1278R B591000
1278R B591000
    BELDEN
    4#25LDPE/GIFHDLDPE SH FRPVCPVC
1278R B591000 数据手册
Product: 1278R RGB Video, Mini Hi-Res, #25-4 Coax Solid TC, CMR Product Description RGB Video Coax, Riser-CMR, 4-25 AWG solid tinned copper conductors, foam polyethylene insulation, Duofoil® + 95% tinned copper interlocked serve shield, inner PVC jackets, PVC jacket Technical Specifications Product Overview RGB Projectors, LCD Projectors, Video Distribution, Component Video, Graphic Displays, Special Effects Editing, Animation, Video Post Production, Home Theater, Offices, Boardrooms, Auditoriums, Teleconferencing, Theaters Suitable Applications: Physical Characteristics (Overall) Conductor AWG Stranding 25 Solid Material Nominal Diameter No. of Coax TC - Tinned Copper 0.018 in Conductor Count: 4 4 Insulation Material Nominal Diameter PE - Polyethylene (Foam) 0.074 in Table Notes: Gas Injected Color Chart Number Color 1 Red 2 Green 3 Blue 4 Yellow Inner Shield Material Type Tape Layer 1 French Braid 2 Material Material Trade Name Coverage [%] Bi-Laminate (Alum+Poly) Duofoil® 100% Tinned Copper (TC) 95% Table Notes: Tape lightly bonded to dielectric Inner Jacket Material Material Nominal Diameter PVC - Polyvinyl Chloride 0.114 in Outer Jacket Material Material Nominal Diameter PVC - Polyvinyl Chloride 0.351 in Electrical Characteristics Conductor DCR Nominal Conductor DCR Nominal Conductor DCR Conductor Resistance Nominal Inner Shield DCR Outer Conductor DCR 34 Ohm/1000ft 34 Ohm/1000ft Capacitance Nom. Capacitance Conductor to Shield 17 pF/ft Inductance Nominal Inductance 0.087 µH/ft Impedance Nominal Characteristic Impedance 75 Ohm Return Loss (RL) Frequency [MHz] Minimum Return (RL) 5-850 MHz 20 dB High Frequency (Nominal/Typical) Frequency [MHz] Nom. Insertion Loss 1 MHz 0.52 dB/100ft 5 MHz 1.17 dB/100ft 50 MHz 3.7 dB/100ft 100 MHz 4.9 dB/100ft 200 MHz 6.7 dB/100ft 400 MHz 9.5 dB/100ft 750 MHz 13.4 dB/100ft 900 MHz 15 dB/100ft 1000 MHz 15.8 dB/100ft 3000 MHz 31.2 dB/100ft Delay Nominal Delay Nominal Velocity of Propagation (VP) [%] 1.24 ns/ft 80% Voltage Non-UL Voltage Rating UL Voltage Rating 300 V RMS 300 V RMS Temperature Range Non-UL Temp Rating: 75°C UL Temp Rating: 60°C Operating Temp Range: -40°C To +75°C Mechanical Characteristics Bulk Cable Weight: 55 lbs/1000ft Max. Pull Tension: 110 lbs Min Bend Radius (Overall): 3.5 in Min Bend Radius (Each Coax): 1.1 in Standards NEC/(UL) Compliance: CMR CEC/C(UL) Compliance: CMG RG Type: Sub-miniature 59 Applicable Environmental and Other Programs Environmental Space: Indoor - Riser EU Directive 2000/53/EC (ELV): Yes EU Directive 2011/65/EU (ROHS II): Yes EU Directive 2012/19/EU (WEEE): Yes EU Directive 2015/863/EU: Yes 5.4 Ohm/1000ft 5.4 Ohm/1000ft EU Directive Compliance: EU Directive 2003/11/EC (BFR) EU CE Mark: No EU RoHS Compliance Date (yyyy-mm-dd): 2004-01-01 MII Order #39 (China RoHS): Yes Suitability Suitability - Indoor: Yes Flammability, LS0H, Toxicity Testing UL Flammability: UL1666 Vertical Shaft UL voltage rating: 300 V RMS Plenum/Non-Plenum Plenum (Y/N): No Part Number Variants Item # 1278R B59500 Color Putup Type Length Black, Matte Reel 1278R B591000 Black, Matte Reel Footnote: 500 ft UPC 612825355168 1,000 ft 612825355175 C - CRATE REEL PUT-UP. History Update and Revision: Revision Number: 0.291 Revision Date: 09-30-2020 © 2020 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with all applicable environmental programs as listed in the data sheet. The information provided is correct to the best of Belden's knowledge, information and belief at the date of its publication. This information is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. The Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product.
1278R B591000 价格&库存
很抱歉,暂时无法提供与“1278R B591000”相匹配的价格&库存,您可以联系我们找货
