BE43910-A500
BE43910-A500
    BELDEN
    BELDEN - BE43910-A500 - Multicore Cable, Screened, 2 Core, 24 AWG, 1640 ft, 500 m
BE43910-A500 数据手册
Product: BE43910 RailTuff SPE 40mGb 24AWG STR SF/UTP E-Beam XL-LSZH, AWM STYLE 22303 Product Description RailTuff Ethernet 1 Pair x 24AWG, STP, Stranded Tinned Copper Conductor, PP Insulation, XLPE Outer Jacket, AWM STYLE 22303 Technical Specifications Product Overview Suitable Applications: 1 single pair Ethernet up to 600 MHz accord. IEEE 802.3bp (1000BASE-T1) Physical Characteristics (Overall) Conductor AWG Stranding 24 Stranded Material Construction n x D No. of Pairs TC - Tinned Copper 7x0.2 mm Conductor Count: 1 2 Insulation Type Material Nominal Diameter Nominal Wall Thickness Insulation PP - Polypropylene 1.65 mm 0.41 mm Color Chart Color Nature Nature & Blue Cabling Description Lay Direction Number of Fillers 2C + 1 S 1 Outer Shield Type Material Min. Coverage [%] Tape Bi-Laminate (Alum+Poly) 25% Braid Tinned Copper (TC) 80% Outer Jacket Material Nominal Diameter Min. Wall Thickness Nominal Wall Thickness XLPE - Cross Linked Polyethylene 4.80 mm 0.38 mm Construction and Dimensions Min Elongation at Breakof Insulation: 100 % Min Elongation at Breakof Jacket: 100 % Min Tensile Strength of Jacket: 10.3 MPa Electrical Characteristics Conductor DCR Max. Conductor DCR Max. DCR Unbalanced Within Pair [%] 0.45 mm 94.2 Ohm/km 2% Capacitance Max. Capacitance Unbalance 160 pF/100m Dielectric Strength: 0.7 kVac/1 min Insulation Resistance: 5000 MOhm*km Insulation Resistance (Cond to Cond): 5000 MOhm*km Insulation Resistance (Cond to Screen): 5000 MOhm*km Impedance Nominal Characteristic Impedance 100 ± 7 Ohm at 100 MHz Delay Frequency [MHz] 4 MHz Max. Delay 552 ns/100m High Frequency Frequency [MHz] Max. Insertion Loss (Attenuation) Min. RL (Return Loss) [dB] Min. TCL [dB] Min. ELTCTL [dB] 1 MHz 3.0 dB/100m 20 dB 40 dB 40 dB 10 MHz 8.7 dB/100m 25 dB 35 dB 20 dB 20 MHz 12.3 dB/100m 25 dB 30.5 dB 13.9 dB 600 MHz 70.6 dB/100m 15.6 dB 8.3 dB 5 dB Coupling Attenuation Class: Type I Voltage Voltage Rating [V] 300 V Temperature Range Operating Temp Range: -40°C to + 80°C Mechanical Characteristics Max Dielectric Shrinkage: 5% Dielectric Shrinkage Description: Shrinkage of Insualtion (100+/2°CX1hr)/150mm Cold Bend Test: No Crack Hygroscopicity: Weight increasing not exceed 1% (for 3hrs) Wicking: The filter paper shall not wet (for 6 hrs) IRM 902 Mineral Oil Resistance Test: At 100C° x 96hr- Tensile Strength: ≥ 70% of Original Elongation at break:≥ 65% of Original UV Resistance 720h per UL1581: (300h) Tensile Strength (Mpa) - 85% of original, Elongation at break (%) - 85% of original Standards Other Standards: IEC 61156-12 NP, EN 45545-2 Hazard Level HL1-HL3, UL758 Applicable Environmental and Other Programs EU Directive 2002/95/EC (RoHS): Yes Flammability, LS0H, Toxicity Testing UL Flammability: FT 2 IEC Flammability: IEC 60332-1-2, EN 50305 clause 9.1.2, IEC 60332-3-25, IEC 60332-3-22 Toxicity of Insulation: (EN 45545-2 Table 5-R15 and R16-HL3) 6 Toxicity of Jacket: (EN 45545-2 Table 5-R15 and R16-HL3) 6 IEC 61034-2 - Smoke Density Min. Transmittance: 70% History Update and Revision: Revision Number: 0.58 Revision Date: 09-09-2021 © 2021 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with all applicable environmental programs as listed in the data sheet. The information provided is correct to the best of Belden's knowledge, information and belief at the date of its publication. This information is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. The Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product.
BE43910-A500 价格&库存
很抱歉,暂时无法提供与“BE43910-A500”相匹配的价格&库存,您可以联系我们找货
