1212F 004A1000
1212F 004A1000
    BELDEN
    CAT5E+ 4PR F/UTP CMR RIB
1212F 004A1000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1212F Multi-Conductor - Enhanced Category 5e Nonbonded-Pair Cable For more Information please call 1-800-Belden1 General Description: CAT5e+ (350MHz), 4-Pair, F/UTP-Foil shielded, Riser-CMR, Premise Horizontal Cable, 24 AWG solid bare copper conductors, polyolefin insulation, overall Beldfoil® shield, PVC jacket, RJ-45 compatible Usage (Overall) Suitable Applications: Premise Horizontal Cable, Gigabit Ethernet, HDBaseT, 100BaseTX, 100BaseVG ANYLAN, 155ATM, 622ATM, NTSC/PAL Component or Composite Video, AES/EBU, Digital Video, RS-422, Noisy Environments, 100 MHz Category 5e Physical Characteristics (Overall) Conductor AWG: # Pairs AWG Stranding Conductor Material 4 24 Solid BC - Bare Copper Total Number of Conductors: 8 Insulation Insulation Material: Insulation Material PO - Polyolefin Outer Shield Outer Shield Material: Outer Shield Trade Name Type Outer Shield Material Beldfoil® Coverage (%) Tape Aluminum Foil-Polyester Tape 100 Outer Shield Drain Wire AWG: AWG Stranding Drain Wire Conductor Material 24 7x32 TC - Tinned Copper Outer Jacket Outer Jacket Material: Outer Jacket Material PVC - Polyvinyl Chloride Overall Cable Overall Nominal Diameter: 0.260 in. Pair Pair Color Code Chart: Number Color 1 White/Blue Stripe & Blue 2 White/Orange Stripe & Orange 3 White/Green Stripe & Green 4 White/Brown Stripe & Brown Mechanical Characteristics (Overall) Operating Temperature Range: -20°C To +75°C Bulk Cable Weight: 30 lbs/1000 ft. Max. Recommended Pulling Tension: 25 lbs. Min. Bend Radius/Minor Axis: 1 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs CEC/C(UL) Specification: CMR EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes Page 1 of 4 02-01-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1212F Multi-Conductor - Enhanced Category 5e Nonbonded-Pair Cable EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 12/09/2011 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Telecommunications Standards: Category 5e - TIA 568.C.2 ANSI Specification: ANSI/TIA 568-C.2 Category 5e Other Specification: NEMA WC-63.1 Category 5e, UL Verified to Category 5e Flame Test UL Flame Test: UL1666 Riser CSA Flame Test: FT4 Suitability Suitability - Indoor: Yes Suitability - Outdoor: No Suitability - Aerial: No Suitability - Burial: No Sunlight Resistance: No Plenum/Non-Plenum Plenum (Y/N): No Plenum Number: 1213F Electrical Characteristics (Overall) Nom. Mutual Capacitance: Capacitance (pF/ft) 15 Maximum Capacitance Unbalance (pF/100 m): 330 Nominal Velocity of Propagation: VP (%) 70 Maximum Delay: Delay (ns/100 m) 538 @ 100MHz Max. Delay Skew: Delay Skew (ns/100 m) 45 Maximum Conductor DC Resistance: DCR @ 20°C (Ohm/100 m) 9.38 Max. Operating Voltage - UL: Voltage 300 V RMS Maximum DCR Unbalanced: DCR Unbalance @ 20°C (%) 3 Electrical Characteristics-Premise (Overall) Premise Cable Electrical Table 1: Freq. (MHz) Max. Attenuation (dB/100 m) Min. NEXT (dB) Min. PSNEXT (dB) Min. ACR (dB) Min. PSACR (dB) Min RL (dB) Min. SRL (dB) 1 2.000 70.3 68.3 70.3 66.3 20.000 23.0 4 4.000 61.3 59.3 59.3 55.3 23.000 23.0 8 5.700 56.8 54.8 53.1 49.1 24.500 24.5 10 6.400 55.3 53.3 50.9 46.9 25.000 25.0 16 8.100 52.2 50.2 46.1 42.1 25.000 25.0 20 9.100 50.8 48.8 43.7 39.7 25.000 25.0 25 10.200 49.3 47.3 41.1 37.1 24.300 24.3 31.25 11.400 47.9 45.9 38.5 34.5 23.600 23.6 Page 2 of 4 02-01-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1212F Multi-Conductor - Enhanced Category 5e Nonbonded-Pair Cable 62.5 16.400 43.4 41.4 29.0 25.0 21.500 21.5 100 21.000 40.3 38.3 21.3 17.3 20.100 20.1 155 26.600 37.4 35.4 12.8 8.9 18.800 200 30.500 35.8 33.8 7.3 3.3 18.000 250 34.400 34.3 32.3 1.9 300 38.000 33.1 28.2 16.800 350 41.400 32.1 27.2 16.300 400 44.600 31.3 26.3 15.900 450 47.600 30.5 25.6 15.500 17.300 Premise Cable Electrical Table 2: Freq. (MHz) Input (Unfitted) Imp. (Ohms) Fitted Impedance Min. ELFEXT (dB) Min. PSELFEXT (dB) 1 100 ± 15 100 ± 15 67.8 64.8 4 100 ± 15 100 ± 15 55.8 52.8 8 100 ± 15 100 ± 15 49.7 46.7 10 100 ± 15 100 ± 15 47.8 44.8 16 100 ± 15 100 ± 15 43.7 40.7 20 100 ± 15 100 ± 15 41.8 38.8 25 100 ± 15 100 ± 15 39.8 36.8 31.25 100 ± 15 100 ± 15 37.9 34.9 62.5 100 ± 15 100 ± 15 31.9 28.9 100 100 ± 15 100 ± 15 27.8 24.8 155 100 ± 22 100 ± 15 24.0 21.0 200 100 ± 22 100 ± 15 21.8 18.8 250 100 ± 32 100 ± 15 19.8 16.8 300 100 ± 32 100 ± 15 18.2 15.2 350 100 ± 32 100 ± 15 16.9 13.9 Notes (Overall) Notes: Shield is bonded to jacket inner wall for electrical stability. RJ-45 Compatible. Jacket sequentially marked at 2 ft. intervals. Third party verified to TIA/EIA-568-B.2, Category 5e. Put Ups and Colors: Item # Putup Ship Weight Color 1212F 002A1000 1,000 FT 30.000 LB RED Notes Item Desc CAT5E+ 4PR F/UTP CMR RIB 1212F 0021000 1,000 FT 30.000 LB RED CAT5E+ 4PR F/UTP CMR REEL 1212F 003A1000 1,000 FT 30.000 LB ORANGE CAT5E+ 4PR F/UTP CMR RIB 1212F 0031000 1,000 FT 30.000 LB ORANGE CAT5E+ 4PR F/UTP CMR REEL 1212F 004A1000 1,000 FT 30.000 LB YELLOW CAT5E+ 4PR F/UTP CMR RIB 1212F 0041000 1,000 FT 30.000 LB YELLOW CAT5E+ 4PR F/UTP CMR REEL 1212F 005A1000 1,000 FT 30.000 LB GREEN, DARK CAT5E+ 4PR F/UTP CMR RIB 1212F 0051000 1,000 FT 30.000 LB GREEN, DARK CAT5E+ 4PR F/UTP CMR REEL 1212F 006A1000 1,000 FT 30.000 LB BLUE, LIGHT 1212F 006A500 500 FT 20.500 LB BLUE, LIGHT 1212F 0061000 1,000 FT 30.000 LB BLUE, LIGHT CAT5E+ 4PR F/UTP CMR REEL 1212F 008A1000 1,000 FT 30.000 LB GRAY CAT5E+ 4PR F/UTP CMR RIB 1212F 0081000 1,000 FT 30.000 LB GRAY CAT5E+ 4PR F/UTP CMR REEL 1212F 009A1000 1,000 FT 30.000 LB WHITE 1212F 009A500 500 FT 20.500 LB WHITE 1212F 0091000 1,000 FT 30.000 LB WHITE CAT5E+ 4PR F/UTP CMR REEL 1212F 010A1000 1,000 FT 30.000 LB BLACK CAT5E+ 4PR F/UTP CMR RIB 1212F 0101000 1,000 FT 30.000 LB BLACK CAT5E+ 4PR F/UTP CMR REEL CAT5E+ 4PR F/UTP CMR RIB C CAT5E+ 4PR F/UTP CMR RIB CAT5E+ 4PR F/UTP CMR RIB C CAT5E+ 4PR F/UTP CMR RIB Notes: C = CRATE REEL PUT-UP. Revision Number: 2 Revision Date: 07-27-2016 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 3 of 4 02-01-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1212F Multi-Conductor - Enhanced Category 5e Nonbonded-Pair Cable Page 4 of 4 02-01-2017
1212F 004A1000 价格&库存
很抱歉,暂时无法提供与“1212F 004A1000”相匹配的价格&库存,您可以联系我们找货
