Detailed Specifications & Technical Data
ENGLISH MEASUREMENT VERSION
AX102271 Modular Connectors - 10GX Modular Jack - MDVO style
For more Information
please call
1-800-Belden1
General Description:
10GX Modular Jack, Category 6A, RJ45, MDVO-style, White
Usage (Overall)
Suitable Applications:
IBDN System 10GX, TIA Category 6A, ISO Class E, 10GBASE-T
Related Parts:
Compatible with Interface and MDVO Style Faceplates, Adapters, Boxes and Patch Panels
Physical Characteristics (Connectivity)
Dimensions
Dimensions:
Height (in.) Width (in.) Depth (in.)
0.780
0.770
1.170
Materials
Materials:
Description
Type
Material
Front Connection Flexible PCB Flexible PCB with 50u inch Gold over Nickel
Rear Connection IDC
Phosphor Bronze with Tin Plating over Nickel
Connector Body
Plastic - UL94V-0
N/A
Color
Color:
White
Wiring Scheme
Wiring Scheme:
T568A/B
Weight
Weight:
0.016 lbs.
Included Parts
Included Parts:
1 X-Bar + 1 dust cap
Packaging
Packaging:
Individually packaged in a plastic bag. Standard pack of 50 units.
Mechanical Characteristics (Connectivity)
Footprint/Type:
MDVO-Style
Plug / Jack Compatibility:
RJ45, RJ11
Termination Interface:
Termination Connection
Durabilities
Front
Mated Connection 750 cycles
Rear
IDC Connection
20 terminations
Cable/Connector Retention:
15 lbs.
Connector/Hardware Retention:
20 lbs.
Plug/Connector Retention:
11.250 lbs.
Storage Temperature Range:
-40°C To +70°C
Installation Temperature Range:
-10°C To +60°C
Operating Temperature Range:
-10°C To +60°C
Tool Compatibility:
Belden 110 Connecting Tool
Applicable Specifications and Agency Compliance (Overall)
Applicable Standards & Environmental Programs
Other Standards:
FCC Part 68, Subpart F, IEC 60603-7
EU Directive 2002/95/EC (RoHS):
Yes
EU RoHS Compliance Date (mm/dd/yyyy):
07/01/2006
Page 1 of 3
02-27-2017
MII Order #39 (China RoHS):
EUP 50
Telecommunications Standards:
Category 6A - TIA 568.B.2-10, ISO/IEC 11801:2002 Amendment 2
Third Party Performance Verification:
ETL - Verified Category 6A
Safety Listing:
ACA, Bi-national Standard Listed
Suitability
Suitability - Indoor:
Yes - Indoor
Transmission Characteristics (Connectivity)
Mated Connection Table 1:
Max.
Min.
Min.
Min.
Min.
Frequency Max.
Insertion Loss Insertion Loss NEXT
NEXT
FEXT
FEXT
(MHz)
TIA* (dB)
Belden** (dB) TIA* (dB) Belden** (dB) TIA* (dB) Belden** (dB)
1.000
0.100
0.050
75.000
77.000
75.000
80.000
4.000
0.100
0.050
75.000
77.000
71.100
75.100
8.000
0.100
0.050
75.000
77.000
65.000
69.000
10.000
0.100
0.050
74.000
77.000
63.100
67.100
16.000
0.100
0.060
69.900
72.900
59.000
63.000
20.000
0.100
0.070
68.000
71.000
57.100
61.100
25.000
0.100
0.080
66.000
69.000
55.100
59.100
31.250
0.110
0.090
64.100
67.100
53.200
57.200
62.500
0.160
0.140
58.100
61.100
47.200
51.200
100.000
0.200
0.180
54.000
57.000
43.100
47.100
200.000
0.280
0.260
48.000
51.000
37.100
41.100
250.000
0.320
0.300
46.000
49.000
35.100
39.100
300.000
0.350
0.330
42.900
46.700
33.600
37.600
400.000
0.400
0.380
37.900
42.900
31.100
35.100
500.000
0.450
0.430
34.000
40.000
29.100
33.100
625.000
0.480
37.100
Mated Connection Table - Footnote:
31.200
* TIA/EIA-568-B.2-10-2008 Category 6A Standard.
** Worst-case performance for a 10GX mated connection using 10GX modular plugs.
Mated Connection Table 2:
Min.
Min.
Min.
Min.
Min.
Min.
Min.
Frequency Min.
Return Loss Return Loss PSANEXT PSANEXT
PSAACRF PSAACRF
Balanced TCL Balanced TCL
(MHz)
TIA* (dB)
Belden** (dB)
1.000
30.000
34.100
70.500
72.000
67.000
72.000
40.000
45.000
4.000
30.000
34.100
70.500
72.000
67.000
72.000
40.000
45.000
8.000
30.000
34.100
70.500
72.000
67.000
72.000
40.000
45.000
10.000
30.000
34.100
70.500
72.000
67.000
72.000
40.000
45.000
16.000
30.000
34.100
70.500
72.000
67.000
72.000
40.000
45.000
20.000
30.000
34.100
70.500
72.000
67.000
72.000
40.000
45.000
25.000
30.000
34.100
70.500
72.000
67.000
72.000
40.000
45.000
31.250
30.000
34.100
70.500
72.000
67.000
72.000
38.100
45.000
62.500
30.000
34.100
70.500
72.000
67.000
72.000
32.100
39.100
100.000
28.000
30.000
70.500
72.000
67.000
72.000
28.000
35.000
200.000
22.000
24.000
64.500
66.000
61.000
66.000
22.000
29.000
250.000
20.000
22.000
62.500
64.000
59.000
64.000
20.000
27.000
300.000
18.500
20.500
61.000
62.500
57.500
62.500
18.500
25.500
400.000
16.000
18.000
58.500
60.000
55.000
60.000
16.000
23.000
500.000
14.000
16.000
56.500
58.000
53.000
58.000
14.000
21.000
625.000
13.000
56.100
56.100
Dielectric Strength:
1,000 V RMS @ 60 Hz for 1 minute
Current Rating:
1.500 A
Insulation Resistance:
50 M-Ohm Minimum
Max. Contact Resistance:
20 m-Ohm
Termination Resistance:
2.5 m-Ohm
19.100
Notes (Overall)
Notes: Please see Installation Guide PX103771
Product Family
Part Number List:
Item Number Color
AX102269
Gray
AX102270
Almond
Page 2 of 3
02-27-2017
AX102271
White
AX102272
Black
AX102273
Orange (TIA 606)
AX102274
Red (TIA 606)
AX102275
Yellow (TIA 606)
AX102276
Green (TIA 606)
AX102277
Blue (TIA 606)
AX102278
Purple (TIA 606)
AX102562
Ivory
Put Ups and Colors:
Item #
Putup
Ship Weight
AX102271
1 EA
0.024 LB
Revision Number: 0
Color
Notes
Item Desc
10GX JACK MDVO WHITE
Revision Date: 12-01-2008
© 2017 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to
change without notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for
any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether
in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities
and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is
correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the
safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification.
Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the
product.
Page 3 of 3
02-27-2017
很抱歉,暂时无法提供与“AX102271”相匹配的价格&库存,您可以联系我们找货
