Detailed Specifications & Technical Data
ENGLISH MEASUREMENT VERSION
1121A Triad - 600V Tray Cable
For more Information
please call
1-800-Belden1
General Description:
18 AWG triads stranded (7x26) bare copper conductors, twisted triads, PVC/Nylon insulation, overall
Beldfoil® shield (100% coverage), PVC jacket.
Physical Characteristics (Overall)
Conductor
AWG:
# Triads AWG Stranding Conductor Material
1
18
7x26
BC - Bare Copper
Total Number of Conductors:
3
Insulation
Insulation Material:
Insulation Material
PVC/Nylon - Polyvinyl Chloride/Nylon
Inner Shield
Inner Shield Color Code Chart:
Number Color
1
Black & Red & Blue
Outer Shield
Outer Shield Material:
Outer Shield Trade Name Type Outer Shield Material
Beldfoil®
Coverage (%)
Tape Aluminum Foil-Polyester Tape 100
Outer Shield Drain Wire AWG:
AWG Stranding Drain Wire Conductor Material
7x28
TC - Tinned Copper
Outer Jacket
Outer Jacket Material:
Nom. Wall Thickness (in.)
PVC - Polyvinyl Chloride 0.047
Outer Jacket Ripcord:
Yes
Overall Cable
Overall Nominal Diameter:
0.290 in.
Mechanical Characteristics (Overall)
Wet Temperature Range:
-30°C To +75°C
Dry Temperature Range:
-30°C To +90°C
Bulk Cable Weight:
45 lbs/1000 ft.
Max. Recommended Pulling Tension:
81 lbs.
Min. Bend Radius/Minor Axis:
2.900 in.
Applicable Specifications and Agency Compliance (Overall)
Applicable Standards & Environmental Programs
NEC/(UL) Specification:
NPLF, TC-ER
EU Directive 2011/65/EU (ROHS II):
Yes
EU CE Mark:
Yes
EU Directive 2000/53/EC (ELV):
Yes
EU Directive 2002/95/EC (RoHS):
Yes
EU RoHS Compliance Date (mm/dd/yyyy):
04/01/2005
EU Directive 2002/96/EC (WEEE):
Yes
Page 1 of 2
08-26-2016
EU Directive 2003/11/EC (BFR):
Yes
CA Prop 65 (CJ for Wire & Cable):
Yes
MII Order #39 (China RoHS):
Yes
Other Specification:
ICEA S-73-532, S-61-402
Flame Test
UL Flame Test:
UL1685 Vertical Tray Flame Test
CSA Flame Test:
FT4
IEEE Flame Test:
1202
Suitability
Suitability - Burial:
Yes
Sunlight Resistance:
Yes
Plenum/Non-Plenum
Plenum (Y/N):
No
Electrical Characteristics (Overall)
Nom. Conductor DC Resistance:
DCR @ 20°C (Ohm/1000 ft)
5.86
Nominal Outer Shield DC Resistance:
7.46
Max. Operating Voltage - UL:
Voltage
600 V RMS (NEC Type TC)
150 V RMS (NPLF)
Max. Recommended Current:
Current
6 Amps per conductor @ 30C
Notes (Overall)
Notes: Alternate color coding available upon request.
Put Ups and Colors:
Item #
Putup
Ship Weight
Color
Notes
Item Desc
1121A 0101000
1,000 FT
55.000 LB
BLACK
CZ
3 #18 PVC/NYL FS PVC
1121A 01010000
10,000 FT
550.000 LB
BLACK
CZ
1121A 010500
500 FT
29.000 LB
BLACK
CZ
Notes:
C = CRATE REEL PUT-UP.
Z = FINAL PUT-UP LENGTH MAY VARY (+ OR -) 10% FOR SPOOLS OR REELS AND(+ OR -) 5% FOR UNREEL CARTONS FROM LENGTH SHOWN.
Revision Number: 3
Revision Date: 10-13-2014
© 2016 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to
change without notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for
any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether
in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities
and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is
correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the
safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification.
Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the
product.
Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU).
Page 2 of 2
08-26-2016
很抱歉,暂时无法提供与“1121A 0101000”相匹配的价格&库存,您可以联系我们找货
