1314SB 0101000
1314SB 0101000
    BELDEN
    1 PR #14 PP FRNHPO
1314SB 0101000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1314SB Multi-Conductor - Speaker Wire and Cable For more Information please call 1-800-Belden1 General Description: 14 AWG stranded tinned copper conductors, polypropylene insulation, LSZH jacket with ripcord, sequential footage marking every two feet. Usage (Overall) Suitable Applications: Speaker, Audio, Control, Intercom, ABS Type Approved, Shipboard, CMG-LS, IEEE 45 clause 23, IEC 60092-376 clause 17, 60092-351, 60754-1, 60754-2, 61034, UL1685 FT4 Loading, Limited Smoke, IEC 60332-3-22 (Category A), 60332-1, IEEE 1202 Physical Characteristics (Overall) Conductor AWG: # Conductors AWG Stranding Conductor Material 2 14 41 TC - Tinned Copper Total Number of Conductors: 2 Insulation Insulation Material: Insulation Material Dia. (in.) PP - Polypropylene 0.095 Outer Shield Outer Shield Material: Outer Shield Material Unshielded Outer Jacket Outer Jacket Material: Outer Jacket Material LSZH - Low Smoke Zero Halogen Outer Jacket Ripcord: Yes Overall Cable Overall Cabling Color Code Chart: Number Color 1 Black 2 White Overall Nominal Diameter: 0.294 in. Mechanical Characteristics (Overall) Operating Temperature Range: -20°C To +105°C Bulk Cable Weight: 53 lbs/1000 ft. Max. Recommended Pulling Tension: 109.200 lbs. Min. Bend Radius/Minor Axis: 3 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMG-LS CEC/C(UL) Specification: CMG-LS EU Directive 2011/65/EU (ROHS II): Yes IEEE Specification: Std. 45 clause 23 EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes Page 1 of 2 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1314SB Multi-Conductor - Speaker Wire and Cable EU RoHS Compliance Date (mm/dd/yyyy): 08/04/2006 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Other Specification: UL444, ABS Type Approval Certificate 06-HS184641E Flame Test UL Flame Test: UL1685 FT4 Loading, Limited Smoke CSA Flame Test: FT4 IEC Flame Test: 60332-1, 60332-3-22 (Category A) IEEE Flame Test: 1202 Suitability Suitability - Indoor: Yes Suitability - Outdoor: Yes Sunlight Resistance: Yes Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Inductance: Inductance (µH/ft) 0.17 Nom. Capacitance Conductor to Conductor: Capacitance (pF/ft) 29 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 2.42 Max. Operating Voltage - UL: Voltage 300 V RMS Max. Recommended Current: Current 22 Amps per conductor @ 25°C Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 1314SB 0101000 1,000 FT 57.000 LB BLACK C 1 PR #14 PP FRNHPO Notes: C = CRATE REEL PUT-UP. Revision Number: 6 Revision Date: 08-20-2014 © 2016 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 2 of 2 08-26-2016
1314SB 0101000 价格&库存
很抱歉,暂时无法提供与“1314SB 0101000”相匹配的价格&库存,您可以联系我们找货
1314SB 0101000
    • 1000+11.733191000+1.52503
