WWW.ICMCORP.NET
CPLCRTC-B Compression Tool
COMMERCIAL
• Smaller, economical version of the
RTC 360 tool
• Manufactured of 4100 series aircraft grade
Chromoly alloy for maximum strength and durability
• Tool body is over molded with an ergonomic, hard
plastic shell to ensure a comfortable grip and easy compression
• Fixed compression dies inside the head of the tool allow for an easy,
consistant compression
• Compress with F-Conn’s Basic Series of F and RCA
• Made in the USA
• 1-year warranty
Compression Tools
INDUSTRY USE: CATV
CPLCRBC-B Double Bubble™ Compression Tool
INDUSTRY USE: SECURITY
BROADCAST
CATV
COMMERCIAL
• A perfect solution for structured
wiring, security cameras,
satellite and other exposed wiring
installations
grade Chromoly alloy
• Compress with F-Conn’s DB™ Connector Series
• Available in F, RCA and BNC
• Creates a secure, permanent “double bubble”
connection with the DB™ connector
• Self-adjusting plunger head provides a precise and constant
compression each and every time
• Includes 1 interchangeable adapter tip for compression
of F and RCA type connectors
• Made in the USA
• 1-year warranty
Part#
Description
CPLCRBC-B
Double Bubble™ Compression Tool - Blue
LMTIP-S
Silver adapter tip for F-Conn’s silver/nickel connectors
RBCTIP-UHF
Adapter tip for F-Conn’s 50 Ohm connectors
Call for Tech Support 800.222.2142
23
WWW.ICMCORP.NET
Compression Tools
CPLCCT-SLM Linear Compliant Compression Tool
INDUSTRY USE: PRO A/V
SECURITY
CATV
COMMERCIAL
• Manufactured of solid steel for
• Crafted so that it is lightweight
and easy to use
constant compression each
and every time
• Includes four interchangeable
adapter tips to compress a full line of connectors
• Compress with F-Conn’s FS and RG Series Connectors
• Made in the USA
• 1-year warranty
Part#
Description
CPLCCT-SLM
Linear Complaint Compression Tool
LMTIP-S
LMTIP-G
Gold adapter tip for F-Conn’s gold connectors
LMTIP-WP
Wall Plate adapter tip for F-Conn’s splice connectors
LMTIP-RA
Right Angle adapter tip for F-Conn’s right angle connectors
LMTIP-HOLDER
Holder for adapter tips
LMTIP-KIT
Kit includes Holder + 5 tips - G, S, RA, WP, IEC
CPLCCT-1-S Compression Tool
INDUSTRY USE: CATV
• For FS Series F-type and RCA
compression connectors
• No adjustment for compression!
• Crafted so that it is lightweight and easy to use
constant compression each and every time
• Made in the USA
• 1-year warranty
24
WWW.ICMCORP.NET
CPLCCT-SS59/11 Compression Tool
• Compress connectors for FS
Series RG59, RG6, RG7 and
RG11 cables with an easy flip of the die
• Compress the F-Conn RG11 right angle connector
• Compatible with other brands of compression connectors
• Made in the USA
• 1-year warranty
Compression Tools
INDUSTRY USE: CATV
CPLCCT-11BNC Specialty Compression Tool
INDUSTRY USE: CATV
• Compresses the FS11BNC,
RG11 BNC-type connector
• No adjustments required!
compression
• Made in the USA
• 1-year warranty
CPLCRBC-ITS Specialty Compression Tool
INDUSTRY USE: TOLL ROAD
SECURITY
• Designed specifically for the
Double Bubble™ ITS BNC
male & female connector
• Designed for Belden 8281 & 8281B
cable
• Use the LMTIP-WP adapter tip for the
DB59BNCSL2-F (female) splice
ITS connector
• Made in the USA
• 1-year warranty
25
很抱歉,暂时无法提供与“CPLCCT-SLMR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+3696.004391+463.66470
