Detailed Specifications & Technical Data
ENGLISH MEASUREMENT VERSION
1502R Multi-Conductor - Multimedia Control Cable
For more Information
please call
1-800-Belden1
General Description:
22 AWG stranded (7x30) TC conductors, FPE insulation (data), STP (Data) w/Beldfoil®, TC drain wire, 18
AWG (16x30) TC conductors, unshielded (power) pair, F-R PVC insulation (power), F-R PVC Jacket
(Available in Black, White, or Aqua)
Physical Characteristics (Overall)
Conductor
AWG:
# Conductors # Pairs AWG Stranding Conductor Material
2
1
22
7x30
TC - Tinned Copper
1
18
16x30
TC - Tinned Copper
Total Number of Conductors:
4
Insulation
Insulation Material:
Insulation Trade Name Insulation Material
Wall Thickness (in.) AWG
Datalene®
.025
22
F-R PVC - Flame Retardant Polyvinyl Chloride .013
18
HDFPE - High Density Foam Polyethylene
Inner Shield
Inner Shield Material:
Layer #
Inner Shield Trade Name Type Inner Shield Material
22 AWG Pair Beldfoil®
Coverage (%) Stranding Dia. (in.) Conductor Material
Tape Aluminum Foil-Polyester Tape 100
Inner Shield Drain Wire AWG:
AWG
24 AWG 7x32
TC - Tinned Copper
Outer Shield
Outer Shield Material:
Unshielded
Outer Jacket
Outer Jacket Material:
Outer Jacket Ripcord:
Yes
Overall Cable
Overall Nominal Diameter:
0.250 in.
Pair
Pair Color Code Chart:
Number Color
1
Blue & White
2
Red & Black
Mechanical Characteristics (Overall)
Operating Temperature Range:
-20°C To +75°C
Non-UL Temperature Rating:
75°C
Bulk Cable Weight:
40 lbs/1000 ft.
Max. Recommended Pulling Tension:
59.800 lbs.
Min. Bend Radius/Minor Axis:
2.500 in.
Applicable Specifications and Agency Compliance (Overall)
Applicable Standards & Environmental Programs
NEC/(UL) Specification:
CMR
Page 1 of 3
01-05-2017
CEC/C(UL) Specification:
CMG
EU Directive 2011/65/EU (ROHS II):
Yes
EU CE Mark:
Yes
EU Directive 2000/53/EC (ELV):
Yes
EU Directive 2002/95/EC (RoHS):
Yes
EU RoHS Compliance Date (mm/dd/yyyy):
04/01/2005
EU Directive 2002/96/EC (WEEE):
Yes
EU Directive 2003/11/EC (BFR):
Yes
CA Prop 65 (CJ for Wire & Cable):
Yes
MII Order #39 (China RoHS):
Yes
Flame Test
UL Flame Test:
UL1666 Vertical Shaft
CSA Flame Test:
FT4
Plenum/Non-Plenum
Plenum (Y/N):
No
Plenum Number:
1502P
Electrical Characteristics (Overall)
Nom. Characteristic Impedance:
Description Impedance (Ohm)
22 AWG Pair 100
Nom. Inductance:
Description Inductance (µH/ft)
22 AWG
.232
18 AWG
.168
Nom. Capacitance Conductor to Conductor:
Description Capacitance (pF/ft)
22 AWG Pair 14
18 AWG Pair 29
Nom. Capacitance Cond. to Other Conductor & Shield:
Description Freq. (MHz) Start Freq. (MHz) Stop Freq. (MHz) Capacitance (pF/ft)
22 AWG Pair
38
Nom. Conductor DC Resistance:
Description DCR @ 20°C (Ohm/1000 ft)
22 AWG
16.3
18 AWG
6.9
Max. Operating Voltage - UL:
Voltage
300 V RMS
Max. Recommended Current:
Current
3.8 Amps per conductor @ 25°C (22 AWG); 7.2 Amps per conductor @ 25°C (18 AWG)
Notes (Overall)
Notes: Sequential footage marking every two feet.
Put Ups and Colors:
Item #
Putup
Ship Weight
Color
Notes
Item Desc
1502R G751000
1,000 FT
44.000 LB
AQUA
C
2 #18 PVC +2 FS #22 FHDPEFRPVC
1502R G75500
500 FT
22.000 LB
AQUA
C
1502R 0091000
1,000 FT
44.000 LB
WHITE
C
1502R 009500
500 FT
22.000 LB
WHITE
C
1502R 0101000
1,000 FT
44.000 LB
BLACK
C
1502R 01010000
10,000 FT
470.000 LB
BLACK
1502R 010500
500 FT
22.000 LB
BLACK
1502R 0105000
5,000 FT
215.000 LB
BLACK
C
Notes:
C = CRATE REEL PUT-UP.
Page 2 of 3
01-05-2017
Revision Number: 1
Revision Date: 07-30-2013
© 2017 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to
change without notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for
any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether
in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities
and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is
correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the
safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification.
Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the
product.
Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU).
Page 3 of 3
01-05-2017
很抱歉,暂时无法提供与“1502R G751000”相匹配的价格&库存,您可以联系我们找货
