1300SB 0101000
1300SB 0101000
    BELDEN
    4 PR #24 PP FS FRNHPO
1300SB 0101000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1300SB Multi-Conductor - Category 5e ScTP Shipboard ABS Type Approved For more Information please call 1-800-Belden1 General Description: 24 AWG solid bare copper conductors, polypropylene insulation, overall Beldfoil® shield, 24 AWG stranded tinned copper drain wire, low smoke zero halogen jacket. Usage (Overall) Suitable Applications: Shipboard LAN/Data, WI-FI, Wireless LAN, Outdoor Antenna, Radio, Broadband, RF, Where ABS Type Approval is Required Physical Characteristics (Overall) Conductor AWG: # Pairs AWG Stranding Conductor Material 4 24 Solid BC - Bare Copper Total Number of Conductors: 8 Insulation Insulation Material: Insulation Material Wall Thickness (in.) Dia. (in.) PP - Polypropylene .010 .042 Outer Shield Outer Shield Material: Outer Shield Trade Name Type Outer Shield Material Beldfoil® Coverage (%) Tape Aluminum Foil-Polyester Tape 100 Outer Shield Drain Wire AWG: AWG Stranding Drain Wire Conductor Material 24 7x32 TC - Tinned Copper Outer Jacket Outer Jacket Material: Outer Jacket Material LSZH - Low Smoke Zero Halogen Overall Cable Overall Nominal Diameter: 0.260 in. Pair Pair Color Code Chart: Number Color 1 White/Blue Stripe & Blue 2 White/Orange Stripe & Orange 3 White/Green Stripe & Green 4 White/Brown Stripe & Brown Mechanical Characteristics (Overall) Operating Temperature Range: -30°C To +105°C Bulk Cable Weight: 32.400 lbs/1000 ft. Max. Recommended Pulling Tension: 25 lbs. Min. Bend Radius/Minor Axis: 2.500 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMG-LS CEC/C(UL) Specification: CMG-LS EU Directive 2011/65/EU (ROHS II): Yes IEEE Specification: Std. 45 clause 23 Page 1 of 3 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1300SB Multi-Conductor - Category 5e ScTP Shipboard ABS Type Approved EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 08/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Other Specification: NEMA WC-63.1 Category 5e, UL 444, ABS Type Approval Certificate 15-VC1420029 Flame Test UL Flame Test: UL1685 FT4 Loading, Limited Smoke C(UL) Flame Test: FT4, Limited Smoke IEC Flame Test: 60332-1, 60332-3-22 (Category A) IEEE Flame Test: 1202 Suitability Suitability - Indoor: Yes Suitability - Outdoor: Yes Sunlight Resistance: Yes Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Mutual Capacitance: Capacitance (pF/ft) 15 Maximum Capacitance Unbalance (pF/100 m): 330 Nominal Velocity of Propagation: VP (%) 70 Maximum Delay: Delay (ns/100 m) 538 @ 100MHz Max. Delay Skew: Delay Skew (ns/100 m) 45 Maximum Conductor DC Resistance: DCR @ 20°C (Ohm/100 m) 9.38 Max. Operating Voltage - UL: Voltage 300 V RMS Maximum DCR Unbalanced: DCR Unbalance @ 20°C (%) 3 Electrical Characteristics-Premise (Overall) Premise Cable Electrical Table 1: Freq. (MHz) Max. Attenuation (dB/100 m) Min. NEXT (dB) Min. PSNEXT (dB) Min. ACR (dB) Min. PSACR (dB) Min RL (dB) Min. SRL (dB) 1 2.0 65.3 62.3 60.3 60.3 20.0 20.0 4 4.1 56.3 53.3 49.2 49.2 23.0 23.0 8 5.8 51.8 48.8 43.0 43.0 24.5 24.5 10 6.5 50.3 47.3 40.8 40.8 25.0 25.0 16 8.2 47.3 44.3 36.1 36.1 25.0 25.0 20 9.3 45.8 42.8 33.5 33.5 25.0 25.0 25 10.4 44.3 41.3 30.9 30.9 24.3 24.3 31.25 11.7 42.9 39.9 28.2 28.2 23.6 23.6 62.5 17.0 38.4 35.4 18.4 18.4 21.5 21.5 100 22.0 35.3 32.3 10.3 10.3 20.1 20.1 Page 2 of 3 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1300SB Multi-Conductor - Category 5e ScTP Shipboard ABS Type Approved Premise Cable Electrical Table 2: Freq. (MHz) Input (Unfitted) Imp. (Ohms) Fitted Impedance Min. ELFEXT (dB) Min. PSELFEXT (dB) 1 100 ± 15 100 ± 15 63.8 60.8 4 100 ± 15 100 ± 15 51.7 48.7 8 100 ± 15 100 ± 15 45.7 42.7 10 100 ± 15 100 ± 15 43.8 40.8 16 100 ± 15 100 ± 15 39.7 36.7 20 100 ± 15 100 ± 15 37.7 34.7 25 100 ± 15 100 ± 15 35.8 32.8 31.25 100 ± 15 100 ± 15 33.9 30.9 62.5 100 ± 15 100 ± 15 27.8 24.8 100 100 ± 15 100 ± 15 23.8 20.8 Notes (Overall) Notes: RJ-45 Compatible. Jacket sequentially marked at 2 ft. intervals. Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 1300SB 0101000 1,000 FT 35.000 LB BLACK C 4 PR #24 PP FS FRNHPO Notes: C = CRATE REEL PUT-UP. Revision Number: 4 Revision Date: 07-15-2016 © 2016 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 3 of 3 08-26-2016
1300SB 0101000 价格&库存
很抱歉,暂时无法提供与“1300SB 0101000”相匹配的价格&库存,您可以联系我们找货
1300SB 0101000
  • 1000+9.529771000+1.23842
  • 2000+9.461012000+1.22949
库存:4000
