1505F G7W1000
1505F G7W1000
    BELDEN
    #21 GIFHDLDPE DBLB PVC
1505F G7W1000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1505F Coax - RG-59/U Type For more Information please call 1-800-Belden1 General Description: 22 AWG stranded (7x29) .031" bare compacted copper conductor, gas-injected foam HDPE insulation, tinned copper double braid shield (95% coverage), PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Coax AWG Stranding Conductor Material 1 22 7x29 Dia. (in.) BCC - Bare Compacted Copper .031 Total Number of Conductors: 1 Insulation Insulation Material: Insulation Material Dia. (in.) Gas-injected FHDPE - Foam High Density Polyethylene .145 Outer Shield Outer Shield Material: Layer # Type Outer Shield Material Coverage (%) 1 Braid TC - Tinned Copper 95.000 2 Braid TC - Tinned Copper 95.000 Outer Jacket Outer Jacket Material: Outer Jacket Material PVC - Polyvinyl Chloride Overall Cable Overall Nominal Diameter: 0.242 in. Mechanical Characteristics (Overall) Operating Temperature Range: -35°C To +75°C UL Temperature Rating: 75°C Bulk Cable Weight: 41 lbs/1000 ft. Max. Recommended Pulling Tension: 88 lbs. Min. Bend Radius/Minor Axis: 2.500 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CM CEC/C(UL) Specification: CM EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes RG Type: 59/U Page 1 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1505F Coax - RG-59/U Type Flame Test UL Flame Test: UL1685 UL Loading Suitability Suitability - Indoor: Yes Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 75 Nom. Inductance: Inductance (µH/ft) 0.094 Nom. Capacitance Conductor to Shield: Capacitance (pF/ft) 17.0 Nominal Velocity of Propagation: VP (%) 80 Nominal Delay: Delay (ns/ft) 1.3 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 12.2 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 2.4 Nom. Attenuation: Freq. (MHz) Attenuation (dB/100 ft.) 1.000 0.200 3.600 0.500 5.000 0.600 6.000 0.670 7.000 0.730 10.000 0.900 12.000 0.980 25.000 1.440 67.500 2.400 71.500 2.500 88.500 2.800 100.000 3.000 135.000 3.500 143.000 3.600 180.000 4.100 270.000 5.100 360.000 6.000 540.000 7.500 720.000 8.900 750.000 9.100 1000.000 10.800 1500.000 13.600 2000.000 16.100 2250.000 17.300 3000.000 20.700 4500.000 26.700 Max. Operating Voltage - UL: Voltage 300 V RMS Other Electrical Characteristic 1: Impedance tested in accordance with ASTM D-4566 paragraph 43.2, option 2 using a 75 Ohm fixed bridge and termination. Other Electrical Characteristic 2: Return Loss tested in accordance with ASTM D-4566 paragraph 45.3, using a 75 Ohm fixed bridge and Page 2 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1505F Coax - RG-59/U Type Other Electrical Characteristic 2: Return Loss tested in accordance with ASTM D-4566 paragraph 45.3, using a 75 Ohm fixed bridge and termination. Minimum Return Loss: Start Freq. (MHz) Stop Freq. (MHz) Min. RL (dB) 5.000 850.000 20.000 851.000 4500.000 15.000 Sweep Test Sweep Testing: 100% Sweep tested 5 MHz to 4.5 GHz. Notes (Overall) Notes: Compacted conductor combines impedance uniformity of solid conductors and "nick-resistance" of stranded conductor. Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 1505F B591000 1,000 FT 45.000 LB BLACK, MATTE C #21 GIFHDLDPE DBLB PVC 1505F G7V1000 1,000 FT 45.000 LB RED, MATTE C #21 GIFHDLDPE DBLB PVC 1505F G7W1000 1,000 FT 45.000 LB GREEN, MATTE C #21 GIFHDLDPE DBLB PVC 1505F G7X1000 1,000 FT 45.000 LB BLUE, MATTE C #21 GIFHDLDPE DBLB PVC 1505F G7Y1000 1,000 FT 45.000 LB WHITE, MATTE C #21 GIFHDLDPE DBLB PVC 1505F G8L1000 1,000 FT 45.000 LB ORANGE, MATTE C #21 GIFHDLDPE DBLB PVC 1505F Z4B1000 1,000 FT 45.000 LB VIO Z4B 1505F 0041000 1,000 FT 45.000 LB YELLOW #21 GIFHDLDPE DBLB PVC C #21 GIFHDLDPE DBLB PVC Notes: C = CRATE REEL PUT-UP. Revision Number: 11 Revision Date: 06-17-2016 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 3 of 3 01-05-2017
1505F G7W1000 价格&库存
很抱歉,暂时无法提供与“1505F G7W1000”相匹配的价格&库存,您可以联系我们找货
