TECHNICAL DATA SHEET
COAX CTF100
Code
version
date
page
CTF100
1
2008-04-09
1/2
APPLICATION
Coaxial cables used in cabled distribution networks designed according the European
Standard EN 50117-2-1 and En 50117-2-4 operating at frequencies between 5 MHz and 3000
MHz.
CONSTRUCTION
1 2 3.1 3.2
4
1
2
3.1
3.2
4
Solid soft annealed copper
Gas injected LDPE
Copper-polyester foil
Annealed copper
PVC according the European Standard HD 624.
Inner conductor
Dielectric
Foil
Braid
Sheath
REQUIREMENTS AND TEST METHODS
Test methods in accordance with European standard EN 50117-1.
Mechanical characteristics
1. Inner conductor.
Diameter:
2. Dielectric:
Diameter:
Adhesion:
3. Outer conductor:
Diameter screen:
Coverage braid:
4. Sheath:
Diameter:
Tensile strength:
Elongation at break:
5. Cable:
Storage/operation temperature:
Minimum installation temperature:
Minimum static bend radius:
0.96 mm ± 0.02 mm
4.7 mm ± 0.15 mm
7.5 – 75 N at 25 mm
5.35 mm ± 0.15 mm
55 % ± 5 %
6.65 mm ± 0.2 mm
≥ 12.5 N/mm2
≥ 150 %
-40°C to +70°C
-5 °C
35 mm
Belden Wire & Cable B.V.
All rights are reserved. Reproduction in whole or in part is prohibited without the written consent of the copyright owner
COAX CTF100
Code
version
date
page
CTF100
1
2008-04-09
2/2
Electrical characteristics
Mean characteristic impedance:
Regularity of impedance:
DC loop resistance:
DC resistance inner conductor:
DC resistance outer conductor:
Capacitance:
Velocity ratio:
Insulation resistance:
Voltage test of dielectric:
Screening efficiency after flexing
30-1000 MHz:
1000 – 2000 MHz:
2000 – 3000 MHz:
Return loss at
5-30 MHz:
30-470 MHz:
470-1000 MHz:
1000-2000 MHz:
2000-3000 MHz:
75 ± 3 Ω
>40dB or 104 MOhm.km
2 kVdc
≥ 75 dB
≥ 65 dB
≥ 55 dB
≥ 20 dB*
≥ 20 dB*
≥ 18 dB*
≥ 16 dB*
≥ 15 dB*
*Max. 3 peak values 4 dB lower than specified.
Attenuation at
5 MHz:
50 MHz:
100 MHz:
200 MHz:
460 MHz:
800 MHz:
Maximal
1.6 dB/100m
4.6 dB/100m
6.5 dB/100m
9.5 dB/100m
15.0 dB/100m
18.8 dB/100m
Attenuation at
860 MHz:
1000 MHz:
1750 MHz:
2150 MHz:
2400 MHz:
3000 MHz:
REVISIONS
# Description
Maximal
19.5 dB/100m
21.5 dB/100m
29.0 dB/100m
32.5 dB/100m
34.4 dB/100m
38.4 dB/100m
Date
Initials
Belden CDT believes this product to be in compliance with the environmental regulations EU RoHS (Directive 2002/95/EC,
27 January 2003); this is valid for all material produced after the RoHS compliant date for this product.
很抱歉,暂时无法提供与“CTF100.00100”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 100+26.38861100+3.42390
- 200+23.42751200+3.03970
