectors - CAT6+ Modular Jack - MDVO style Telecommunications Standards: ISO/IEC 11801:2002 Ed.2 Third Party Performance Verification: ETL - Verified Category 6 Safety Listing: ACA, Bi-national Standard Listed Suitability Suitability - Indoor: Yes - Indoor Transmission Characteristics (Connectivity) Mated Connection Table 1: Max. Min. Min. Min. Min. Frequency Max. Insertion Loss Insertion Loss NEXT NEXT FEXT FEXT (MHz) TIA* (dB) Belden** (dB) TIA* (dB) Belden** (dB) TIA* (dB) Belden** (dB) 1.000 0.100 0.100 75.000 77.000 75.000 77.000 4.000 0.100 0.100 75.000 77.000 71.100 75.100 8.000 0.100 0.100 75.000 77.000 65.000 69.000 10.000 0.100 0.100 74.000 77.000 63.100 67.100 16.000 0.100 0.100 69.900 72.900 59.000 63.000 20.000 0.100 0.100 68.000 71.000 57.100 61.100 25.000 0.100 0.100 66.000 69.000 55.100 59.100 31.250 0.110 0.100 64.100 67.100 53.200 57.200 62.500 0.160 0.120 58.100 61.100 47.200 51.200 100.000 0.200 0.160 54.000 57.000 43.100 47.100 200.000 0.280 0.240 48.000 51.000 37.100 41.100 250.000 0.320 0.280 46.000 49.000 35.100 39.100 300.000 0.310 44.500 Mated Connection Table - Footnote: 37.600 * TIA/EIA-568-C.2 Category 6 Standard. ** Worst-case performance for a CAT6+ mated connection using CAT6+ modular plugs. Mated Connection Table 2: Min. Min. Min. Frequency Min. Return Loss Return Loss Balanced TCL Balanced TCL (MHz) TIA* (dB) Belden** (dB) TIA* (dB) Belden** (dB) 1.000 30.000 32.000 40.000 42.000 4.000 30.000 32.000 40.000 42.000 8.000 30.000 32.000 40.000 42.000 10.000 30.000 32.000 40.000 42.000 16.000 30.000 32.000 40.000 42.000 20.000 30.000 32.000 40.000 42.000 25.000 30.000 32.000 40.000 42.000 31.250 30.000 32.000 38.100 42.000 62.500 28.100 32.000 32.100 36.100 100.000 24.000 28.000 28.000 32.000 200.000 18.000 22.000 22.000 26.000 250.000 16.000 22.000 20.000 24.000 300.000 18.500 22.500 Dielectric Strength: 1,000 V RMS @ 60 Hz for 1 minute Current Rating: 1.500 A Insulation Resistance: 500 M-Ohm Minimum Max. Contact Resistance: 20 m-Ohm Termination Resistance: 2.5 m-Ohm Notes (Overall) Notes: Please see Installation Guide PX103329 Notes (Cont'd.): IDC Wire Gauge: 22~24 AWG Product Family Part Number List: Item Number Color AX101063 Gray AX101064 Almond AX101065 White AX101066 Black AX101067 Orange (TIA 606) AX101068 Red (TIA 606) AX101069 Yellow (TIA 606) AX101070 Green (TIA 606) Page 2 of 3 02-27-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION AX101071 Modular Connectors - CAT6+ Modular Jack - MDVO style AX101071 Blue (TIA 606) AX101072 Purple (TIA 606) AX101073 Brown (TIA 606) AX102563 Ivory Put Ups and Colors: Item # Putup Ship Weight AX101071 1 EA 0.024 LB Revision Number: 1 Color Notes Item Desc CAT6+ JACK MDVO BLUE TIA606 Revision Date: 08-13-2014 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 3 of 3 02-27-2017
AX101071 价格&库存
很抱歉,暂时无法提供与“AX101071”相匹配的价格&库存,您可以联系我们找货
